[GeoNode-devel] GeoNODE-Project Docker Server Hard Disc Space
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Tue Mar 12 06:12:25 PDT 2019
Hi Francesco,
Thank you very much for you reply. I am still Docker beginner. Reading on
the internet the command would be <docker system prune>, but I am worried
about wiping out all docker images. Would recommend me a docker command to
remove the stopped containers?
Kind regards
Julierme
On Tue, Mar 12, 2019 at 8:38 AM Francesco Frassinelli <
francesco.frassinelli at nina.no> wrote:
> Hi,
> Have you tried to remove stopped containers? The default GeoNode Docker
> setup can produce a lot of dead containers when starting up (this issue has
> been fixed in SPC GeoNode).
> Cheers,
> Frafra
> *From:* geonode-devel <geonode-devel-bounces at lists.osgeo.org> *On Behalf
> Of *Julierme Pinheiro
> *Sent:* Monday, March 11, 2019 5:59 PM
> *To:* geonode-users <geonode-users at lists.osgeo.org>; geonode-devel <
> geonode-devel at lists.osgeo.org>
> *Subject:* [GeoNode-devel] GeoNODE-Project Docker Server Hard Disc Space
> Dear all,
> I have been running GeoNode-Project installed via Docker on an
> Ubuntu at 18.04LTS and lately my server hard disc is getting full, running
> out of space. I see that docker device mapper and containers are using a
> lot of space. Would this hard disc issue be caused by any log file? Is
> there any action that you would recommend in order to get some more free
> space in the server? I have only 16 layers and 3 maps in GeoNode. Find
> bellow some information about docker devicemapper amd containers:
> /dev/dm-3 10G 160M 9,9G 2%
> /var/lib/docker/devicemapper/mnt/1a5503ef70abc86df7551647ab581d446db7cb445e0c5cdafe8e6b10e2efcc5d
> /dev/dm-4 10G 381M 9,7G 4%
> /var/lib/docker/devicemapper/mnt/ebda88ce1405216ea5e9b7ab53d1ca41cb1008e2bcc8979b1bed16a289211c08
> /dev/dm-2 10G 448M 9,6G 5%
> /var/lib/docker/devicemapper/mnt/50183a5001b29c9b54e08a71ac0e1f2ba7fdbe8b90d479cbee545b880d44ff5b
> /dev/dm-5 10G 10G 20K 100%
> /var/lib/docker/devicemapper/mnt/4d6ca1f8aa7bbe1482963cec36f6144c2d0232da21c4bf015bf059407102c4db
> /dev/dm-1 10G 2,2G 7,9G 22%
> /var/lib/docker/devicemapper/mnt/4b14d81a4b154593f5ca01c97826241a0c113060747b799792cf5a1da7435a23
> /dev/dm-6 10G 3,4G 6,7G 34%
> /var/lib/docker/devicemapper/mnt/36aabfab818b3156aacf8170d8c9373147cf6438f78f0992a0c6dcf11fcee50e
> /dev/dm-7 10G 146M 9,9G 2%
> /var/lib/docker/devicemapper/mnt/03dc512a9c357ca634170c39204583738c16920a1ef51bd589b679dc0484c644
> Thank you very much for your time in advance
> Kind regards
> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190312/577ebb5d/attachment.html>
More information about the geonode-devel
