[GeoNode-devel] Authentication between geonode and geoserver doesn't happen automatically.
Dimitris Karakostis
karakostis.dimitris at gmail.com
Tue Apr 16 07:11:07 PDT 2019
Hello Toni,
Yes I have followed these instructions as they have worked nicely in the
past. From the logs do you verify also, that there is an issue with the
authentication between geonode and geoserver?
On Tue, Apr 16, 2019 at 11:21 AM Dimitris Karakostis <
karakostis.dimitris at gmail.com> wrote:
> Hello all,
> I have installed a geonode-project (2.10rc4) in an AWS EC2 Ubuntu 16.04
> EC2 machine and configured the geoserver and geonode as described in the
> documentation
> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html>.
> I am able to access both geonode and geoserver but the authentication
> between these two doesn't work. I have tried both with the default admin
> user or also other users. When I try to upload a shapefile, the layer is
> created in geoserver but the process freezes in this step: "Performing
> Final GeoServer Config Step". The ports I have enabled in the security
> groups of the EC2 is (80, 8000, 8080, 5432). Below is the log files from
> geoserver:
> 16 Apr 09:13:22 INFO [importer.rest] - Handling POST of
> multipart/form-data; boundary=----------ThIs_Is_tHe_bouNdaRY_$
> 16 Apr 09:13:23 WARN [geoserver.security] - Could not find factory for
> store : DataStoreInfoImpl[geonode_data]. Unable to encrypt connection
> parameters.
> 16 Apr 09:13:23 ERROR [geoserver.rest] - No such layer:
> afg_acled_secincidents_collected_30sep2018_306
> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such layer:
> 16 Apr 09:13:23 WARN [common.sender] - Error while trying to initialize
> RabbitMQ Sender Connecton
> java.net.ConnectException: Connection refused (Connection refused)
> AULT req:DEFAULT ws:"geonode"+
> layer:"afg_acled_secincidents_collected_30sep2018_307"+]
> 16 Apr 09:20:36 WARN [services.RuleReaderServiceImpl] - No access for
> filter RuleFilter[user:DEFAULT role:DEFAULT inst:name+:default-gs
> ip:"3.212.173.63"+ serv:DEFAULT req:DEFAULT ws:"geonode"+
> 16 Apr 09:20:36 INFO [services.RuleReaderServiceImpl] - Returning
> AccessInfo[grant:DENY admin:false] for RuleFilter[user:DEFAULT role:DEFAULT
> inst:name+:default-gs ip:"3.212.173.63"+ serv:DEFAULT req:DEFAULT
> ws:"geonode"+ layer:"afg_acled_secincidents_collected_30sep2018_307"+]
> 16 Apr 09:20:36 ERROR [geoserver.rest] - No such layer:
> at
> org.geoserver.rest.catalog.LayerController.layerGet(LayerController.java:115)
> at sun.reflect.GeneratedMethodAccessor508.invoke(Unknown Source)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:498)
> at
> org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
> at
> org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
> at
> org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
> at
> org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
> at
> org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
> at
> org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
> at
> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
> at
> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
> at
> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
> at
> org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
> at
> org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
> at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
> at
> at
> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
> at
> at
> at
> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
> at
> org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:89)
> at
> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
> at
> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
> at
> at
> org.springframework.orm.hibernate3.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:198)
> at
> org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
> at
> at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:83)
> at
> at
> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
> at
> at
> at
> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
> at
> at
> at
> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
> at
> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
> at
> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
> at
> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
> at
> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
> at
> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
> at
> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
> at
> at
> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
> at
> at
> at
> at
> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
> at
> at
> org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:173)
> at
> at
> at
> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
> at
> at
> at
> at
> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
> at
> at
> at
> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
> at
> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
> at
> at
> at
> at
> org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
> at
> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
> at
> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
> at
> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347)
> at
> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263)
> at
> at
> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
> at
> at
> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
> at
> at
> at
> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
> at
> at
> at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
> at
> at
> at
> org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
> at
> at
> at
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
> at
> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
> at
> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:494)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
> at
> org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
> at
> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
> at
> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
> at
> org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1520)
> at
> org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1476)
> at
> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
> at
> org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
> at java.lang.Thread.run(Thread.java:748)
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190416/496c407d/attachment-0001.html>
More information about the geonode-devel
