[GeoNode-devel] New Issue #4153: GeoLite Legacy db discontinued so paver setup fails in Geonode 2.8 dev install
Jonathan Doig
j.doig at unsw.edu.au
Fri Jan 11 00:14:29 PST 2019
Hi devs and Happy New Year
Maxmind has discontinued<https://blog.maxmind.com/2018/01/02/discontinuation-of-the-geolite-legacy-databases/> GeoLite Legacy database support as of Jan 2nd 2019.
That causes paver setup to fail when installing Geonode 2.8 dev in Finalize GeoNode Setup & Test<http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html#finalize-geonode-setup-test>.
This is because updategeoip.py expects<https://github.com/GeoNode/geonode/blob/master/geonode/base/management/commands/updategeoip.py#L34> to use geoip2 to handle the new GeoLite2 database, but geoip2 is only available from Django 1.9, not in Django 1.8 as used by Geonode 2.8.
I've raised this as issue 4153<https://github.com/GeoNode/geonode/issues/4153>.
Regards
Jonathan
CityData<https://citydata.be.unsw.edu.au/>: Store, discover and share - data for city analytics and decision-making
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190111/6c91a7bc/attachment.html>
More information about the geonode-devel
