[GeoNode-devel] Fixing JSONP enabled by default in MappingJackson2JsonView
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Aug 19 02:59:11 PDT 2019
Dear Naresh,
I had the occasion to have a deeper look at this topic.
So, currently, those endpoints have been exposed by "djanto-tastypie".
Unfortunately, tastypie accepts the keyword "callback" and actually scans
it to be a valid JSONP call. Therefore, not only this is admitted but it is
also used by the package to render the outputs.
As far as I can see from the code, it doesn't look to be harmful, and the
response is consistent.
Do you have clear evidence that it is possible to invoke an external JSONP
somehow?
I don't know the tool you are using to make the security tests, but I guess
it shouldn't be only checking for the query parameter "callback" to be
accepted or not.
That said, to remove this warning I'm afraid that the only solution would
be to rewrite those APIs without using Tatypie. Which would be good, by the
way, but I don't think there are currently volunteers or people able to
make such a big change for free,
You will probably need to wait for the GeoNode 3.0 version, which,
hopefully, will get rid of this old-fashioned library too.
Best regards,
Alessio.
Il giorno mer 14 ago 2019 alle ore 13:51 Naresh N <naresh919 at gmail.com> ha
scritto:
> Dear Alessio,
> Thanks for quick response. The application scanned using *Acunetix*
> software and it is showing the security alert JSONP enabled by default in
> Please find the below Request and Response headers which is listed by
> Acunetix software
> *Request Header*
> GET /*api/groups/?callback=crldpcnlxk&jsonp=crldpcnlxk&cb=crldpcnlxk&json=crldpcnlxk
> HTTP/1.1*
> Cookie: csrftoken=bYBRus0eSrnR36SeDSU6CJpxx6gmLX1z
> Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
> Accept-Encoding: gzip,deflate
> Host: XXX.XX.X.XXX
> User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36
> (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36
> Connection: Keep-alive
> *Response Header*
> HTTP/1.1 200 OK
> Date: Tue, 13 Aug 2019 10:43:50 GMT
> Server: Apache
> Vary: Accept,Accept-Language,Cookie,Accept-Encoding
> X-Frame-Options: SAMEORIGIN
> Content-Language: en
> Cache-Control: no-cache
> Cache-Control: max-age=300
> Expires: Tue, 13 Aug 2019 10:48:50 GMT
> Content-Length: 113
> Keep-Alive: timeout=100, max=65
> Connection: Keep-Alive
> Content-Type: text/javascript
> Original-Content-Encoding: gzip
> *crldpcnlxk({"meta": {"limit": 10, "next": null, "offset": 0, "previous":
> null, "total_count": 0}, "objects": []})*
> Is any thing related to GeoServer ( As it is written in java and spring
> framework is used)?
> *The alert is coming when it is sending the requests to /api/base or
> /api/groups. Is there any way we can block when request to api comes with
> callback function as argument(specifically jsonp). *
> *If we remove JSONP from the request,will the issue resolve? But what is
> dependency with GeoNode.*
> Kindly help me to resolve above mentioned security related alert.
> Thanks&Regards,
> Naresh.N
> On Tue, Aug 13, 2019 at 1:10 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Dear Naresh,
>> I got the occasion to look a bit to this, but I'm pretty sure your
>> software is giving you a false flag.
>> First of all GeoNode is not using Spring, therefore the solution you
>> propose makes no sense.
>> Secondly I tried the api url by trying several jsonp callbacks and got no
>> issues.
>> If you can possibly provide more information on the issue you are
>> currently experiencing, or at least describe better how to reproduce it,
>> I'll try to dig more into it.
>> Kind regards,
>> Alessio.
>> Il giorno mar 13 ago 2019 alle ore 06:18 Naresh N <naresh919 at gmail.com>
>> ha scritto:
>>> Dear Alessio,
>>> Thanks a lot. Please help me to resolve.
>>> Best Regards,
>>> Naresh.N
>>> On Mon, Aug 12, 2019 at 7:20 PM Alessio Fabiani <
>>>> Hello Naresh,
>>>> thanks for the feedback. Let me double check and try to fix it
>>>> accordingly.
>>>> Will send you updates as soon as possible. Regards.
>>>> Il giorno mer 7 ago 2019 alle ore 11:38 Naresh N <naresh919 at gmail.com>
>>>> ha scritto:
>>>>> Dear All,
>>>>> We have used GeoNode for development of our portal SUVIDHA. As a
>>>>> part of security check scanned our SUVIDHA portal for vulnerabilities ,
>>>>> it is showing following security alert
>>>>> * J**SONP enabled by default in MappingJackson2JsonView *
>>>>> *Reported request header is as follows*
>>>>> GET
>>>>> /api/profiles/?callback=kdeltofpmt&jsonp=kdeltofpmt&cb=kdeltofpmt&json=kdeltofpmt
>>>>> HTTP/1.1 Cookie: csrftoken=NuHnIHPRdzkH6pyi1XmrWpx6Z0v60gsW Accept:
>>>>> Accept-Encoding: gzip,deflate Host: 172.26.3.222 User-Agent: Mozilla/5.0
>>>>> (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko)
>>>>> Chrome/73.0.3683.103 Safari/537.36 Connection: Keep-alive
>>>>> How do I need to fix above?
>>>>> *It recommendation to fix is mentioned in the following link*
>>>>> https://www.acunetix.com/vulnerabilities/web/jsonp-enabled-by-default-in-mappingjackson2jsonview/
>>>>> Please help me how do find this module in GeoNode and how to fix ?.
>>>>> Please do the needful.
>>>>> Thanks & Regards,
>>>>> Naresh.N
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax: +39 0584 1660272
>>>> mob: +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190819/91cee9c7/attachment-0001.html>
More information about the geonode-devel
