[GeoNode-devel] Vector tiles in GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Mar 13 10:03:09 PDT 2019
https://www.opengeospatial.org/projects/initiatives/vt-pilot-2018
https://www.youtube.com/watch?v=LL-spqq-LNU
https://www.youtube.com/watch?v=rT4AWlAtT54
https://www.youtube.com/watch?time_continue=9&v=d0wsbDOIqmo
Il giorno mer 13 mar 2019 alle ore 17:57 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> @Paolo Pasquali <paolo.pasquali at gmail.com> just wanted to make you aware
> that this (mvt support) is ongoing work (client side) on MapStore
> https://www.geo-solutions.it/blog/mapstore-release-2019_01_00/
> Il giorno mer 13 mar 2019 alle ore 17:47 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Ciao Francesco,
>> Initially I'm going to try with both OL and Leaflet.
>> Then see what happens...
>> Suggestions are more than welcome.
>> P.
>> On Wed, Mar 13, 2019 at 5:30 PM Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Ciao Paolo,
>>> just curious which client are you using for mvt?
>>> Francesco
>>> Il 13 mar 2019, 17:22 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>,
>>> ha scritto:
>>> This issue has been solved.
>>> The grid subset bounds must be set to dynamic.
>>> Ciao,
>>> P.
>>> On Wed, Mar 13, 2019 at 5:01 PM Paolo Pasquali <paolo.pasquali at gmail.com>
>>> wrote:
>>>> Dear all,
>>>> I would like to experiment vector tiles in GeoNode.
>>>> As a starting point, I've added the plugin inside GeoServer and
>>>> following the documentation I have tried to activate the vector tile
>>>> formats in a GeoServer layer page.
>>>> Unfortunately, I'm getting
>>>>    - Grid subset bounds are either null or invalid
>>>>    - Grid subset bounds do not intersect the Gridset bounds
>>>> when I try to save the changes.
>>>> I've downloaded the 2.14.x snapshot plugin [1]. So I wonder if this is
>>>> the correct version.
>>>> Or maybe my installation has something wrong?
>>>> Thanks for your help.
>>>> Best,
>>>> Paolo
>>>> [1] Vector Tiles
>>>> <https://build.geoserver.org/geoserver/2.14.x/ext-latest/geoserver-2.14-SNAPSHOT-vectortiles-plugin.zip>
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190313/4235f9c4/attachment-0001.html>
More information about the geonode-devel mailing list
