[GeoNode-devel] Test cases mandatory for PRs affecting GeoNode core
Alessio Fabiani alessio.fabiani at gmail.com
Thu Feb 14 06:14:11 PST 2019
Dear devs,
due to recent blocker "regressions" introduced after merging some PRs to
GeoNode core, from now on PRs affecting and/or modifying the latter *must *be
either:
1. Linked to an issue well describing the problem/improvement
2. Contain test-cases demonstrating the new changes will work correctly
Other than this, "contrib" apps very old/outdated and/or without a
maintainer, will be removed (after having discussed that on the mailing
list) in order to clean up and lighten the GeoNode code base.
Regards,
Alessio Fabiani.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190214/1b778c36/attachment.html>
More information about the geonode-devel mailing list
