[GeoNode-devel] Upload has become unresponsive
Paolo Pasquali
paolo.pasquali at gmail.com
Wed Jun 5 01:45:15 PDT 2019
Ciao Alessio,
I get a JS error at:
geogig_enabled = , Unexpected token ','
That's weird since the uploader worked.
Do you think this could be the cause of the problem?
Thanks,
Paolo
On Wed, Jun 5, 2019 at 10:25 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Most probably a javascript issue.
> Can you please try again and look at the "console" tab of the browser
> debug window if any error pops up?
> Il giorno mer 5 giu 2019 alle ore 10:18 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Dear all,
>> While moving from the IP to the domain configuration in my Docker
>> installation, the upload stopped working. I've changed some parameters
>> trying to solve another problem but can't figure out the what caused this.
>> So, when I try to upload a layer (choosing or dropping files) the page
>> simply does nothing. If I remember well I already had this problem but
>> can't find in old email the solution. Sorry for duplicate.
>> Thanks for your help.
>> Best,
>> Paolo
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190605/b8e7b0b2/attachment-0001.html>
More information about the geonode-devel
