[GeoNode-devel] Custom geonode project installation
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Wed Jan 2 09:43:21 PST 2019
Hi Dimitris,
let me recap:
> IOError: [Errno 13] Permission denied: '/usr/local/share/GeoIP'
This was solved by settings permissions of /usr/local/share
> And then when I run the paver sync or the paver start (as in the instructions), I get:
> django.db.utils.OperationalError: could not connect to server: Connection refused
> Is the server running on host "localhost" (127.0.0.1) and accepting
> TCP/IP connections on port 5432?
Note, with dev setup there is neither tomcat nor postgresql involved.
GeoServer is run by use of Jetty. Instead of Postgresql Setup we´re using
Sqlite.
So the error is here:
DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings
You´re using local_settings which expects a running postgresql server.
https://github.com/GeoNode/geonode-project/blob/master/project_name/local_settings.py.sample#L88
Try:
DJANGO_SETTINGS_MODULE=wfp_geonode.settings
(settings instead of local_settings) instead.
> I am running the installation in a virtual environment inside a vagrant VM (ubuntu/xenial64). I thought it could be related with the port forwarding but that seems to be configured ok in the vagrantfile:
> config.vm.network :forwarded_port, guest: 5432, host: 5432
This is totally fine. It would only matter when running in production.
(Sqlite should not care about the port, in production I would further close 5432 and
only connect by local_tunnel to postgres)
> I also tried to check the configuration in the pg_config file but I can not find out where my postgres is installed. I run: which psql but there is no output.
Also only relevant with production setup. ;)
> On a different note, the installation comes with jetty server right?
See above.
As summary. You can use the dev setup with with django-dev-server, jetty and sqlite to quickly
setup a environment for development. Going to production is much more complex as the different
parts have to be configured. ( The docs explain how (a bit outdated but working.) I´ve created a little
ansible playbook which automates those steps: https://github.com/csgis/geonode_ansible <https://github.com/csgis/geonode_ansible> )
Hope this helps,
Toni
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190102/a7ed0dba/attachment.html>
More information about the geonode-devel
