[GeoNode-devel] Change style raises 403 even for admin after updating to latest master code
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Mar 7 09:29:12 PST 2019
Hello Paolo,
are you sure your token and session are still valid? I'm not aware of
commits affecting this functionality pushed recently.
Il giorno gio 7 mar 2019 alle ore 17:25 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hello developers
> For a few weeks two our instances base on GeoNode master have been
> working correctly, but now - after pulling latest commits from GeoNode
> master (not sure which one is affecting this) - even the admin can't
> change the style for a layer (gets a 403).
> This is the error I see in the GeoServer log (here is the full log:
> https://paste.ofcode.org/ZDjAQSNqzJGecRKKixKNnV)
> 2019-03-07 16:14:03,322 INFO [geoserver.flow] - Request [wfs 1.0.0
> DescribeFeatureType] starting, processing through flow controllers
> 2019-03-07 16:14:03,322 INFO [geoserver.flow] - Request control-flow
> performed, running requests: 1, blocked requests: 0
> 2019-03-07 16:14:03,323 ERROR [geoserver.ows] -
> org.geoserver.wfs.WFSException: Could not find type:
> {http://www.geonode.org/}action_1
>     at
> org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:156)
> at
> org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:91)
> at sun.reflect.GeneratedMethodAccessor482.invoke(Unknown Source)
> could this be a regression?
> any idea?
> best
> Paolo
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190307/4bec5916/attachment-0001.html>
More information about the geonode-devel mailing list
