[GeoNode-devel] Sign up to GeoNode
Paolo Pasquali
paolo.pasquali at gmail.com
Thu Jun 20 01:06:14 PDT 2019
Ciao Alessio,
Thanks for the quick response.
In a recent version there is not this problem.
So I guess I need to upgrade my GeoNode but I'd need some help from you on
how to proceed.
I've installed GeoNode using Docker and I've added some other apps. One of
them (Wagtail) requires djangorestframework>=3.1.3,<3.7 in order to run
with Django 1.11. MapStore2 (django-mapstore-adapter) requires instead
djangorestframework>=3.8.2 so I need to stick with GXP for now.
I've tried to switch to GXP (removing django-mapstore-adapter from the
requirements) but the docker-compose fails anyway.
How would you suggest to proceed?
Thanks,
Ciao.
Paolo
On Wed, Jun 19, 2019 at 7:06 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Paolo,
> did you managed to reproduce the issue on recent 2.10 versions too? If so
> it is a regression.
> Il giorno mer 19 giu 2019 alle ore 18:41 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Hi devs,
>> I'm running a GeoNode 2.10.x (a couple of months ago version) and I'm
>> having an issue with the sign up form.
>> When a new user tries to register I get:
>> *IntegrityError at /account/signup/*
>> *insert or update on table "people_profile_groups" violates foreign key
>> constraint "profile_id_refs_id_8228233c"*
>> *DETAIL: Key (profile_id)=(982) is not present in table
>> "people_profile_tmp".*
>> The user then is registered and activated although I've set ACCOUNT_APPROVAL_REQUIRED
>> = *True*
>> while the expected behaviour should be registered but not active.
>> Some background info: I have migrated my data from a GeoNode 2.4.1
>> restoring the old database.
>> Thanks for your help!
>> Best,
>> Paolo
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190620/f6c84950/attachment.html>
More information about the geonode-devel
