[GeoNode-devel] Vector tiles in GeoNode
Paolo Pasquali paolo.pasquali at gmail.com
Wed Mar 13 10:16:57 PDT 2019
Thanks Alessio!
I was aware of MapStore but I've never tried it.
That's something I going to see in action for sure... once I've learned the
basics of vector tiles.
Ciao
P.
On Wed, Mar 13, 2019 at 6:03 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> https://www.opengeospatial.org/projects/initiatives/vt-pilot-2018
> https://www.youtube.com/watch?v=LL-spqq-LNU
> https://www.youtube.com/watch?v=rT4AWlAtT54
> https://www.youtube.com/watch?time_continue=9&v=d0wsbDOIqmo
> Il giorno mer 13 mar 2019 alle ore 17:57 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> @Paolo Pasquali <paolo.pasquali at gmail.com> just wanted to make you aware
>> that this (mvt support) is ongoing work (client side) on MapStore
>> https://www.geo-solutions.it/blog/mapstore-release-2019_01_00/
>> Il giorno mer 13 mar 2019 alle ore 17:47 Paolo Pasquali <
>> paolo.pasquali at gmail.com> ha scritto:
>>> Ciao Francesco,
>>> Initially I'm going to try with both OL and Leaflet.
>>> Then see what happens...
>>> Suggestions are more than welcome.
>>> P.
>>> On Wed, Mar 13, 2019 at 5:30 PM Francesco Bartoli <xbartolone at gmail.com>
>>> wrote:
>>>> Ciao Paolo,
>>>> just curious which client are you using for mvt?
>>>> Francesco
>>>> Il 13 mar 2019, 17:22 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>,
>>>> ha scritto:
>>>> This issue has been solved.
>>>> The grid subset bounds must be set to dynamic.
>>>> Ciao,
>>>> P.
>>>> On Wed, Mar 13, 2019 at 5:01 PM Paolo Pasquali <
>>>> paolo.pasquali at gmail.com> wrote:
>>>>> Dear all,
>>>>> I would like to experiment vector tiles in GeoNode.
>>>>> As a starting point, I've added the plugin inside GeoServer and
>>>>> following the documentation I have tried to activate the vector tile
>>>>> formats in a GeoServer layer page.
>>>>> Unfortunately, I'm getting
>>>>>    - Grid subset bounds are either null or invalid
>>>>>    - Grid subset bounds do not intersect the Gridset bounds
>>>>> when I try to save the changes.
>>>>> I've downloaded the 2.14.x snapshot plugin [1]. So I wonder if this is
>>>>> the correct version.
>>>>> Or maybe my installation has something wrong?
>>>>> Thanks for your help.
>>>>> Best,
>>>>> Paolo
>>>>> [1] Vector Tiles
>>>>> <https://build.geoserver.org/geoserver/2.14.x/ext-latest/geoserver-2.14-SNAPSHOT-vectortiles-plugin.zip>
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190313/0430d02f/attachment-0001.html>
More information about the geonode-devel mailing list
