[GeoNode-devel] error during layer upload using GeoNode master (TypeError: can't compare offset-naive and offset-aware datetimes)
Paolo Corti
pcorti at gmail.com
Fri Aug 9 11:43:49 PDT 2019
FYI (in case you get the same problem): this error is raised if you
are using USE_TZ = True
As suggested here [1] it looks like oauth2_provider should use
django.utils.timezone.now()
best
Paolo
[1] https://docs.djangoproject.com/en/2.2/topics/i18n/timezones/
On Fri, Aug 9, 2019 at 2:29 PM Paolo Corti <pcorti at gmail.com> wrote:
> Hi devs
> when uploading a layer using GeoNode master I am now getting this error:
> Traceback (most recent call last):
> File "/home/ubuntu/geonode/geonode/layers/views.py", line 217, in layer_upload
> metadata_upload_form=form.cleaned_data["metadata_upload_form"])
> File "/home/ubuntu/geonode/geonode/layers/utils.py", line 599, in file_upload
> defaults=defaults
> File "/home/ubuntu/env/local/lib/python2.7/site-packages/django/db/models/manager.py",
> line 85, in manager_method
> return getattr(self.get_queryset(), name)(*args, **kwargs)
> File "/home/ubuntu/env/local/lib/python2.7/site-packages/modeltranslation/manager.py",
> line 413, in get_or_create
> return super(MultilingualQuerySet, self).get_or_create(**kwargs)
> File "/home/ubuntu/env/local/lib/python2.7/site-packages/django/db/models/query.py",
> line 466, in get_or_create
> return self._create_object_from_params(lookup, params)
> line 500, in _create_object_from_params
> obj = self.create(**params)
> line 405, in create
> return super(MultilingualQuerySet, self).create(**kwargs)
> line 394, in create
> obj.save(force_insert=True, using=self.db)
> File "/home/ubuntu/env/local/lib/python2.7/site-packages/polymorphic/models.py",
> line 93, in save
> return super(PolymorphicModel, self).save(*args, **kwargs)
> File "/home/ubuntu/env/local/lib/python2.7/site-packages/django/db/models/base.py",
> line 808, in save
> force_update=force_update, update_fields=update_fields)
> line 848, in save_base
> update_fields=update_fields, raw=raw, using=using,
> File "/home/ubuntu/env/local/lib/python2.7/site-packages/django/dispatch/dispatcher.py",
> line 193, in send
> for receiver in self._live_receivers(sender)
> File "/home/ubuntu/geonode/geonode/decorators.py", line 53, in wrapper
> return func(*args, **kwargs)
> File "/home/ubuntu/geonode/geonode/geoserver/signals.py", line 94,
> in geoserver_post_save
> set_resource_default_links(instance, sender, prune=True)
> File "/home/ubuntu/geonode/geonode/utils.py", line 1643, in
> create_gs_thumbnail(instance, overwrite=True, check_bbox=True)
> File "/home/ubuntu/geonode/geonode/geoserver/helpers.py", line 2154,
> in create_gs_thumbnail
> return implementation(instance, overwrite, check_bbox)
> File "/home/ubuntu/geonode/geonode/layers/utils.py", line 1086, in
> create_gs_thumbnail_geonode
> if access_token and not access_token.is_expired():
> File "/home/ubuntu/env/local/lib/python2.7/site-packages/oauth2_provider/models.py",
> line 292, in is_expired
> return timezone.now() >= self.expires
> any idea before I start looking into it? (not sure if this was already
> discussed here)
> thanks
> Paolo
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> #drt3jc1
Paolo Corti
twitter: @capooti
skype: capooti
#drt3jc1
More information about the geonode-devel
