[GeoNode-devel] Test cases mandatory for PRs affecting GeoNode core
Francesco Bartoli
xbartolone at gmail.com
Thu Feb 14 06:31:19 PST 2019
Definitively +1 I would also propose to use the budget from OSGeo to improve e2e tests, CI and CD
Il 14 feb 2019, 15:14 +0100, Alessio Fabiani <alessio.fabiani at gmail.com>, ha scritto:
> Dear devs,
> due to recent blocker "regressions" introduced after merging some PRs to GeoNode core, from now on PRs affecting and/or modifying the latter must be either:
> 1. Linked to an issue well describing the problem/improvement
> 2. Contain test-cases demonstrating the new changes will work correctly
> Other than this, "contrib" apps very old/outdated and/or without a maintainer, will be removed (after having discussed that on the mailing list) in order to clean up and lighten the GeoNode code base.
> Regards,
> Alessio Fabiani.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190214/c809aed2/attachment.html>
More information about the geonode-devel
