[GeoNode-devel] GeoNODE-Project Docker Server Hard Disc Space
Francesco Frassinelli
francesco.frassinelli at nina.no
Tue Mar 12 04:38:52 PDT 2019
Have you tried to remove stopped containers? The default GeoNode Docker setup can produce a lot of dead containers when starting up (this issue has been fixed in SPC GeoNode).
Cheers,
Frafra
From: geonode-devel <geonode-devel-bounces at lists.osgeo.org> On Behalf Of Julierme Pinheiro
Sent: Monday, March 11, 2019 5:59 PM
To: geonode-users <geonode-users at lists.osgeo.org>; geonode-devel <geonode-devel at lists.osgeo.org>
Subject: [GeoNode-devel] GeoNODE-Project Docker Server Hard Disc Space
Dear all,
I have been running GeoNode-Project installed via Docker on an Ubuntu at 18.04LTS<mailto:Ubuntu at 18.04LTS> and lately my server hard disc is getting full, running out of space. I see that docker device mapper and containers are using a lot of space. Would this hard disc issue be caused by any log file? Is there any action that you would recommend in order to get some more free space in the server? I have only 16 layers and 3 maps in GeoNode. Find bellow some information about docker devicemapper amd containers:
/dev/dm-3 10G 160M 9,9G 2% /var/lib/docker/devicemapper/mnt/1a5503ef70abc86df7551647ab581d446db7cb445e0c5cdafe8e6b10e2efcc5d
/dev/dm-4 10G 381M 9,7G 4% /var/lib/docker/devicemapper/mnt/ebda88ce1405216ea5e9b7ab53d1ca41cb1008e2bcc8979b1bed16a289211c08
/dev/dm-2 10G 448M 9,6G 5% /var/lib/docker/devicemapper/mnt/50183a5001b29c9b54e08a71ac0e1f2ba7fdbe8b90d479cbee545b880d44ff5b
/dev/dm-5 10G 10G 20K 100% /var/lib/docker/devicemapper/mnt/4d6ca1f8aa7bbe1482963cec36f6144c2d0232da21c4bf015bf059407102c4db
/dev/dm-1 10G 2,2G 7,9G 22% /var/lib/docker/devicemapper/mnt/4b14d81a4b154593f5ca01c97826241a0c113060747b799792cf5a1da7435a23
/dev/dm-6 10G 3,4G 6,7G 34% /var/lib/docker/devicemapper/mnt/36aabfab818b3156aacf8170d8c9373147cf6438f78f0992a0c6dcf11fcee50e
/dev/dm-7 10G 146M 9,9G 2% /var/lib/docker/devicemapper/mnt/03dc512a9c357ca634170c39204583738c16920a1ef51bd589b679dc0484c644
Thank you very much for your time in advance
Kind regards
Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190312/9bc1101d/attachment.html>
More information about the geonode-devel
