[GeoNode-devel] Python 3 / Django 2 Upgrade version naming and branch
G. Allegri
giovanni.allegri at geo-solutions.it
Wed Mar 20 02:29:04 PDT 2019
Hi all,
I don't see anyone references inside this issue
<https://github.com/GeoNode/geonode/issues/4276> partecipating to the
discussion. I think we will need to comment the issue and ask them to
partecipate.
Giovanni
Il giorno mer 20 mar 2019 alle ore 10:18 Simone Giannecchini <
simone.giannecchini at geo-solutions.it> ha scritto:
> Hi Francesco,
> I think we are pretty much inline although my concern is more on the
> amount of work needed to track all these branches and the implicit risks.
> In addition this Python 3 work should happen in a public branch where the
> community can contribute or at least check; I am strognly against this work
> being done as we are talking about a potential disruptive contribution I
> would be very careful about how we prepare for it and how we handle it.
> Regards,
> Simone.
> Il giorno mar 19 mar 2019 alle 15:35 Francesco Bartoli <
> xbartolone at gmail.com> ha scritto:
>> Thanks Alessio for clarifications. Comments inline
>> Il 19 mar 2019, 15:30 +0100, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it>, ha scritto:
>> Hello Simone and Francesco,
>> just to clarify a bit more, the idea would be to following one.
>> When we are ready to start the release process (**after** clean up and
>> other preparation stuff we have already discussed at the meeting), the 2.10
>> branch would become the new stable branch, where we backport only critical
>> issues and/or features the community has tested enough (and that have a
>> maintainer).
>> The 2.11 branch would become the Python 2 dev branch for a while until we
>> definitively switch to Python 3. This because of people that installed
>> 2.10, might still need to backport fixes without being forced to switch to
>> Python 3 and Django 2.
>> what about master during the phases?
>> In the meantime, we will align the branches with the 2.20 one, based on
>> Python 3, and once we are ready to switch definitively, the next releases
>> will be based on the latter.
>> I’m a little bit concerned about this since potential incompatibilities
>> would be likely as much as longer the release time of Python 3 will be. I
>> believe the more we can cut 2.10 and 2.11 very close to the merge of PR for
>> py3 into master the more we stay safe. Once that might happen then I would
>> keep 2.11 just for fixing critical issues and master for new features
>> In parallel, hopefully, the work on GeoNode 3 will move on.
>> Il giorno mar 19 mar 2019 alle ore 15:05 Simone Giannecchini <
>>> Hi Alessio,
>>> I fully agree that we should not pollute 2.10, however two things:
>>> -1- it is not clear to me the plan for the two new branches. Are they
>>> expected to merge before 2.11 or after?
>>> -2- Cutting 2.10 now could be too early as there is more clean up that
>>> we might want to do before releasing and this cut would generate a lot of
>>> work now to keep master and 2.10 branches aligned meanwhile.
>>> It would probably be best to have the Python 3 development happen in
>>> parallel in a branch that tracks master and then merge on master at a
>>> certain point when the upgrade is ready or simply have the Python 3 branch
>>> become the new master.
>>> I am also interested to hear what the others think.
>>> Regards,
>>> Simone.
>>> Il giorno mar 19 mar 2019 alle 10:03 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>> Dear devs,
>>>> as the work on upgrading GeoNode 2.10 to Python 3 and Django 2 is
>>>> moving on, I would propose to:
>>>> 1. Create a 2.10 branch which will be used for the next release still
>>>> based on Python 2; this branch will be stable and only major issues will be
>>>> backported until the release
>>>> 2. Move "master" to 2.11; this will be the new development branch still
>>>> based on Python 2
>>>> 3. Create a 2.20 branch which will be the development branch based on
>>>> Python3
>>>> Any objections? Ideas?
>>>> Regards,
>>>> Alessio.
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A -
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g> 55054
>>>> Massarosa
>>>> (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax: +39 0584 1660272
>>>> mob: +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Regards,
>>> Simone Giannecchini.
>>> GeoSolutions Director
>>> - sent from my mobile, apologies for brevity and typos-
>> @alfa7691
>> GeoSolutions S.A.S.
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-+55054++Massarosa&entry=gmail&source=g> 55054
>> Massarosa
>> (LU) - Italy
> Regards,
Giovanni Allegri
GeoSolutions S.A.S.
<https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
55054 Massarosa
(LU)
Italy
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190320/063df7f9/attachment-0001.html>
More information about the geonode-devel
