[GeoNode-devel] Switching to MapStore in GeoNode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Apr 4 06:29:04 PDT 2019
Hi Paolo,
cool. Currently, it is possible either by clicking the "Styles > Edit" from
the "Editing Tools" section or by creating/editing a new map containing
that Layer.
[image: image.png]
Il giorno gio 4 apr 2019 alle ore 15:25 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi Alessio,
> I gave a first look at this today, and it is really great and a compelling
> alternative to the old fashioned GeoExplorer :)
> Could you explain how it is possible to edit a style, as I didn't find the
> way? Thanks a lot
> Paolo
> On Tue, Apr 2, 2019 at 12:47 PM Paolo Pasquali <paolo.pasquali at gmail.com>
> wrote:
>> Ciao Alessio,
>> I've probably messed up my docker installation. I've solved rebuilding
>> and adding the mapstore packages in the requirements.
>> I'm still not sure why it didn't work by pip installing them after the
>> initial setup.
>> Anyway, thank you Alessio for your support.
>> I'll get back to you for more info about MapStore for sure... 😀
>> Ciao,
>> P.
>> On Mon, Apr 1, 2019 at 6:39 PM Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> P.S.: it works only with GeoNode 2.10+
>>> Il giorno lun 1 apr 2019 alle ore 18:36 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>> That is quite strange. Have you been able to get a stacktrace somehow?
>>>> Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to check that
>>>> the exception does not occur or it is hidden by another one.
>>>> Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>> Ciao Alessio,
>>>>> My settings section starts with:
>>>>> # To enable the MapStore2 based Client enable those
>>>>> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>>>>> INSTALLED_APPS += (
>>>>> 'mapstore2_adapter',
>>>>> 'geonode_mapstore_client',)
>>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore' # DEPRECATED use
>>>>> HOOKSET instead
>>>>> GEONODE_CLIENT_HOOKSET =
>>>>> "geonode_mapstore_client.hooksets.MapStoreHookSet"
>>>>> Thanks,
>>>>> P.
>>>>> Paolo Pasquali
>>>>> ITHACA - Information Technology for Humanitarian Assistance,
>>>>> Cooperation and Action
>>>>> via Pier Carlo Boggio, 61
>>>>> 10138 Torino - Italy
>>>>> Tel. +39 011 1975 1872
>>>>> Fax +39 011 1975 1122
>>>>> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
>>>>>> Hello Paolo,
>>>>>> can you check if the before the Hookset you have the following
>>>>>> sentence in your settings file
>>>>>> INSTALLED_APPS += (
>>>>>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>>>>>> Dear all,
>>>>>>> I would like to test MapStore in GeoNode. I've followed the
>>>>>>> instructions [1] and removed the related comments in my settings but I get:
>>>>>>> ImportError: No module named mapstore2_adapter
>>>>>>> Double checking:
>>>>>>> $ pip show django-mapstore-adapter
>>>>>>> Version: 0.1.13
>>>>>>> Summary: Django MapStore2 Adapter
>>>>>>> Home-page:
>>>>>>> https://github.com/geosolutions-it/django-mapstore-adapter
>>>>>>> Author: Alessio Fabiani
>>>>>>> Author-email: alessio.fabiani at geo-solutions.it
>>>>>>> License: UNKNOWN
>>>>>>> Location:
>>>>>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>>>>>> Requires: Markdown, requests, django, jsonfield,
>>>>>>> djangorestframework, idna, MarkupSafe
>>>>>>> Required-by: django-geonode-mapstore-client
>>>>>>> And
>>>>>>> $ pip show django-geonode-mapstore-client
>>>>>>> Version: 0.1.18
>>>>>>> Summary: Use GeoNode client in your django projects
>>>>>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>>>>>> Author-email: alessio.fabiani at gmail.com
>>>>>>> License: BSD, see LICENSE file.
>>>>>>> Location:
>>>>>>> Requires: django-mapstore-adapter
>>>>>>> Required-by:
>>>>>>> Thanks in advance for your help.
>>>>>>> Best,
>>>>>>> Paolo
>>>>>>> [1]
>>>>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax: +39 0584 1660272
>>>>>> mob: +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> @alfa7691
>>> GeoSolutions S.A.S.
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/bbb0f757/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/bbb0f757/attachment-0001.png>
More information about the geonode-devel
