[GeoNode-devel] Geonode in vagrant
Pieter du Plooy
pjduplooy.gis at gmail.com
Thu Feb 14 07:16:40 PST 2019
Toni
If I use the ip address as is in the vagrant file, what vars do you
recommend I change?
On Thu, Feb 14, 2019 at 1:11 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Pieter,
> the workflow is like this:
> 1) Spin a plain vagrantbox from Ubuntu base box
> https://gist.github.com/t-book/7bafe00d0e0ca1be5669ecbf5e0d6e84
> $ vagrant up
> $ vagrant ssh
> $ sudo apt install python
> 2) install ansible on your host
> 3) clone the ansible repository I´ve sent
> 4) adjust the vars as explained in the readme
> https://github.com/csgis/geonode_ansible#installing
> 5) Run the playbook with: $ ansible-playbook -v -i hosts site.yml
> Voila ansible should install geonode 2.10 at your vanilla vagrant box ;)
> Best regards,
> Toni
> Am 14.02.2019 um 11:57 schrieb Pieter du Plooy <pjduplooy.gis at gmail.com>:
> Toni
> Can I use ansible inside a vagrant box?
> On Thu, Feb 14, 2019 at 12:41 PM Pieter du Plooy <pjduplooy.gis at gmail.com>
> wrote:
>> Hi Toni
>> A video would be much appreciated.
>> On Thu, Feb 14, 2019 at 11:27 AM Toni Schönbuchner <
>>> Dear Pieter,
>>> I´m currently on travel but can share a vagrant box next week when back
>>> in office.
>>> Is it possible that you might have a documentation set that I can print
>>> and then follow from there?(I follow that better). I want to see why
>>> things are done in a certain way.
>>> Well this should be covered by documentations. Unfortuantely it´s a bit
>>> outdated.
>>> A rework is on my list for a long time. Until then you´re welcome to ask
>>> why something is
>>> happening when.
>>> Your guidance would be appreciated. (On a side note I have been using
>>> your vagrant box since you pushed it to Vagrant Cloud. I also prefer
>>> Vagrant over Docker, since I feel I have more control, and can then
>>> experiment more).
>>> But the time has now come for me to build a box by myself, so your
>>> guidance will be appreciated.
>>> +1
>>> The ansible playbook I´ve sent will do exactly that. You can spin your
>>> vagrant box from
>>> ubuntu image. Configure vars like IP, user etc and ansible will run all
>>> needed commands.
>>> The nice part about it is that they stay very close to the official
>>> docs. It should be easy
>>> to understand the ansible tasks also knowing nothing about it. If you
>>> want I can
>>> share a video guiding you through relevant steps.
>>> Cheers,
>>> Toni
>>> Am 14.02.2019 um 03:39 schrieb Pieter du Plooy <pjduplooy.gis at gmail.com
>>> Thanks Toni
>>> Would be much appreciated.
>>> I was trying to follow your Geonode 2.8 vagrant video, but am struggling
>>> to jump between pausing the video, and then actually following the tasks
>>> (Just a personal issue).
>>> experiment more).
>>> Pieter
>>> On Wed, Feb 13, 2019 at 10:10 PM Toni Schönbuchner <
>>>> Dear Pieter,
>>>> for 2.10 on 16.04 you could just use the master branch (ansible) for
>>>> installation
>>>> https://github.com/csgis/geonode_ansible/tree/master
>>>> For 2.10 on bionic:
>>>> https://github.com/csgis/geonode_ansible/tree/bionic
>>>> In case of questions I´m happy to guide you.
>>>> And yes of course I would be prepared to push a box to
>>>> vagrant cloud as well ;)
>>>> Cheers,
>>>> Toni
>>>> Am 13.02.2019 um 21:00 schrieb geonode-devel-request at lists.osgeo.org:
>>>> Message: 2
>>>> Date: Wed, 13 Feb 2019 17:40:59 +0200
>>>> From: Pieter du Plooy <pjduplooy.gis at gmail.com>
>>>> To: geonode-devel at lists.osgeo.org
>>>> Subject: [GeoNode-devel] Geonode in vagrant
>>>> Message-ID:
>>>> <CADsUavHt8_z6G2mN44DT_XFoKShw2-br7-NyE-d1qdyGSbZyqg at mail.gmail.com>
>>>> Content-Type: text/plain; charset="utf-8"
>>>> Hi guys
>>>> I would like to ask if Toni is prepared to update the Vagrant box to
>>>> have
>>>> Geonode 2.10?
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190214/1eb644ca/attachment-0001.html>
More information about the geonode-devel
