[GeoNode-devel] Filter layer in MapStore map
Simone Giannecchini
simone.giannecchini at geo-solutions.it
Tue Jul 2 15:25:48 PDT 2019
Hi Jonathan,
a few things:
-1- I believe this issue should be moved to the geonode-mapstore repo
-2- the ability to create filtered layers by specifying a query is going to
be released shortly for mapstore. This means it will end up in the geonode
integration soon
-3- you can still use geoexplorer if you prefer :)
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
On Mon, Jun 10, 2019 at 2:08 PM Jonathan Doig <j.doig at unsw.edu.au> wrote:
> Hi Devs
> In the old GeoExplorer mapping client, you could filter a layer by scale
> or attributes and save the map with this filter applied to the layer
> definition.
> In the new MapStore mapping client, you can open the layer attribute table
> and apply a filter, but cannot save it to the layer definition. This is a
> significant loss of function.
> Raised as issue #4468 <https://github.com/GeoNode/geonode/issues/4468>.
> Cheers
> Jonathan
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190702/77b51c92/attachment-0001.html>
More information about the geonode-devel
