[GeoNode-devel] Reg: Use of httponly flag for cookie in GeoNode
Naresh N naresh919 at gmail.com
Tue Aug 20 21:47:47 PDT 2019
Dear Alessio,
I have done the changes in my local environment of GeoNode.  Please find
the details below.
*  ISSUE :* *Use of HttpOnly flag for CSRF cookie*
* (i). *Set the flag in Settings.py  * CSRF_COOKIE_HTTPONLY=True*
* (ii) *In the following all files CSRF token value  read from *Cookie code
is commented* and *added the new code* which reads CSRF token value with i*nput
hidden field * name with  *csrfmiddlewaretoken*
*  a.*
/usr/lib/python2.7/site-packages/autocomplete_light/templates/autocomplete_light/_ajax_csrf.html-
  b.. /home/geonode/geonode/static_root/pinax/js/theme.js
  c. ./home/geonode/geonode/static_root/geonode/js/extjs/GeoNode-mixin.js
  d../home/geonode/geonode/static_root/pinax/js/theme.js
  e. /home/geonode/geonode/static_root/geonode/js/utils/util.js
  f. /home/geonode/geonode/static_root/geonode/js/extjs/GeoNode-mixin.js
*The following functions code from above files  is modified  to var
csrftoken = jQuery("[name=csrfmiddlewaretoken]").val(); return csrftoken;*
*getCRSFToken*: function() {
        var csrfToken, csrfMatch = document.cookie.match(/csrftoken=(\w+)/);
        if (csrfMatch && csrfMatch.length > 0) {
            csrfToken = csrfMatch[1];
        return csrfToken;
f*unction getCookie(name)* {
        var cookieValue = null;
      if (document.cookie && document.cookie !== '') {
            var cookies = document.cookie.split(';');
            for (var i = 0; i < cookies.length; i++) {
          var cookie = $.trim(cookies[i]);
                // Does this cookie string begin with the name we want?
                if (cookie.substring(0, name.length + 1) == (name + '=')) {
                    cookieValue =
decodeURIComponent(cookie.substring(name.length + 1));
                    break;
return cookievalue;
Thanks&Regards,
Naresh.n
On Tue, Aug 20, 2019 at 5:34 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Any chance to send a Pull Request to GeoNode along with the issue
> description?
> Il giorno mar 20 ago 2019 alle ore 13:05 Naresh N <naresh919 at gmail.com>
> ha scritto:
>> Dear All,
>> I could able to resolve the issue. The following changes are done.
>> 1. Settings.py  * CSRF_COOKIE_HTTPONLY=True*
>> *2.* In following  files *X-CSRFToken* value is assigned using the  var
>> a./usr/lib/python2.7/site-packages/autocomplete_light/templates/autocomplete_light/_ajax_csrf.html-
>> Thanks&Regards,
>> Naresh.N
>> On Mon, Aug 19, 2019 at 3:05 PM Naresh N <naresh919 at gmail.com> wrote:
>>> Dear all,
>>> The following changes are made to enable HTTPOnly flag for cookies
>>> 1. In settings.py   * CSRF_COOKIE_HTTPONLY=True*
>>> 2.* X-CSRFToken* value is set using the  jquery -- *var csrftoken =
>>> jQuery("[name=csrfmiddlewaretoken]").val();*
>>> After doing the above changes layers are not getting upload and showing
>>> CSRF validation failed. Please find the attached screenshot with this mail.
>>> Kindly  help me to fix the issue. Apart from above mentioned places is
>>> any other places need changes?
>>> Thanks&Regards,
>>> Naresh.N
>>> On Fri, Aug 16, 2019 at 1:46 PM Naresh N <naresh919 at gmail.com> wrote:
>>>> Dear All,
>>>> Kindly help on regarding httponly flag for cookie use in GeoNode.
>>>> Thanks&Regards,
>>>> Naresh.N
>>>> On Wed, Aug 14, 2019 at 3:03 PM Naresh N <naresh919 at gmail.com> wrote:
>>>>> Dear All,
>>>>> We have used GeoNode for development of  our portal.
>>>>> As a part of security measures,we have to use cookie set with
>>>>> httponly  flag.  I have  enabled the flag CSRF_COOKIE_HTTPONLY  as true in
>>>>> settings.py,  then* upload layers* and other *ajax_requsts functions
>>>>> are not working.*
>>>>> Please suggest how to over come this. Which are all the places need to
>>>>> modify the code.
>>>>> Thanks&Regards,
>>>>> Naresh.N
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190821/f8892487/attachment-0001.html>
More information about the geonode-devel mailing list
