[GeoNode-devel] Test cases mandatory for PRs affecting GeoNode core
Simone Giannecchini
simone.giannecchini at geo-solutions.it
Thu Feb 14 06:51:53 PST 2019
I would rephrase *must be either* to *must be both* and rejecting
anything that does not comply, no matter who is proposing it.
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Thu, Feb 14, 2019 at 3:14 PM Alessio Fabiani
<alessio.fabiani at gmail.com> wrote:
> Dear devs,
> due to recent blocker "regressions" introduced after merging some PRs to GeoNode core, from now on PRs affecting and/or modifying the latter must be either:
> 1. Linked to an issue well describing the problem/improvement
> 2. Contain test-cases demonstrating the new changes will work correctly
> Other than this, "contrib" apps very old/outdated and/or without a maintainer, will be removed (after having discussed that on the mailing list) in order to clean up and lighten the GeoNode code base.
> Regards,
> Alessio Fabiani.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel
