[GeoNode-devel] Upload has become unresponsive
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Jun 5 01:25:09 PDT 2019
Most probably a javascript issue.
Can you please try again and look at the "console" tab of the browser debug
window if any error pops up?
Il giorno mer 5 giu 2019 alle ore 10:18 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Dear all,
> While moving from the IP to the domain configuration in my Docker
> installation, the upload stopped working. I've changed some parameters
> trying to solve another problem but can't figure out the what caused this.
> So, when I try to upload a layer (choosing or dropping files) the page
> simply does nothing. If I remember well I already had this problem but
> can't find in old email the solution. Sorry for duplicate.
> Thanks for your help.
> Best,
> Paolo
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190605/314e21db/attachment.html>
More information about the geonode-devel
