[GeoNode-devel] Switching to MapStore in GeoNode
Paolo Pasquali paolo.pasquali at ithaca.polito.it
Mon Apr 8 03:29:48 PDT 2019
Thanks Simone.
Please consider a MapStore presentation at the next Summit.
I'm looking forward to learning more.
Ciao
P.
On Thu, Apr 4, 2019 at 3:58 PM Simone Giannecchini <
simone.giannecchini at geo-solutions.it> wrote:
> Paolo,
> the standard version of MapStore (which we are using for GeoNode) does not
> support vector tiles yet.
> We are experimenting within the framework of OGC testbeds on the support
> of vector tiles and the ability to switch server-side rendering to
> client-side rendering (and the other way around) but this experiment has
> not landed on master yet.
> I think Alessio sent links to these pilots earlier, but still, these are
> pilots of what will come in the future.
> Regards,
> Simone Giannecchini
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> On Thu, Apr 4, 2019 at 3:53 PM Paolo Pasquali <
> paolo.pasquali at ithaca.polito.it> wrote:
>> Dear Alessio, Simone,
>> As I understand MapStore can also publish Vector Tiles.
>> My guess is that the GeoServer Vector Tiles Extension must be installed
>> [1] since it doesn't come with GeoNode.
>> The extension works fine with an OpenLayers simple viewer but that must
>> be defined in the source code with new ol.layer.VectorTile and so on.
>> Is there any documentation on how to publish vector tiles in MapStore
>> instead of Image Tiles?
>> Does the style editor works with Vector Tiles as well?
>> Thanks!
>> Ciao
>> Paolo
>> [1]
>> https://docs.geoserver.org/latest/en/user/extensions/vectortiles/install.html
>> On Thu, Apr 4, 2019 at 3:50 PM Paolo Corti <pcorti at gmail.com> wrote:
>>> Thanks a lot, it looks really powerful and impressive.
>>> Do I understand correctly that there isn't a UI widget for editing
>>> styles (such as the one in GeoExplorer) but you can make changes only via
>>> the SLD/CSS editor? That could limit the utility for GeoNode instances
>>> where general public isn't used to tools which are not UI based.
>>> cheers
>>> Paolo
>>> On Thu, Apr 4, 2019 at 3:37 PM Simone Giannecchini <
>>>> These webinars registrations (mind you, they are huge) can help:
>>>> https://www.dropbox.com/s/q1rdwuzc4wu0y0f/Map%20Styling%20IGAD%201.mp4?dl=0
>>>> https://www.dropbox.com/s/3yrmb5tdrilt9f9/Map%20Styling%20IGAD%202.mp4?dl=0
>>>> Regards,
>>>> Simone Giannecchini
>>>> @simogeo
>>>> Founder/Director
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> On Thu, Apr 4, 2019 at 3:29 PM Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>> Hi Paolo,
>>>>> cool. Currently, it is possible either by clicking the "Styles > Edit"
>>>>> from the "Editing Tools" section or by creating/editing a new map
>>>>> containing that Layer.
>>>>> [image: image.png]
>>>>> Il giorno gio 4 apr 2019 alle ore 15:25 Paolo Corti <pcorti at gmail.com>
>>>>> ha scritto:
>>>>>> Hi Alessio,
>>>>>> I gave a first look at this today, and it is really great and a
>>>>>> compelling alternative to the old fashioned GeoExplorer :)
>>>>>> Could you explain how it is possible to edit a style, as I didn't
>>>>>> find the way? Thanks a lot
>>>>>> Paolo
>>>>>> On Tue, Apr 2, 2019 at 12:47 PM Paolo Pasquali <
>>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>>> Ciao Alessio,
>>>>>>> I've probably messed up  my docker installation. I've solved
>>>>>>> rebuilding and adding the mapstore packages in the requirements.
>>>>>>> I'm still not sure why it didn't work by pip installing them after
>>>>>>> the initial setup.
>>>>>>> Anyway, thank you Alessio for your support.
>>>>>>> I'll get back to you for more info about MapStore for sure... 😀
>>>>>>> Ciao,
>>>>>>> P.
>>>>>>> On Mon, Apr 1, 2019 at 6:39 PM Alessio Fabiani <
>>>>>>>> P.S.: it works only with GeoNode 2.10+
>>>>>>>> Il giorno lun 1 apr 2019 alle ore 18:36 Alessio Fabiani <
>>>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>>>> That is quite strange. Have you been able to get a stacktrace
>>>>>>>>> somehow? Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to
>>>>>>>>> check that the exception does not occur or it is hidden by another one.
>>>>>>>>> Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
>>>>>>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>>>>>>> Ciao Alessio,
>>>>>>>>>> My settings section starts with:
>>>>>>>>>> # To enable the MapStore2 based Client enable those
>>>>>>>>>> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>>>>>>>>>>     INSTALLED_APPS += (
>>>>>>>>>>         'mapstore2_adapter',
>>>>>>>>>>         'geonode_mapstore_client',)
>>>>>>>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore'  # DEPRECATED
>>>>>>>>>> use HOOKSET instead
>>>>>>>>>> GEONODE_CLIENT_HOOKSET =
>>>>>>>>>> "geonode_mapstore_client.hooksets.MapStoreHookSet"
>>>>>>>>>> Thanks,
>>>>>>>>>> P.
>>>>>>>>>> Paolo Pasquali
>>>>>>>>>> ITHACA - Information Technology for Humanitarian Assistance,
>>>>>>>>>> Cooperation and Action
>>>>>>>>>> via Pier Carlo Boggio, 61
>>>>>>>>>> 10138 Torino - Italy
>>>>>>>>>> Tel. +39 011 1975 1872
>>>>>>>>>> Fax +39 011 1975 1122
>>>>>>>>>> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
>>>>>>>>>>> Hello Paolo,
>>>>>>>>>>> can you check if the before the Hookset you have the following
>>>>>>>>>>> sentence in your settings file
>>>>>>>>>>>     INSTALLED_APPS += (
>>>>>>>>>>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>>>>>>>>>>> Dear all,
>>>>>>>>>>>> I would like to test MapStore in GeoNode. I've followed the
>>>>>>>>>>>> instructions [1] and removed the related comments in my settings but I get:
>>>>>>>>>>>> ImportError: No module named mapstore2_adapter
>>>>>>>>>>>> Double checking:
>>>>>>>>>>>> $ pip show django-mapstore-adapter
>>>>>>>>>>>> Version: 0.1.13
>>>>>>>>>>>> Summary: Django MapStore2 Adapter
>>>>>>>>>>>> Home-page:
>>>>>>>>>>>> https://github.com/geosolutions-it/django-mapstore-adapter
>>>>>>>>>>>> Author: Alessio Fabiani
>>>>>>>>>>>> Author-email: alessio.fabiani at geo-solutions.it
>>>>>>>>>>>> License: UNKNOWN
>>>>>>>>>>>> Location:
>>>>>>>>>>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>>>>>>>>>>> Requires: Markdown, requests, django, jsonfield,
>>>>>>>>>>>> djangorestframework, idna, MarkupSafe
>>>>>>>>>>>> Required-by: django-geonode-mapstore-client
>>>>>>>>>>>> And
>>>>>>>>>>>> $ pip show django-geonode-mapstore-client
>>>>>>>>>>>> Version: 0.1.18
>>>>>>>>>>>> Summary: Use GeoNode client in your django projects
>>>>>>>>>>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>>>>>>>>>>> Author-email: alessio.fabiani at gmail.com
>>>>>>>>>>>> License: BSD, see LICENSE file.
>>>>>>>>>>>> Location:
>>>>>>>>>>>> Requires: django-mapstore-adapter
>>>>>>>>>>>> Required-by:
>>>>>>>>>>>> Thanks in advance for your help.
>>>>>>>>>>>> Best,
>>>>>>>>>>>> Paolo
>>>>>>>>>>>> [1]
>>>>>>>>>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>> notizia.
>>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>> Paolo Corti
>>>>>> Geospatial software developer
>>>>>> web: http://www.paolocorti.net
>>>>>> twitter: @capooti
>>>>>> skype: capooti
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190408/a724bdbe/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190408/a724bdbe/attachment-0001.png>
More information about the geonode-devel mailing list
