[GeoNode-devel] attributes are not created when uploading a layer
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jul 16 05:53:59 PDT 2019
Hi Paolo,
I guess this needs more investigation. Currently, I'm not sure what's going
on.
It is also possible that the update to the new "geoserver-restconfig"
library instead of the old "gsconfig" one, already fixes the problem.
I would open an issue in any case.
Cheers,
Alessio.
Il giorno mar 16 lug 2019 alle ore 04:38 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi all
> Two things to add here:
> * I realized that this behaviour is happening randomly - so it could
> be that for some reason during the upload process GeoServer
> authorization doesn't work under some circumstances.
> For example this is the same shapefile uploaded today and on Saturday:
> attributes are there only in the latter one:
> http://128.31.22.46/layers/geonode:subwaylines_p_odp_2
> http://128.31.22.46/layers/geonode:subwaylines_p_odp_3
> * Everything else with GeoServer works correctly (style editing, data
> editing etc...), so I believe configuration should be correct
> @afabiani, I am planning to file a ticket, let me know your thoughts about
> this.
> thanks
> Paolo
> On Fri, Jul 12, 2019 at 4:07 PM Paolo Corti <pcorti at gmail.com> wrote:
> > Hi (GeoServer) devs
> > this is happening not locally, but on two our production instances now
> > - it was working correctly before a few weeks ago - with different
> > code.
> > What is happening: when a user - even the administrator - upload a new
> > vector layer, the attributes are not created in the layer_attributes
> > django table.
> > The problem seems to occur at this line:
> https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/helpers.py#L915
> > Checking the body of the response I see:
> > <?xml version="1.0" ?>
> > <ServiceExceptionReport
> >    version="1.2.0"
> >    xmlns="http://www.opengis.net/ogc"
> >    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> >    xsi:schemaLocation="http://www.opengis.net/ogc
> > http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
> >    <ServiceException code="InvalidParameterValue">
> >       Could not find type: {http://www.geonode.org/}subwaylines_p_odp_4
> > </ServiceException></ServiceExceptionReport>
> > If I save the layer (from metadata) then the attributes are correctly
> created.
> > I am pretty sure this must be some GeoServer misconfiguration in
> > security directory: do you have an hint about what could cause this?
> > thanks in advance!
> > Paolo
> > Paolo Corti
> > Geospatial software developer
> > web: http://www.paolocorti.net
> > twitter: @capooti
> > skype: capooti
> > #drt3jc1
> Paolo Corti
> twitter: @capooti
> skype: capooti
> #drt3jc1
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190716/b5d108ab/attachment.html>
More information about the geonode-devel mailing list
