[GeoNode-devel] attributes are not created when uploading a	layer
    Paolo Corti
    pcorti at gmail.com
    Mon Jul 15 19:37:58 PDT 2019
Hi all
Two things to add here:
* I realized that this behaviour is happening randomly - so it could
be that for some reason during the upload process GeoServer
authorization doesn't work under some circumstances.
For example this is the same shapefile uploaded today and on Saturday:
attributes are there only in the latter one:
http://128.31.22.46/layers/geonode:subwaylines_p_odp_2
http://128.31.22.46/layers/geonode:subwaylines_p_odp_3
* Everything else with GeoServer works correctly (style editing, data
editing etc...), so I believe configuration should be correct
@afabiani, I am planning to file a ticket, let me know your thoughts about this.
thanks
Paolo
On Fri, Jul 12, 2019 at 4:07 PM Paolo Corti <pcorti at gmail.com> wrote:
> Hi (GeoServer) devs
> this is happening not locally, but on two our production instances now
> - it was working correctly before a few weeks ago - with different
> code.
> What is happening: when a user - even the administrator - upload a new
> vector layer, the attributes are not created in the layer_attributes
> django table.
> The problem seems to occur at this line:
> https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/helpers.py#L915
> Checking the body of the response I see:
> <?xml version="1.0" ?>
> <ServiceExceptionReport
>    version="1.2.0"
>    xmlns="http://www.opengis.net/ogc"
>    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>    xsi:schemaLocation="http://www.opengis.net/ogc
> http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
>    <ServiceException code="InvalidParameterValue">
>       Could not find type: {http://www.geonode.org/}subwaylines_p_odp_4
> </ServiceException></ServiceExceptionReport>
> If I save the layer (from metadata) then the attributes are correctly created.
> I am pretty sure this must be some GeoServer misconfiguration in
> security directory: do you have an hint about what could cause this?
> thanks in advance!
> Paolo
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> #drt3jc1
Paolo Corti
twitter: @capooti
skype: capooti
#drt3jc1
More information about the geonode-devel
