[GeoNode-devel] error during layer upload using GeoNode master (TypeError: can't compare offset-naive and offset-aware datetimes)
Paolo Corti
pcorti at gmail.com
Fri Aug 9 11:29:58 PDT 2019
Hi devs
when uploading a layer using GeoNode master I am now getting this error:
File "/home/ubuntu/geonode/geonode/layers/views.py", line 217, in layer_upload
metadata_upload_form=form.cleaned_data["metadata_upload_form"])
File "/home/ubuntu/geonode/geonode/layers/utils.py", line 599, in file_upload
defaults=defaults
File "/home/ubuntu/env/local/lib/python2.7/site-packages/django/db/models/manager.py",
line 85, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/home/ubuntu/env/local/lib/python2.7/site-packages/modeltranslation/manager.py",
line 413, in get_or_create
return super(MultilingualQuerySet, self).get_or_create(**kwargs)
File "/home/ubuntu/env/local/lib/python2.7/site-packages/django/db/models/query.py",
line 466, in get_or_create
return self._create_object_from_params(lookup, params)
line 500, in _create_object_from_params
obj = self.create(**params)
line 405, in create
return super(MultilingualQuerySet, self).create(**kwargs)
line 394, in create
obj.save(force_insert=True, using=self.db)
File "/home/ubuntu/env/local/lib/python2.7/site-packages/polymorphic/models.py",
line 93, in save
return super(PolymorphicModel, self).save(*args, **kwargs)
File "/home/ubuntu/env/local/lib/python2.7/site-packages/django/db/models/base.py",
line 808, in save
force_update=force_update, update_fields=update_fields)
line 848, in save_base
update_fields=update_fields, raw=raw, using=using,
File "/home/ubuntu/env/local/lib/python2.7/site-packages/django/dispatch/dispatcher.py",
line 193, in send
for receiver in self._live_receivers(sender)
File "/home/ubuntu/geonode/geonode/decorators.py", line 53, in wrapper
return func(*args, **kwargs)
File "/home/ubuntu/geonode/geonode/geoserver/signals.py", line 94,
in geoserver_post_save
set_resource_default_links(instance, sender, prune=True)
File "/home/ubuntu/geonode/geonode/utils.py", line 1643, in
create_gs_thumbnail(instance, overwrite=True, check_bbox=True)
File "/home/ubuntu/geonode/geonode/geoserver/helpers.py", line 2154,
in create_gs_thumbnail
return implementation(instance, overwrite, check_bbox)
File "/home/ubuntu/geonode/geonode/layers/utils.py", line 1086, in
create_gs_thumbnail_geonode
if access_token and not access_token.is_expired():
File "/home/ubuntu/env/local/lib/python2.7/site-packages/oauth2_provider/models.py",
line 292, in is_expired
return timezone.now() >= self.expires
any idea before I start looking into it? (not sure if this was already
discussed here)
thanks
Paolo
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
#drt3jc1
More information about the geonode-devel
