[GeoNode-devel] New Issue #4153: GeoLite Legacy db discontinued so paver setup fails in Geonode 2.8 dev install
Francesco Bartoli
xbartolone at gmail.com
Fri Jan 11 02:27:12 PST 2019
Alessio, I think the easiest would be to host the .dat file as an artifact along with other files like .war etc., what do you think?
Il 11 gen 2019, 09:45 +0100, Alessio Fabiani <alessio.fabiani at geo-solutions.it>, ha scritto:
> Many thanks Jonathan,
> will take a look asap.
> Alessio.
> > Il giorno ven 11 gen 2019 alle ore 09:26 Jonathan Doig <j.doig at unsw.edu.au> ha scritto:
> > > Hi devs and Happy New Year
> > > Maxmind has discontinued GeoLite Legacy database support as of Jan 2nd 2019.
> > > That causes paver setup to fail when installing Geonode 2.8 dev in Finalize GeoNode Setup & Test.
> > > This is because updategeoip.py expects to use geoip2 to handle the new GeoLite2 database, but geoip2 is only available from Django 1.9, not in Django 1.8 as used by Geonode 2.8.
> > > I’ve raised this as issue 4153.
> > > Regards
> > > Jonathan
> > > CityData: Store, discover and share – data for city analytics and decision-making
> > > _______________________________________________
> > > geonode-devel mailing list
> > > geonode-devel at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190111/ee200fbd/attachment.html>
More information about the geonode-devel
