[GeoNode-devel] Python 3 / Django 2 Upgrade version naming and branch
Simone Giannecchini
simone.giannecchini at geo-solutions.it
Wed Mar 20 02:17:56 PDT 2019
Hi Francesco,
I think we are pretty much inline although my concern is more on the amount
of work needed to track all these branches and the implicit risks.
In addition this Python 3 work should happen in a public branch where the
community can contribute or at least check; I am strognly against this work
being done as we are talking about a potential disruptive contribution I
would be very careful about how we prepare for it and how we handle it.
Regards,
Simone.
Il giorno mar 19 mar 2019 alle 15:35 Francesco Bartoli <xbartolone at gmail.com>
ha scritto:
> Thanks Alessio for clarifications. Comments inline
> Il 19 mar 2019, 15:30 +0100, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>, ha scritto:
> Hello Simone and Francesco,
> just to clarify a bit more, the idea would be to following one.
> When we are ready to start the release process (**after** clean up and
> other preparation stuff we have already discussed at the meeting), the 2.10
> branch would become the new stable branch, where we backport only critical
> issues and/or features the community has tested enough (and that have a
> maintainer).
> The 2.11 branch would become the Python 2 dev branch for a while until we
> definitively switch to Python 3. This because of people that installed
> 2.10, might still need to backport fixes without being forced to switch to
> Python 3 and Django 2.
> what about master during the phases?
> In the meantime, we will align the branches with the 2.20 one, based on
> Python 3, and once we are ready to switch definitively, the next releases
> will be based on the latter.
> I’m a little bit concerned about this since potential incompatibilities
> would be likely as much as longer the release time of Python 3 will be. I
> believe the more we can cut 2.10 and 2.11 very close to the merge of PR for
> py3 into master the more we stay safe. Once that might happen then I would
> keep 2.11 just for fixing critical issues and master for new features
> In parallel, hopefully, the work on GeoNode 3 will move on.
> Il giorno mar 19 mar 2019 alle ore 15:05 Simone Giannecchini <
> simone.giannecchini at geo-solutions.it> ha scritto:
>> Hi Alessio,
>> I fully agree that we should not pollute 2.10, however two things:
>> -1- it is not clear to me the plan for the two new branches. Are they
>> expected to merge before 2.11 or after?
>> -2- Cutting 2.10 now could be too early as there is more clean up that we
>> might want to do before releasing and this cut would generate a lot of work
>> now to keep master and 2.10 branches aligned meanwhile.
>> It would probably be best to have the Python 3 development happen in
>> parallel in a branch that tracks master and then merge on master at a
>> certain point when the upgrade is ready or simply have the Python 3 branch
>> become the new master.
>> I am also interested to hear what the others think.
>> Regards,
>> Simone.
>> Il giorno mar 19 mar 2019 alle 10:03 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> Dear devs,
>>> as the work on upgrading GeoNode 2.10 to Python 3 and Django 2 is moving
>>> on, I would propose to:
>>> 1. Create a 2.10 branch which will be used for the next release still
>>> based on Python 2; this branch will be stable and only major issues will be
>>> backported until the release
>>> 2. Move "master" to 2.11; this will be the new development branch still
>>> based on Python 2
>>> 3. Create a 2.20 branch which will be the development branch based on
>>> Python3
>>> Any objections? Ideas?
>>> Regards,
>>> Alessio.
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A -
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g> 55054
>>> Massarosa
>>> (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Regards,
>> Simone Giannecchini.
>> GeoSolutions Director
>> - sent from my mobile, apologies for brevity and typos-
> @alfa7691
> GeoSolutions S.A.S.
> <https://maps.google.com/?q=Via+di+Montramito+3/A+-+55054++Massarosa&entry=gmail&source=g> 55054
> Massarosa
> (LU) - Italy
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
Regards,
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190320/e10f66ab/attachment-0001.html>
More information about the geonode-devel
