[GeoNode-devel] [GeoNode-users] GeoNode Credentials Login
Francesco Bartoli xbartolone at gmail.com
Tue Mar 26 16:17:05 PDT 2019
Hi Julierme,
few comments about what I can see from that site:
• Login with admin/admin actually doesn’t work but it is strange
• Apparently your installation doesn’t look like to come from a docker standard deploy as normally I do have geoserver from the root in a /geoserver location while I’m seeing it published in a different public port (8080)
• Also you geoserver instance doesn’t have the geonode login button which is still stranger
Are you totally sure it does come from a geonode-project deployed with the docker installation method?
Il 26 mar 2019, 22:58 +0100, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> You can see here http://iamgeo.com.br/
> Kind regards
> Julierme
> > On Tue, Mar 26, 2019 at 6:56 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
> > > And no Caps Lock on.
> > > > On Tue, Mar 26, 2019 at 6:55 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
> > > > > And geoserver response while liging in:
> > > > > Invalid username/password combination.
> > > > > > On Tue, Mar 26, 2019 at 6:53 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
> > > > > > > Hi Francesco,
> > > > > > > Thank you very much for your reply. Look at this response. I did not do any change at all:
> > > > > > > Forbidden (403)
> > > > > > > CSRF verification failed. Request aborted.
> > > > > > > You are seeing this message because this site requires a CSRF cookie when submitting forms. This cookie is required for security reasons, to ensure that your browser is not being hijacked by third parties.
> > > > > > > If you have configured your browser to disable cookies, please re-enable them, at least for this site, or for 'same-origin' requests.
> > > > > > > Help
> > > > > > > Reason given for failure:
> > > > > > >    CSRF cookie not set.
> > > > > > > In general, this can occur when there is a genuine Cross Site Request Forgery, or when Django's CSRF mechanism has not been used correctly. For POST forms, you need to ensure:
> > > > > > > • Your browser is accepting cookies.
> > > > > > > • The view function passes a request to the template's render method.
> > > > > > > • In the template, there is a {% csrf_token %} template tag inside each POST form that targets an internal URL.
> > > > > > > • If you are not using CsrfViewMiddleware, then you must use csrf_protect on any views that use the csrf_token template tag, as well as those that accept the POST data.
> > > > > > > • The form has a valid CSRF token. After logging in in another browser tab or hitting the back button after a login, you may need to reload the page with the form, because the token is rotated after a login.
> > > > > > > You're seeing the help section of this page because you have DEBUG = True in your Django settings file. Change that to False, and only the initial error message will be displayed.
> > > > > > > You can customize this page using the CSRF_FAILURE_VIEW setting.
> > > > > > > I appreciated your reply.
> > > > > > > Julierme
> > > > > > > > On Tue, Mar 26, 2019 at 6:37 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > > > > > > > Hi Julierme,
> > > > > > > > > I’m right now on a geonode-project based code and the login is working well for me.
> > > > > > > > > Francesco
> > > > > > > > > Il 26 mar 2019, 22:30 +0100, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> > > > > > > > > > Dear users and developers,
> > > > > > > > > > I just installed via Docker a brand new master geonode-project on a Ubuntu18.04lTS server and after installation I could not do a login either through geonode and geoserver default credentials:
> > > > > > > > > > admin admin
> > > > > > > > > > admin geoserver.
> > > > > > > > > > Has anyone faced the same issue? Did the default credentials change?
> > > > > > > > > > I appreciated your time.
> > > > > > > > > > Kind regards
> > > > > > > > > > Julierme
> > > > > > > > > > _______________________________________________
> > > > > > > > > > geonode-users mailing list
> > > > > > > > > > geonode-users at lists.osgeo.org
> > > > > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190327/d994275c/attachment-0001.html>
More information about the geonode-devel mailing list
