[GeoNode-devel] Custom geonode project installation
Dimitris Kar dkarakostis at gmail.com
Wed Jan 2 07:07:49 PST 2019
Hey Francesco!
I thought the same but after changing the permissions on the folder and
running again the paver setup, this time everything is installed correctly
without any errors:
Writing to /home/ubuntu/Envs/wfp_geonode/src/geonode/geonode/GeoIPCities.dat
GeoNode development environment successfully set up.If you have not set up
an administrative account, please do so now. Use "paver start" to start up
the server.
But when I execute the paver sync and paver start, I receive again the same
errors as before.
On Wed, Jan 2, 2019 at 3:36 PM francesco bartoli <xbartolone at gmail.com>
wrote:
> Hi Dimitri,
> think the issue here is generated from the reported error "IOError: [Errno
> 13] Permission denied: '/usr/local/share/GeoIP'"
> Can you check if your user has write permissions on '/usr/local/share'?
> Anyway think you are using  local_settings where this variable is defined
> at global system level
> https://github.com/GeoNode/geonode/blob/f4d067fe623a4952c2b7b7db26cd2111a557c623/package/support/geonode.local_settings#L522
> If you override that variable then the issue should go away.
> Francesco
> Il giorno mer 2 gen 2019 alle ore 15:20 Dimitris Kar <
> dkarakostis at gmail.com> ha scritto:
>> Hey Toni,
>> Yes. Actually when I execute the paver setup (as above), I get:
>> IOError: [Errno 13] Permission denied: '/usr/local/share/GeoIP'
>> up an administrative account, please do so now. Use "paver start" to start
>> up the server.
>> And then when I run the paver sync or the paver start (as in the
>> instructions), I get:
>> django.db.utils.OperationalError: could not connect to server: Connection
>> refused
>>     Is the server running on host "localhost" (127.0.0.1) and accepting
>>     TCP/IP connections on port 5432?
>> GeoNode is now available. "
>> I am running the installation in a virtual environment inside a vagrant
>> VM (ubuntu/xenial64). I thought it could be related with the port
>> forwarding but that seems to be configured ok in the vagrantfile:
>>   config.vm.network :forwarded_port, guest: 5432, host: 5432
>> I also tried to check the configuration in the pg_config file but I can
>> not find out where my postgres is installed. I run: which psql but there is
>> no output.
>> Have you faced this issue before?
>> On a different note, the installation comes with jetty server right?
>> On Wed, Jan 2, 2019 at 1:27 PM Toni Schönbuchner <
>> toni.schoenbuchner at csgis.de> wrote:
>>> Hi Dimitris,
>>> have you run
>>> DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver setup
>>> this should download and create geoserver dependencies.
>>> Cheers,
>>> Toni
>>> CSGIS
>>> Kolonnadenstraße 1
>>> 04109 Leipzig
>>> Mobil +49/ (0) 176 6680 3198
>>> Tel  +49/ (0) 341 24 04 738
>>> Fax  +49/ (0) 341 24 04 73
>>> Web http://csgis.de
>>> Hinweis gemäß § 33 BDSG
>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>> ausschließlich für den
>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>> diese E-Mail versehentlich
>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>> löschen Sie diese Nachricht
>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>> Vervielfältigung, Veränderung,
>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> Am 02.01.2019 um 11:56 schrieb Dimitris Kar <dkarakostis at gmail.com>:
>>> Hello Toni,
>>> At last I found some time to try your instructions for installing the
>>> geonode-project. Everything was installed successfully but when I try to
>>> execute the paver commands I get certain errors.
>>> More specifically - after enabling the local_settings -  when I run:
>>> DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
>>> I get
>>> ---> pavement.start
>>> ---> pavement.start_geoserver
>>> cd /vagrant/wfp_geonode/geoserver/data
>>> Captured Task Output:
>>> ---> pavement.start
>>> Traceback (most recent call last):
>>>   File
>>> "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/tasks.py",
>>> line 196, in _run_task
>>>     return do_task()
>>>   File
>>> line 192, in do_task
>>>     task()
>>>   File
>>> line 321, in __call__
>>>     retval = environment._run_task(self.name, self.needs, self.func)
>>>   File
>>> line 214, in _run_task
>>>     return do_task()
>>>   File
>>> line 193, in do_task
>>>     return func(**kw)
>>>   File "pavement.py", line 667, in start_geoserver
>>>     with pushd(data_dir):
>>>   File "/usr/lib/python2.7/contextlib.py", line 17, in __enter__
>>>     return self.gen.next()
>>>   File
>>> "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/path.py",
>>> line 39, in pushd
>>>     os.chdir(dir)
>>> OSError: [Errno 2] No such file or directory:
>>> '/vagrant/wfp_geonode/geoserver/data'
>>> It seems like it can not find the geoserver folder. And in fact there is
>>> no geoserver folder under the wfp_geonode installation:
>>> dev_config.yml               Dockerfile      jetty-runner.xml  *package*
>>> /      README.rst        setup.py   wait-for-databases.sh
>>> docker-compose.override.yml  *entrypoint.sh**  Makefile          pavement.py
>>>   requirements.txt  tasks.py   *wfp_geonode*/
>>> docker-compose.yml           *fixtures*/       *manage.py**
>>> playbook.yml  *scripts*/          uwsgi.ini  *wfp_geonode.egg-info*/
>>> Do you have any clue, what could be the problem?
>>> On Wed, Dec 19, 2018 at 5:27 PM Toni Schönbuchner <
>>>> Hi Dimitris,
>>>> it sounds you´re a bit puzzled between 'geonode core‘ and
>>>> geonode-project.
>>>> To understand better see whats happening with geonode-project:
>>>> It installs `geonode core` as dependency:
>>>> https://github.com/GeoNode/geonode-project/blob/master/requirements.txt#L2
>>>> further loads/overwrites it´s settings:
>>>> https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L30
>>>> Doing so we can overwrite things like templates etc. in Geonode-Project
>>>> without touching
>>>> core files.
>>>> As a rule of thumb, if you´d like to commit changes to geonode core,
>>>> create a fork of the upstream
>>>> repository, do your changes and create a PR.
>>>> I think in your case – as you´d like to modify *your* specific version
>>>> – start by creating a geonode
>>>> project as described here (and ignore the first 'geonode core' dev
>>>> setup):
>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project
>>>> I hope I did not misunderstood your question.
>>>> Happy geonod’ ing.
>>>> – Toni
>>>> CSGIS
>>>> Kolonnadenstraße 1
>>>> 04109 Leipzig
>>>> Web http://csgis.de
>>>> Message: 1
>>>> Date: Wed, 19 Dec 2018 16:57:16 +0100
>>>> From: Dimitris Kar <dkarakostis at gmail.com>
>>>> To: geonode-devel <geonode-devel at lists.osgeo.org>
>>>> Subject: [GeoNode-devel] Custom geonode project installation
>>>> Message-ID:
>>>> <CAH4UFc99H4OuAxKUc+FhFZ=13gSJZDdMnH7Lj1=ec49Qg+6sgA at mail.gmail.com>
>>>> Content-Type: text/plain; charset="utf-8"
>>>> Hello all,
>>>> I am trying following the instructions from this workshop (
>>>> http://geonode.org/dev-workshop/#/2) in order to install GeoNode and a
>>>> GeoNode project. I have installed GeoNode in dev mode using a python
>>>> virtualenv + django development server method.
>>>> Then I follow the instructions in order to create a geonode-project as
>>>> following:
>>>>   1. cd ./geonode
>>>>   2. django-admin.py startproject wfp_geonode --template=
>>>>   https://github.com/GeoNode/geonode-project/archive/master.zip -e
>>>>   py,rst,json,yml,ini,env,sample -n Dockerfile wfp_geonode  (I executed
>>>>   this command without includong: -n Dockerfile wfp_geonode)
>>>>   3. workon geonode
>>>>   4. cd wfp_geonode
>>>>   5. pip install -e wfp_geonode
>>>>   6. cd ../geonode
>>>>   7. DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
>>>> But when I actually run the command, I get the below command. If I am
>>>> not
>>>> wrong, I remember, that I can not use geonode-project aside with a
>>>> geonode
>>>> dev installation but this is not quite clear in the above workshop
>>>> presentation (see above link).
>>>> Did anyone had similar issues? Should I install a geonode for production
>>>> and use the geonode-project then?
>> geonode-devel mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190102/55dd5e9f/attachment-0001.html>
More information about the geonode-devel mailing list
