[GeoNode-devel] GeoNODE-Project Docker Server Hard Disc Space
Francesco Frassinelli francesco.frassinelli at nina.no
Tue Mar 12 06:15:47 PDT 2019
You can use docker container prune, if you just want to remove stopped containers without removing volumes. My suggestion is to have a backup system for your volumes (or bind mounts) so you feel more relaxed when removing unused stuff 😉
From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
Sent: Tuesday, March 12, 2019 2:12 PM
To: Francesco Frassinelli <francesco.frassinelli at nina.no>
Cc: geonode-devel <geonode-devel at lists.osgeo.org>
Subject: Re: [GeoNode-devel] GeoNODE-Project Docker Server Hard Disc Space
Hi Francesco,
Thank you very much for you reply. I am still Docker beginner. Reading on the internet the command would be <docker system prune>, but I am worried about wiping out all docker images. Would recommend me a docker command to remove the stopped containers?
Kind regards
Julierme
On Tue, Mar 12, 2019 at 8:38 AM Francesco Frassinelli <francesco.frassinelli at nina.no<mailto:francesco.frassinelli at nina.no>> wrote:
Have you tried to remove stopped containers? The default GeoNode Docker setup can produce a lot of dead containers when starting up (this issue has been fixed in SPC GeoNode).
Cheers,
Frafra
From: geonode-devel <geonode-devel-bounces at lists.osgeo.org<mailto:geonode-devel-bounces at lists.osgeo.org>> On Behalf Of Julierme Pinheiro
Sent: Monday, March 11, 2019 5:59 PM
To: geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>; geonode-devel <geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>>
Subject: [GeoNode-devel] GeoNODE-Project Docker Server Hard Disc Space
Dear all,
I have been running GeoNode-Project installed via Docker on an Ubuntu at 18.04LTS<mailto:Ubuntu at 18.04LTS> and lately my server hard disc is getting full, running out of space.  I see that docker device mapper and containers are using a lot of space. Would this hard disc issue be caused by any log file? Is there any action that you would recommend in order to get some more free space in the server? I have only 16 layers and 3 maps in GeoNode. Find bellow some information about docker devicemapper amd containers:
/dev/dm-3        10G  160M  9,9G   2% /var/lib/docker/devicemapper/mnt/1a5503ef70abc86df7551647ab581d446db7cb445e0c5cdafe8e6b10e2efcc5d
/dev/dm-4        10G  381M  9,7G   4% /var/lib/docker/devicemapper/mnt/ebda88ce1405216ea5e9b7ab53d1ca41cb1008e2bcc8979b1bed16a289211c08
/dev/dm-2        10G  448M  9,6G   5% /var/lib/docker/devicemapper/mnt/50183a5001b29c9b54e08a71ac0e1f2ba7fdbe8b90d479cbee545b880d44ff5b
/dev/dm-5        10G   10G   20K 100% /var/lib/docker/devicemapper/mnt/4d6ca1f8aa7bbe1482963cec36f6144c2d0232da21c4bf015bf059407102c4db
/dev/dm-1        10G  2,2G  7,9G  22% /var/lib/docker/devicemapper/mnt/4b14d81a4b154593f5ca01c97826241a0c113060747b799792cf5a1da7435a23
/dev/dm-6        10G  3,4G  6,7G  34% /var/lib/docker/devicemapper/mnt/36aabfab818b3156aacf8170d8c9373147cf6438f78f0992a0c6dcf11fcee50e
/dev/dm-7        10G  146M  9,9G   2% /var/lib/docker/devicemapper/mnt/03dc512a9c357ca634170c39204583738c16920a1ef51bd589b679dc0484c644
Thank you very much for your time in advance
Kind regards
Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190312/b510b040/attachment-0001.html>
More information about the geonode-devel mailing list
