[GeoNode-devel] Upload has become unresponsive
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jun 5 01:47:22 PDT 2019
Yep, geogig stuff has been removed from GeoNode.
You'll need to update your templates accordingly and remove any reference
to geogig everywhere.
Il giorno mer 5 giu 2019 alle ore 10:45 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Ciao Alessio,
> I get a JS error at:
> geogig_enabled = ,  Unexpected token ','
> That's weird since the uploader worked.
> Do you think this could be the cause of the problem?
> Thanks,
> Paolo
> On Wed, Jun 5, 2019 at 10:25 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Most probably a javascript issue.
>> Can you please try again and look at the "console" tab of the browser
>> debug window if any error pops up?
>> Il giorno mer 5 giu 2019 alle ore 10:18 Paolo Pasquali <
>>> Dear all,
>>> While moving from the IP to the domain configuration in my Docker
>>> installation, the upload stopped working. I've changed some parameters
>>> trying to solve another problem but can't figure out the what caused this.
>>> So, when I try to upload a layer (choosing or dropping files) the page
>>> simply does nothing. If I remember well I already had this problem but
>>> can't find in old email the solution. Sorry for duplicate.
>>> Thanks for your help.
>>> Best,
>>> Paolo
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190605/f7f41946/attachment-0001.html>
More information about the geonode-devel mailing list
