[GeoNode-devel] Switching to MapStore in GeoNode
Simone Giannecchini
simone.giannecchini at geo-solutions.it
Thu Apr 4 06:58:11 PDT 2019
Paolo,
the standard version of MapStore (which we are using for GeoNode) does not
support vector tiles yet.
We are experimenting within the framework of OGC testbeds on the support of
vector tiles and the ability to switch server-side rendering to client-side
rendering (and the other way around) but this experiment has not landed on
master yet.
I think Alessio sent links to these pilots earlier, but still, these are
pilots of what will come in the future.
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
On Thu, Apr 4, 2019 at 3:53 PM Paolo Pasquali <
paolo.pasquali at ithaca.polito.it> wrote:
> Dear Alessio, Simone,
> As I understand MapStore can also publish Vector Tiles.
> My guess is that the GeoServer Vector Tiles Extension must be installed
> [1] since it doesn't come with GeoNode.
> The extension works fine with an OpenLayers simple viewer but that must be
> defined in the source code with new ol.layer.VectorTile and so on.
> Is there any documentation on how to publish vector tiles in MapStore
> instead of Image Tiles?
> Does the style editor works with Vector Tiles as well?
> Thanks!
> Ciao
> Paolo
> [1]
> https://docs.geoserver.org/latest/en/user/extensions/vectortiles/install.html
> On Thu, Apr 4, 2019 at 3:50 PM Paolo Corti <pcorti at gmail.com> wrote:
>> Thanks a lot, it looks really powerful and impressive.
>> Do I understand correctly that there isn't a UI widget for editing styles
>> (such as the one in GeoExplorer) but you can make changes only via the
>> SLD/CSS editor? That could limit the utility for GeoNode instances where
>> general public isn't used to tools which are not UI based.
>> cheers
>> Paolo
>> On Thu, Apr 4, 2019 at 3:37 PM Simone Giannecchini <
>> simone.giannecchini at geo-solutions.it> wrote:
>>> These webinars registrations (mind you, they are huge) can help:
>>> https://www.dropbox.com/s/q1rdwuzc4wu0y0f/Map%20Styling%20IGAD%201.mp4?dl=0
>>> https://www.dropbox.com/s/3yrmb5tdrilt9f9/Map%20Styling%20IGAD%202.mp4?dl=0
>>> Regards,
>>> Simone Giannecchini
>>> @simogeo
>>> Founder/Director
>>> GeoSolutions S.A.S.
>>> Italy
>>> http://twitter.com/geosolutions_it
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> On Thu, Apr 4, 2019 at 3:29 PM Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Hi Paolo,
>>>> cool. Currently, it is possible either by clicking the "Styles > Edit"
>>>> from the "Editing Tools" section or by creating/editing a new map
>>>> containing that Layer.
>>>> [image: image.png]
>>>> Il giorno gio 4 apr 2019 alle ore 15:25 Paolo Corti <pcorti at gmail.com>
>>>> ha scritto:
>>>>> Hi Alessio,
>>>>> I gave a first look at this today, and it is really great and a
>>>>> compelling alternative to the old fashioned GeoExplorer :)
>>>>> Could you explain how it is possible to edit a style, as I didn't find
>>>>> the way? Thanks a lot
>>>>> Paolo
>>>>> On Tue, Apr 2, 2019 at 12:47 PM Paolo Pasquali <
>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>> Ciao Alessio,
>>>>>> I've probably messed up my docker installation. I've solved
>>>>>> rebuilding and adding the mapstore packages in the requirements.
>>>>>> I'm still not sure why it didn't work by pip installing them after
>>>>>> the initial setup.
>>>>>> Anyway, thank you Alessio for your support.
>>>>>> I'll get back to you for more info about MapStore for sure... 😀
>>>>>> Ciao,
>>>>>> P.
>>>>>> On Mon, Apr 1, 2019 at 6:39 PM Alessio Fabiani <
>>>>>>> P.S.: it works only with GeoNode 2.10+
>>>>>>> Il giorno lun 1 apr 2019 alle ore 18:36 Alessio Fabiani <
>>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>>> That is quite strange. Have you been able to get a stacktrace
>>>>>>>> somehow? Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to
>>>>>>>> check that the exception does not occur or it is hidden by another one.
>>>>>>>> Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
>>>>>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>>>>>> Ciao Alessio,
>>>>>>>>> My settings section starts with:
>>>>>>>>> # To enable the MapStore2 based Client enable those
>>>>>>>>> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>>>>>>>>> INSTALLED_APPS += (
>>>>>>>>> 'mapstore2_adapter',
>>>>>>>>> 'geonode_mapstore_client',)
>>>>>>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore' # DEPRECATED
>>>>>>>>> use HOOKSET instead
>>>>>>>>> GEONODE_CLIENT_HOOKSET =
>>>>>>>>> "geonode_mapstore_client.hooksets.MapStoreHookSet"
>>>>>>>>> Thanks,
>>>>>>>>> P.
>>>>>>>>> Paolo Pasquali
>>>>>>>>> ITHACA - Information Technology for Humanitarian Assistance,
>>>>>>>>> Cooperation and Action
>>>>>>>>> via Pier Carlo Boggio, 61
>>>>>>>>> 10138 Torino - Italy
>>>>>>>>> Tel. +39 011 1975 1872
>>>>>>>>> Fax +39 011 1975 1122
>>>>>>>>> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
>>>>>>>>>> Hello Paolo,
>>>>>>>>>> can you check if the before the Hookset you have the following
>>>>>>>>>> sentence in your settings file
>>>>>>>>>> INSTALLED_APPS += (
>>>>>>>>>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>>>>>>>>>> Dear all,
>>>>>>>>>>> I would like to test MapStore in GeoNode. I've followed the
>>>>>>>>>>> instructions [1] and removed the related comments in my settings but I get:
>>>>>>>>>>> ImportError: No module named mapstore2_adapter
>>>>>>>>>>> Double checking:
>>>>>>>>>>> $ pip show django-mapstore-adapter
>>>>>>>>>>> Version: 0.1.13
>>>>>>>>>>> Summary: Django MapStore2 Adapter
>>>>>>>>>>> Home-page:
>>>>>>>>>>> https://github.com/geosolutions-it/django-mapstore-adapter
>>>>>>>>>>> Author: Alessio Fabiani
>>>>>>>>>>> Author-email: alessio.fabiani at geo-solutions.it
>>>>>>>>>>> License: UNKNOWN
>>>>>>>>>>> Location:
>>>>>>>>>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>>>>>>>>>> Requires: Markdown, requests, django, jsonfield,
>>>>>>>>>>> djangorestframework, idna, MarkupSafe
>>>>>>>>>>> Required-by: django-geonode-mapstore-client
>>>>>>>>>>> And
>>>>>>>>>>> $ pip show django-geonode-mapstore-client
>>>>>>>>>>> Version: 0.1.18
>>>>>>>>>>> Summary: Use GeoNode client in your django projects
>>>>>>>>>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>>>>>>>>>> Author-email: alessio.fabiani at gmail.com
>>>>>>>>>>> License: BSD, see LICENSE file.
>>>>>>>>>>> Location:
>>>>>>>>>>> Requires: django-mapstore-adapter
>>>>>>>>>>> Required-by:
>>>>>>>>>>> Thanks in advance for your help.
>>>>>>>>>>> Best,
>>>>>>>>>>> Paolo
>>>>>>>>>>> [1]
>>>>>>>>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>> @alfa7691
>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>> Paolo Corti
>>>>> Geospatial software developer
>>>>> web: http://www.paolocorti.net
>>>>> twitter: @capooti
>>>>> skype: capooti
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/441a0d8c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/441a0d8c/attachment-0001.png>
More information about the geonode-devel
