[GeoNode-devel] Filter layer in MapStore map
Jon Doig
j.doig at unsw.edu.au
Tue Jul 2 20:34:46 PDT 2019
Great! Good to know thanks Simone. If it's happening in MapStore anyway I'll suggest this issue can be closed.
Regards
Jon
From: Simone Giannecchini <simone.giannecchini at geo-solutions.it>
Sent: Wednesday, July 3, 2019 8:25:48 AM
To: Jon Doig
Cc: geonode-devel
Subject: Re: [GeoNode-devel] Filter layer in MapStore map
Hi Jonathan,
a few things:
-1- I believe this issue should be moved to the geonode-mapstore repo
-2- the ability to create filtered layers by specifying a query is going to be released shortly for mapstore. This means it will end up in the geonode integration soon
-3- you can still use geoexplorer if you prefer :)
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Mon, Jun 10, 2019 at 2:08 PM Jonathan Doig <j.doig at unsw.edu.au<mailto:j.doig at unsw.edu.au>> wrote:
Hi Devs
In the old GeoExplorer mapping client, you could filter a layer by scale or attributes and save the map with this filter applied to the layer definition.
In the new MapStore mapping client, you can open the layer attribute table and apply a filter, but cannot save it to the layer definition. This is a significant loss of function.
Raised as issue #4468<https://github.com/GeoNode/geonode/issues/4468>.
Cheers
Jonathan
geonode-devel mailing list
geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190703/a180ed13/attachment.html>
More information about the geonode-devel
