[GeoNode-devel] PostGIS version in Docker
Paolo Pasquali
paolo.pasquali at gmail.com
Wed Feb 13 02:08:12 PST 2019
Ok, thanks!
On 13 Feb 2019, 10:49 +0100, Alessio Fabiani <alessio.fabiani at geo-solutions.it>, wrote:
> Hi Paolo,
> I checked this and noticed that the image on docker named "postgis:10" has not been created.
> I have triggered the build. It should be available in few minutes.
> > Il giorno mer 13 feb 2019 alle ore 10:43 Paolo Pasquali <paolo.pasquali at gmail.com> ha scritto:
> > > Dear all,
> > > In GeoNode the docker-compose.yml file was recently updated to use PostgreSQL 10 [1]. The GeoNode project instead still relies on 9.6 [2].
> > > I have tried to update the docker-compose.yml file in the GeoNode project to match the GeoNode version but I get:
> > > Pulling db (geonode/postgis:10)...
> > > ERROR: manifest for geonode/postgis:10 not found
> > > Is it version 10 available?
> > > Thanks.
> > > Best,
> > > Paolo
> > > [1] https://github.com/GeoNode/geonode/blob/master/docker-compose.yml#L5
> > > [2] https://github.com/GeoNode/geonode-project/blob/master/docker-compose.yml#L5
> > > _______________________________________________
> > > geonode-devel mailing list
> > > geonode-devel at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190213/c6e53074/attachment-0001.html>
More information about the geonode-devel
