[GeoNode-devel] Python 3 / Django 2 Upgrade version naming and branch
Simone Giannecchini
simone.giannecchini at geo-solutions.it
Wed Mar 20 02:43:46 PDT 2019
Ciao Giovanni,
To be honest, if we have to ask them to participate a discussion on the dev
mailing list about their proposal that alone is already a concern to me.
Back to square one, Let’s see what the others think.
Regards,
Simone.
Il giorno mer 20 mar 2019 alle 09:29 G. Allegri <
giovanni.allegri at geo-solutions.it> ha scritto:
> Hi all,
> I don't see anyone references inside this issue
> <https://github.com/GeoNode/geonode/issues/4276> partecipating to the
> discussion. I think we will need to comment the issue and ask them to
> partecipate.
> Giovanni
> Il giorno mer 20 mar 2019 alle ore 10:18 Simone Giannecchini <
> simone.giannecchini at geo-solutions.it> ha scritto:
>> Hi Francesco,
>> I think we are pretty much inline although my concern is more on the
>> amount of work needed to track all these branches and the implicit risks.
>> In addition this Python 3 work should happen in a public branch where the
>> community can contribute or at least check; I am strognly against this work
>> being done as we are talking about a potential disruptive contribution I
>> would be very careful about how we prepare for it and how we handle it.
>> Regards,
>> Simone.
>> Il giorno mar 19 mar 2019 alle 15:35 Francesco Bartoli <
>> xbartolone at gmail.com> ha scritto:
>>> Thanks Alessio for clarifications. Comments inline
>>> Il 19 mar 2019, 15:30 +0100, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it>, ha scritto:
>>> Hello Simone and Francesco,
>>> just to clarify a bit more, the idea would be to following one.
>>> When we are ready to start the release process (**after** clean up and
>>> other preparation stuff we have already discussed at the meeting), the 2.10
>>> branch would become the new stable branch, where we backport only critical
>>> issues and/or features the community has tested enough (and that have a
>>> maintainer).
>>> The 2.11 branch would become the Python 2 dev branch for a while until
>>> we definitively switch to Python 3. This because of people that installed
>>> 2.10, might still need to backport fixes without being forced to switch to
>>> Python 3 and Django 2.
>>> what about master during the phases?
>>> In the meantime, we will align the branches with the 2.20 one, based on
>>> Python 3, and once we are ready to switch definitively, the next releases
>>> will be based on the latter.
>>> I’m a little bit concerned about this since potential incompatibilities
>>> would be likely as much as longer the release time of Python 3 will be. I
>>> believe the more we can cut 2.10 and 2.11 very close to the merge of PR for
>>> py3 into master the more we stay safe. Once that might happen then I would
>>> keep 2.11 just for fixing critical issues and master for new features
>>> In parallel, hopefully, the work on GeoNode 3 will move on.
>>> Il giorno mar 19 mar 2019 alle ore 15:05 Simone Giannecchini <
>>>> Hi Alessio,
>>>> I fully agree that we should not pollute 2.10, however two things:
>>>> -1- it is not clear to me the plan for the two new branches. Are they
>>>> expected to merge before 2.11 or after?
>>>> -2- Cutting 2.10 now could be too early as there is more clean up that
>>>> we might want to do before releasing and this cut would generate a lot of
>>>> work now to keep master and 2.10 branches aligned meanwhile.
>>>> It would probably be best to have the Python 3 development happen in
>>>> parallel in a branch that tracks master and then merge on master at a
>>>> certain point when the upgrade is ready or simply have the Python 3 branch
>>>> become the new master.
>>>> I am also interested to hear what the others think.
>>>> Regards,
>>>> Simone.
>>>> Il giorno mar 19 mar 2019 alle 10:03 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>> Dear devs,
>>>>> as the work on upgrading GeoNode 2.10 to Python 3 and Django 2 is
>>>>> moving on, I would propose to:
>>>>> 1. Create a 2.10 branch which will be used for the next release still
>>>>> based on Python 2; this branch will be stable and only major issues will be
>>>>> backported until the release
>>>>> 2. Move "master" to 2.11; this will be the new development branch
>>>>> still based on Python 2
>>>>> 3. Create a 2.20 branch which will be the development branch based on
>>>>> Python3
>>>>> Any objections? Ideas?
>>>>> Regards,
>>>>> Alessio.
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A -
>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g> 55054
>>>>> Massarosa
>>>>> (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> Regards,
>>>> Simone Giannecchini.
>>>> GeoSolutions Director
>>>> - sent from my mobile, apologies for brevity and typos-
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-+55054++Massarosa&entry=gmail&source=g> 55054
>>> Massarosa
>>> (LU) - Italy
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> Regards,
> Giovanni Allegri
> GeoSolutions S.A.S.
> <https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054 Massarosa
> (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
Regards,
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190320/def538c2/attachment-0001.html>
More information about the geonode-devel
