[GeoNode-devel] Custom geonode project installation
Francesco Bartoli
xbartolone at gmail.com
Wed Jan 2 07:36:47 PST 2019
Try to set the variable GEOIP_PATH in your settings
Il 2 gen 2019, 16:08 +0100, Dimitris Kar <dkarakostis at gmail.com>, ha scritto:
> Hey Francesco!
> I thought the same but after changing the permissions on the folder and running again the paver setup, this time everything is installed correctly without any errors:
> Writing to /home/ubuntu/Envs/wfp_geonode/src/geonode/geonode/GeoIPCities.dat
> GeoNode development environment successfully set up.If you have not set up an administrative account, please do so now. Use "paver start" to start up the server.
> But when I execute the paver sync and paver start, I receive again the same errors as before.
> > On Wed, Jan 2, 2019 at 3:36 PM francesco bartoli <xbartolone at gmail.com> wrote:
> > > Hi Dimitri,
> > > think the issue here is generated from the reported error "IOError: [Errno 13] Permission denied: '/usr/local/share/GeoIP'"
> > > Can you check if your user has write permissions on '/usr/local/share'? Anyway think you are using local_settings where this variable is defined at global system level https://github.com/GeoNode/geonode/blob/f4d067fe623a4952c2b7b7db26cd2111a557c623/package/support/geonode.local_settings#L522.
> > > If you override that variable then the issue should go away.
> > > Francesco
> > > > Il giorno mer 2 gen 2019 alle ore 15:20 Dimitris Kar <dkarakostis at gmail.com> ha scritto:
> > > > > Hey Toni,
> > > > > Yes. Actually when I execute the paver setup (as above), I get:
> > > > > And then when I run the paver sync or the paver start (as in the instructions), I get:
> > > > > django.db.utils.OperationalError: could not connect to server: Connection refused
> > > > > Is the server running on host "localhost" (127.0.0.1) and accepting
> > > > > TCP/IP connections on port 5432?
> > > > > GeoNode is now available. "
> > > > > I am running the installation in a virtual environment inside a vagrant VM (ubuntu/xenial64). I thought it could be related with the port forwarding but that seems to be configured ok in the vagrantfile:
> > > > > config.vm.network :forwarded_port, guest: 5432, host: 5432
> > > > > I also tried to check the configuration in the pg_config file but I can not find out where my postgres is installed. I run: which psql but there is no output.
> > > > > Have you faced this issue before?
> > > > > On a different note, the installation comes with jetty server right?
> > > > > > On Wed, Jan 2, 2019 at 1:27 PM Toni Schönbuchner <toni.schoenbuchner at csgis.de> wrote:
> > > > > > > Hi Dimitris,
> > > > > > > have you run
> > > > > > > DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver setup
> > > > > > > this should download and create geoserver dependencies.
> > > > > > > Cheers,
> > > > > > > Toni
> > > > > > > CSGIS
> > > > > > > Kolonnadenstraße 1
> > > > > > > 04109 Leipzig
> > > > > > > Mobil +49/ (0) 176 6680 3198
> > > > > > > Tel +49/ (0) 341 24 04 738
> > > > > > > Fax +49/ (0) 341 24 04 73
> > > > > > > Web http://csgis.de
> > > > > > > Hinweis gemäß § 33 BDSG
> > > > > > > Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
> > > > > > > Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
> > > > > > > erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
> > > > > > > von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
> > > > > > > Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> > > > > > > > Am 02.01.2019 um 11:56 schrieb Dimitris Kar <dkarakostis at gmail.com>:
> > > > > > > > Hello Toni,
> > > > > > > > At last I found some time to try your instructions for installing the geonode-project. Everything was installed successfully but when I try to execute the paver commands I get certain errors.
> > > > > > > > More specifically - after enabling the local_settings - when I run:
> > > > > > > > DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
> > > > > > > > I get
> > > > > > > > ---> pavement.start
> > > > > > > > ---> pavement.start_geoserver
> > > > > > > > cd /vagrant/wfp_geonode/geoserver/data
> > > > > > > > Captured Task Output:
> > > > > > > > ---> pavement.start
> > > > > > > > Traceback (most recent call last):
> > > > > > > > File "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/tasks.py", line 196, in _run_task
> > > > > > > > return do_task()
> > > > > > > > File "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/tasks.py", line 192, in do_task
> > > > > > > > task()
> > > > > > > > File "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/tasks.py", line 321, in __call__
> > > > > > > > retval = environment._run_task(self.name, self.needs, self.func)
> > > > > > > > File "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/tasks.py", line 214, in _run_task
> > > > > > > > return do_task()
> > > > > > > > File "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/tasks.py", line 193, in do_task
> > > > > > > > return func(**kw)
> > > > > > > > File "pavement.py", line 667, in start_geoserver
> > > > > > > > with pushd(data_dir):
> > > > > > > > File "/usr/lib/python2.7/contextlib.py", line 17, in __enter__
> > > > > > > > return self.gen.next()
> > > > > > > > File "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/path.py", line 39, in pushd
> > > > > > > > os.chdir(dir)
> > > > > > > > OSError: [Errno 2] No such file or directory: '/vagrant/wfp_geonode/geoserver/data'
> > > > > > > > It seems like it can not find the geoserver folder. And in fact there is no geoserver folder under the wfp_geonode installation:
> > > > > > > > dev_config.yml Dockerfile jetty-runner.xml package/ README.rst setup.py wait-for-databases.sh
> > > > > > > > docker-compose.override.yml entrypoint.sh* Makefile pavement.py requirements.txt tasks.py wfp_geonode/
> > > > > > > > docker-compose.yml fixtures/ manage.py* playbook.yml scripts/ uwsgi.ini wfp_geonode.egg-info/
> > > > > > > > Do you have any clue, what could be the problem?
> > > > > > > > > On Wed, Dec 19, 2018 at 5:27 PM Toni Schönbuchner <toni.schoenbuchner at csgis.de> wrote:
> > > > > > > > > > Hi Dimitris,
> > > > > > > > > > it sounds you´re a bit puzzled between 'geonode core‘ and geonode-project.
> > > > > > > > > > To understand better see whats happening with geonode-project:
> > > > > > > > > > It installs `geonode core` as dependency:
> > > > > > > > > > https://github.com/GeoNode/geonode-project/blob/master/requirements.txt#L2
> > > > > > > > > > further loads/overwrites it´s settings:
> > > > > > > > > > https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L30
> > > > > > > > > > Doing so we can overwrite things like templates etc. in Geonode-Project without touching
> > > > > > > > > > core files.
> > > > > > > > > > As a rule of thumb, if you´d like to commit changes to geonode core, create a fork of the upstream
> > > > > > > > > > repository, do your changes and create a PR.
> > > > > > > > > > I think in your case – as you´d like to modify your specific version – start by creating a geonode
> > > > > > > > > > project as described here (and ignore the first 'geonode core' dev setup):
> > > > > > > > > > https://github.com/GeoNode/geonode-project#create-a-custom-project
> > > > > > > > > > I hope I did not misunderstood your question.
> > > > > > > > > > Happy geonod’ ing.
> > > > > > > > > > – Toni
> > > > > > > > > > CSGIS
> > > > > > > > > > Kolonnadenstraße 1
> > > > > > > > > > 04109 Leipzig
> > > > > > > > > > Web http://csgis.de
> > > > > > > > > > > Message: 1
> > > > > > > > > > > Date: Wed, 19 Dec 2018 16:57:16 +0100
> > > > > > > > > > > From: Dimitris Kar <dkarakostis at gmail.com>
> > > > > > > > > > > To: geonode-devel <geonode-devel at lists.osgeo.org>
> > > > > > > > > > > Subject: [GeoNode-devel] Custom geonode project installation
> > > > > > > > > > > Message-ID:
> > > > > > > > > > > <CAH4UFc99H4OuAxKUc+FhFZ=13gSJZDdMnH7Lj1=ec49Qg+6sgA at mail.gmail.com>
> > > > > > > > > > > Content-Type: text/plain; charset="utf-8"
> > > > > > > > > > > Hello all,
> > > > > > > > > > > I am trying following the instructions from this workshop (
> > > > > > > > > > > http://geonode.org/dev-workshop/#/2) in order to install GeoNode and a
> > > > > > > > > > > GeoNode project. I have installed GeoNode in dev mode using a python
> > > > > > > > > > > virtualenv + django development server method.
> > > > > > > > > > > Then I follow the instructions in order to create a geonode-project as
> > > > > > > > > > > following:
> > > > > > > > > > > 1. cd ./geonode
> > > > > > > > > > > 2. django-admin.py startproject wfp_geonode --template=
> > > > > > > > > > > https://github.com/GeoNode/geonode-project/archive/master.zip -e
> > > > > > > > > > > py,rst,json,yml,ini,env,sample -n Dockerfile wfp_geonode (I executed
> > > > > > > > > > > this command without includong: -n Dockerfile wfp_geonode)
> > > > > > > > > > > 3. workon geonode
> > > > > > > > > > > 4. cd wfp_geonode
> > > > > > > > > > > 5. pip install -e wfp_geonode
> > > > > > > > > > > 6. cd ../geonode
> > > > > > > > > > > 7. DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
> > > > > > > > > > > But when I actually run the command, I get the below command. If I am not
> > > > > > > > > > > wrong, I remember, that I can not use geonode-project aside with a geonode
> > > > > > > > > > > dev installation but this is not quite clear in the above workshop
> > > > > > > > > > > presentation (see above link).
> > > > > > > > > > > Did anyone had similar issues? Should I install a geonode for production
> > > > > > > > > > > and use the geonode-project then?
> > > > > _______________________________________________
> > > > > geonode-devel mailing list
> > > > > https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190102/920ebaf6/attachment-0001.html>
More information about the geonode-devel
