[GeoNode-devel] Upload has become unresponsive
Paolo Pasquali paolo.pasquali at gmail.com
Wed Jun 5 01:54:14 PDT 2019
Yep, problem solved.
Thanks again!
Ciao
P.
On Wed, Jun 5, 2019 at 10:47 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Yep, geogig stuff has been removed from GeoNode.
> You'll need to update your templates accordingly and remove any reference
> to geogig everywhere.
> Il giorno mer 5 giu 2019 alle ore 10:45 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Ciao Alessio,
>> I get a JS error at:
>> geogig_enabled = ,  Unexpected token ','
>> That's weird since the uploader worked.
>> Do you think this could be the cause of the problem?
>> Thanks,
>> Paolo
>> On Wed, Jun 5, 2019 at 10:25 AM Alessio Fabiani <
>>> Most probably a javascript issue.
>>> Can you please try again and look at the "console" tab of the browser
>>> debug window if any error pops up?
>>> Il giorno mer 5 giu 2019 alle ore 10:18 Paolo Pasquali <
>>>> Dear all,
>>>> While moving from the IP to the domain configuration in my Docker
>>>> installation, the upload stopped working. I've changed some parameters
>>>> trying to solve another problem but can't figure out the what caused this.
>>>> So, when I try to upload a layer (choosing or dropping files) the page
>>>> simply does nothing. If I remember well I already had this problem but
>>>> can't find in old email the solution. Sorry for duplicate.
>>>> Thanks for your help.
>>>> Best,
>>>> Paolo
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190605/1693e7db/attachment-0001.html>
More information about the geonode-devel mailing list
