[GeoNode-devel] Vector tiles in GeoNode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Mar 13 09:57:38 PDT 2019
@Paolo Pasquali <paolo.pasquali at gmail.com> just wanted to make you aware
that this (mvt support) is ongoing work (client side) on MapStore
https://www.geo-solutions.it/blog/mapstore-release-2019_01_00/
Il giorno mer 13 mar 2019 alle ore 17:47 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Ciao Francesco,
> Initially I'm going to try with both OL and Leaflet.
> Then see what happens...
> Suggestions are more than welcome.
> P.
> On Wed, Mar 13, 2019 at 5:30 PM Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Ciao Paolo,
>> just curious which client are you using for mvt?
>> Francesco
>> Il 13 mar 2019, 17:22 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>,
>> ha scritto:
>> This issue has been solved.
>> The grid subset bounds must be set to dynamic.
>> Ciao,
>> P.
>> On Wed, Mar 13, 2019 at 5:01 PM Paolo Pasquali <paolo.pasquali at gmail.com>
>> wrote:
>>> Dear all,
>>> I would like to experiment vector tiles in GeoNode.
>>> As a starting point, I've added the plugin inside GeoServer and
>>> following the documentation I have tried to activate the vector tile
>>> formats in a GeoServer layer page.
>>> Unfortunately, I'm getting
>>> - Grid subset bounds are either null or invalid
>>> - Grid subset bounds do not intersect the Gridset bounds
>>> when I try to save the changes.
>>> I've downloaded the 2.14.x snapshot plugin [1]. So I wonder if this is
>>> the correct version.
>>> Or maybe my installation has something wrong?
>>> Thanks for your help.
>>> Best,
>>> Paolo
>>> [1] Vector Tiles
>>> <https://build.geoserver.org/geoserver/2.14.x/ext-latest/geoserver-2.14-SNAPSHOT-vectortiles-plugin.zip>
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190313/a30461cb/attachment-0001.html>
More information about the geonode-devel
