[GeoNode-devel] Custom geonode project installation
Dimitris Kar
dkarakostis at gmail.com
Fri Jan 4 00:29:59 PST 2019
Hello Toni,
Thanks for the answer. After reinstalling everything in a fresh VM,
everything runs fine. I also made some tests editing the templates and
creating a contrib app and everything seems to be working. I am aware that
when using the geonode-project, its not recommended to edit/change the
geonode core but I was curious to try that. For some reason though when I
do minor changes on templates (/Envs/geonode/src/geonode), they are not
applied. Are you aware if this is the expected behavior?
Also I have checked your video on vimeo (
https://vimeo.com/278003647#t=37m37s). Great documentation!
On Wed, Jan 2, 2019 at 6:43 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hi Dimitris,
> let me recap:
> IOError: [Errno 13] Permission denied: '/usr/local/share/GeoIP'
> This was solved by settings permissions of /usr/local/share
> And then when I run the paver sync or the paver start (as in the
> instructions), I get:
> django.db.utils.OperationalError: could not connect to server: Connection
> refused
> Is the server running on host "localhost" (127.0.0.1) and accepting
> TCP/IP connections on port 5432?
> Note, with dev setup there is neither tomcat nor postgresql involved.
> GeoServer is run by use of Jetty. Instead of Postgresql Setup we´re using
> Sqlite.
> So the error is here:
> DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings
> You´re using local_settings which expects a running postgresql server.
> https://github.com/GeoNode/geonode-project/blob/master/project_name/local_settings.py.sample#L88
> Try:
> DJANGO_SETTINGS_MODULE=wfp_geonode.settings
> (settings instead of local_settings) instead.
> I am running the installation in a virtual environment inside a vagrant VM
> (ubuntu/xenial64). I thought it could be related with the port forwarding
> but that seems to be configured ok in the vagrantfile:
> config.vm.network :forwarded_port, guest: 5432, host: 5432
> This is totally fine. It would only matter when running in production.
> (Sqlite should not care about the port, in production I would further
> close 5432 and
> only connect by local_tunnel to postgres)
> I also tried to check the configuration in the pg_config file but I can
> not find out where my postgres is installed. I run: which psql but there is
> no output.
> Also only relevant with production setup. ;)
> On a different note, the installation comes with jetty server right?
> See above.
> As summary. You can use the dev setup with with django-dev-server, jetty
> and sqlite to quickly
> setup a environment for development. Going to production is much more
> complex as the different
> parts have to be configured. ( The docs explain how (a bit outdated but
> working.) I´ve created a little
> ansible playbook which automates those steps:
> https://github.com/csgis/geonode_ansible )
> Hope this helps,
> Toni
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190104/77ba4cbc/attachment.html>
More information about the geonode-devel
