[GeoNode-devel] New Issue #4153: GeoLite Legacy db discontinued so paver setup fails in Geonode 2.8 dev install
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jan 11 00:44:47 PST 2019
Many thanks Jonathan,
will take a look asap.
Alessio.
Il giorno ven 11 gen 2019 alle ore 09:26 Jonathan Doig <j.doig at unsw.edu.au>
ha scritto:
> Hi devs and Happy New Year
> Maxmind has discontinued
> <https://blog.maxmind.com/2018/01/02/discontinuation-of-the-geolite-legacy-databases/> GeoLite
> Legacy database support as of Jan 2nd 2019.
> That causes paver setup to fail when installing Geonode 2.8 dev in Finalize
> GeoNode Setup & Test
> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html#finalize-geonode-setup-test>
> This is because updategeoip.py expects
> <https://github.com/GeoNode/geonode/blob/master/geonode/base/management/commands/updategeoip.py#L34> to
> use geoip2 to handle the new GeoLite2 database, but geoip2 is only
> available from Django 1.9, not in Django 1.8 as used by Geonode 2.8.
> I’ve raised this as issue 4153
> <https://github.com/GeoNode/geonode/issues/4153>.
> Regards
> Jonathan
> *CityData <https://citydata.be.unsw.edu.au/>*: *Store, discover and share
> – data for city analytics and decision-making*
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190111/4c57fb4e/attachment-0001.html>
More information about the geonode-devel mailing list
