[GeoNode-devel] Reg: Use of httponly flag for cookie in GeoNode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Aug 20 05:04:30 PDT 2019
Any chance to send a Pull Request to GeoNode along with the issue
description?
Il giorno mar 20 ago 2019 alle ore 13:05 Naresh N <naresh919 at gmail.com> ha
scritto:
> Dear All,
> I could able to resolve the issue. The following changes are done.
> 1. Settings.py * CSRF_COOKIE_HTTPONLY=True*
> *2.* In following files *X-CSRFToken* value is assigned using the var
> csrftoken = jQuery("[name=csrfmiddlewaretoken]").val();
> a./usr/lib/python2.7/site-packages/autocomplete_light/templates/autocomplete_light/_ajax_csrf.html-
> b.. /home/geonode/geonode/static_root/pinax/js/theme.js
> c. ./home/geonode/geonode/static_root/geonode/js/extjs/GeoNode-mixin.js
> d../home/geonode/geonode/static_root/pinax/js/theme.js
> e. /home/geonode/geonode/static_root/geonode/js/utils/util.js
> f. /home/geonode/geonode/static_root/geonode/js/extjs/GeoNode-mixin.js
> Thanks&Regards,
> Naresh.N
> On Mon, Aug 19, 2019 at 3:05 PM Naresh N <naresh919 at gmail.com> wrote:
>> Dear all,
>> The following changes are made to enable HTTPOnly flag for cookies
>> 1. In settings.py * CSRF_COOKIE_HTTPONLY=True*
>> 2.* X-CSRFToken* value is set using the jquery -- *var csrftoken =
>> jQuery("[name=csrfmiddlewaretoken]").val();*
>> After doing the above changes layers are not getting upload and showing
>> CSRF validation failed. Please find the attached screenshot with this mail.
>> Kindly help me to fix the issue. Apart from above mentioned places is
>> any other places need changes?
>> Thanks&Regards,
>> Naresh.N
>> On Fri, Aug 16, 2019 at 1:46 PM Naresh N <naresh919 at gmail.com> wrote:
>>> Dear All,
>>> Kindly help on regarding httponly flag for cookie use in GeoNode.
>>> Thanks&Regards,
>>> Naresh.N
>>> On Wed, Aug 14, 2019 at 3:03 PM Naresh N <naresh919 at gmail.com> wrote:
>>>> Dear All,
>>>> We have used GeoNode for development of our portal.
>>>> As a part of security measures,we have to use cookie set with httponly
>>>> flag. I have enabled the flag CSRF_COOKIE_HTTPONLY as true in
>>>> settings.py, then* upload layers* and other *ajax_requsts functions
>>>> are not working.*
>>>> Please suggest how to over come this. Which are all the places need to
>>>> modify the code.
>>>> Thanks&Regards,
>>>> Naresh.N
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190820/4e6b368a/attachment.html>
More information about the geonode-devel
