[GeoNode-devel] Authentication between geonode and geoserver doesn't happen automatically.
Dimitris Karakostis
karakostis.dimitris at gmail.com
Tue Apr 16 02:21:45 PDT 2019
Hello all,
I have installed a geonode-project (2.10rc4) in an AWS EC2 Ubuntu 16.04 EC2
machine and configured the geoserver and geonode as described in the
documentation
<http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html>.
I am able to access both geonode and geoserver but the authentication
between these two doesn't work. I have tried both with the default admin
user or also other users. When I try to upload a shapefile, the layer is
created in geoserver but the process freezes in this step: "Performing
Final GeoServer Config Step". The ports I have enabled in the security
groups of the EC2 is (80, 8000, 8080, 5432). Below is the log files from
geoserver:
16 Apr 09:13:22 INFO [importer.rest] - Handling POST of
multipart/form-data; boundary=----------ThIs_Is_tHe_bouNdaRY_$
16 Apr 09:13:23 WARN [geoserver.security] - Could not find factory for
store : DataStoreInfoImpl[geonode_data]. Unable to encrypt connection
parameters.
16 Apr 09:13:23 ERROR [geoserver.rest] - No such layer:
afg_acled_secincidents_collected_30sep2018_306
org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such layer:
16 Apr 09:13:23 WARN [common.sender] - Error while trying to initialize
RabbitMQ Sender Connecton
java.net.ConnectException: Connection refused (Connection refused)
AULT req:DEFAULT ws:"geonode"+
layer:"afg_acled_secincidents_collected_30sep2018_307"+]
16 Apr 09:20:36 WARN [services.RuleReaderServiceImpl] - No access for
filter RuleFilter[user:DEFAULT role:DEFAULT inst:name+:default-gs
ip:"3.212.173.63"+ serv:DEFAULT req:DEFAULT ws:"geonode"+
16 Apr 09:20:36 INFO [services.RuleReaderServiceImpl] - Returning
AccessInfo[grant:DENY admin:false] for RuleFilter[user:DEFAULT role:DEFAULT
inst:name+:default-gs ip:"3.212.173.63"+ serv:DEFAULT req:DEFAULT
ws:"geonode"+ layer:"afg_acled_secincidents_collected_30sep2018_307"+]
16 Apr 09:20:36 ERROR [geoserver.rest] - No such layer:
at
org.geoserver.rest.catalog.LayerController.layerGet(LayerController.java:115)
at sun.reflect.GeneratedMethodAccessor508.invoke(Unknown Source)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at
org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at
org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at
org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
at
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
at
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
at
org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
at
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
at
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at
at
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at
org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:89)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
at
at
org.springframework.orm.hibernate3.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:198)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at
at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:83)
at
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at
at
org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:173)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:494)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at
org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
at
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1520)
at
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1476)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190416/a39872f1/attachment-0001.html>
More information about the geonode-devel
