[GeoNode-devel] Switching to MapStore in GeoNode
Paolo Corti
pcorti at gmail.com
Thu Apr 4 06:24:02 PDT 2019
Hi Alessio,
I gave a first look at this today, and it is really great and a compelling
alternative to the old fashioned GeoExplorer :)
Could you explain how it is possible to edit a style, as I didn't find the
way? Thanks a lot
Paolo
On Tue, Apr 2, 2019 at 12:47 PM Paolo Pasquali <paolo.pasquali at gmail.com>
wrote:
> Ciao Alessio,
> I've probably messed up my docker installation. I've solved rebuilding
> and adding the mapstore packages in the requirements.
> I'm still not sure why it didn't work by pip installing them after the
> initial setup.
> Anyway, thank you Alessio for your support.
> I'll get back to you for more info about MapStore for sure... 😀
> Ciao,
> P.
> On Mon, Apr 1, 2019 at 6:39 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> P.S.: it works only with GeoNode 2.10+
>> Il giorno lun 1 apr 2019 alle ore 18:36 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> That is quite strange. Have you been able to get a stacktrace somehow?
>>> Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to check that
>>> the exception does not occur or it is hidden by another one.
>>> Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
>>> paolo.pasquali at gmail.com> ha scritto:
>>>> Ciao Alessio,
>>>> My settings section starts with:
>>>> # To enable the MapStore2 based Client enable those
>>>> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>>>> INSTALLED_APPS += (
>>>> 'mapstore2_adapter',
>>>> 'geonode_mapstore_client',)
>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore' # DEPRECATED use
>>>> HOOKSET instead
>>>> GEONODE_CLIENT_HOOKSET =
>>>> "geonode_mapstore_client.hooksets.MapStoreHookSet"
>>>> Thanks,
>>>> P.
>>>> Paolo Pasquali
>>>> ITHACA - Information Technology for Humanitarian Assistance,
>>>> Cooperation and Action
>>>> via Pier Carlo Boggio, 61
>>>> 10138 Torino - Italy
>>>> Tel. +39 011 1975 1872
>>>> Fax +39 011 1975 1122
>>>> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
>>>>> Hello Paolo,
>>>>> can you check if the before the Hookset you have the following
>>>>> sentence in your settings file
>>>>> INSTALLED_APPS += (
>>>>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>>>>> Dear all,
>>>>>> I would like to test MapStore in GeoNode. I've followed the
>>>>>> instructions [1] and removed the related comments in my settings but I get:
>>>>>> ImportError: No module named mapstore2_adapter
>>>>>> Double checking:
>>>>>> $ pip show django-mapstore-adapter
>>>>>> Version: 0.1.13
>>>>>> Summary: Django MapStore2 Adapter
>>>>>> Home-page: https://github.com/geosolutions-it/django-mapstore-adapter
>>>>>> Author: Alessio Fabiani
>>>>>> Author-email: alessio.fabiani at geo-solutions.it
>>>>>> License: UNKNOWN
>>>>>> Location:
>>>>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>>>>> Requires: Markdown, requests, django, jsonfield, djangorestframework,
>>>>>> idna, MarkupSafe
>>>>>> Required-by: django-geonode-mapstore-client
>>>>>> And
>>>>>> $ pip show django-geonode-mapstore-client
>>>>>> Version: 0.1.18
>>>>>> Summary: Use GeoNode client in your django projects
>>>>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>>>>> Author-email: alessio.fabiani at gmail.com
>>>>>> License: BSD, see LICENSE file.
>>>>>> Location:
>>>>>> Requires: django-mapstore-adapter
>>>>>> Required-by:
>>>>>> Thanks in advance for your help.
>>>>>> Best,
>>>>>> Paolo
>>>>>> [1]
>>>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/b9beb47a/attachment-0001.html>
More information about the geonode-devel
