[GeoNode-devel] [Geoserver-users] Restauring GeoServer to its Default Credentials
Christian Mueller
christian.mueller at os-solutions.at
Tue Apr 23 23:21:08 PDT 2019
Hi
Edit users.xml and set "password="plain:mypassword".
Afterwards log in to Geoserver as admin and change the password. As a
consequence you should see "password="digest1:.....".
Cheers
On Tue, Apr 23, 2019 at 6:19 PM 1520 gis <
juliermeopensourcedeveloper at gmail.com> wrote:
> I also tried setting tGeoserver admin password bellow but it did not work:
> <user enabled="true" name="admin"
> password="digest1:D9miJH/hVgfxZJscMafEtbtliG0ROxhLfsznyWfG38X2pda2JOSV4POi55PQI4tw"/>
> Kind regards
> Julierme
> On Tue, Apr 23, 2019 at 12:44 PM 1520 gis <
>> Dear users and developers,
>> I have faced an issue with GeoServer Credentials since I changed its
>> defaults. I am running GeoNode-project master version installed via docker.
>> I went to Django container @ .../security/usergroup/default/users.xml and
>> I changed the admin credentials as discussed in here
>> <http://osgeo-org.1560.x6.nabble.com/Forgot-the-geoserver-login-password-td5298425.html>
>> , but I did not get any success.
>> Any help on how I could achieve that will be very appreciated.
>> Kind regards
>> Julierme
> Geoserver-users mailing list
> Please make sure you read the following two resources before posting to
> this list:
> - Earning your support instead of buying it, but Ian Turton:
> http://www.ianturton.com/talks/foss4g.html#/
> - The GeoServer user list posting guidelines:
> http://geoserver.org/comm/userlist-guidelines.html
> If you want to request a feature or an improvement, also see this:
> https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
> Geoserver-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190424/2fff9b9e/attachment.html>
More information about the geonode-devel
