[GeoNode-devel] Layer Upload doesn't work in GeoNode 2.8.1rc0: "AttributeError at /layers/upload 'NoneType' object has no attribute 'charset'"
Michael Härtel
haerta at haerta.de
Thu May 16 06:18:59 PDT 2019
Thanks for your answer but it didn't help. PIP downloaded the packages
again and re-installed same version. The result in the browser is an
error 500 and the log shows exactly the same error :-(
On 16/05/2019 14:58, Alessio Fabiani wrote:
> Maybe try to run a
> pip install -e .
> from inside the GeoNode source code
> Il giorno gio 16 mag 2019 alle ore 14:50 Michael Härtel
> <haerta at haerta.de <mailto:haerta at haerta.de>> ha scritto:
> Hello Alessio, list
> I tried to incorporate your changes. I followed these steps:
> * Downloaded "geonode-ISSUE_-4401.zip" from github
> * unpacked the contents of the ZIP file to
> "/home/geo/Envs/geonode/src/geonode" (I followed the
> instructions from this
> <http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
> link to set up geonode).
> * Deleted all pyc files in /home/geo
> * restarted apache
> What I get is this error. Strange enough is that I get same error
> when I roll back the changes (copy the backup folder back to
> /home/geo/Envs/geonode/src/geonode).
> [Thu May 16 13:42:42.686733 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] mod_wsgi
> (pid=22537): Exception occurred processing WSGI script
> '/home/geonode/my_geonode/my_geonode/wsgi.py'.
> [Thu May 16 13:42:42.686885 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] Traceback (most
> recent call last):
> [Thu May 16 13:42:42.687030 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] File
> "/home/geonode/my_geonode/my_geonode/wsgi.py", line 44, in <module>
> [Thu May 16 13:42:42.687205 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] application =
> get_wsgi_application()
> [Thu May 16 13:42:42.687284 2019] [wsgi:error] [pid 22537] [remote
> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/wsgi.py",
> line 14, in get_wsgi_application
> [Thu May 16 13:42:42.687425 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] django.setup()
> [Thu May 16 13:42:42.687541 2019] [wsgi:error] [pid 22537] [remote
> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/__init__.py",
> line 17, in setup
> [Thu May 16 13:42:42.687677 2019] [wsgi:error] [pid 22537] [remote
> configure_logging(settings.LOGGING_CONFIG, settings.LOGGING)
> [Thu May 16 13:42:42.687777 2019] [wsgi:error] [pid 22537] [remote
> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/conf/__init__.py",
> line 48, in __getattr__
> [Thu May 16 13:42:42.687964 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] self._setup(name)
> [Thu May 16 13:42:42.688062 2019] [wsgi:error] [pid 22537] [remote
> line 44, in _setup
> [Thu May 16 13:42:42.688154 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] self._wrapped =
> Settings(settings_module)
> [Thu May 16 13:42:42.688237 2019] [wsgi:error] [pid 22537] [remote
> line 92, in __init__
> [Thu May 16 13:42:42.688322 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] mod =
> importlib.import_module(self.SETTINGS_MODULE)
> [Thu May 16 13:42:42.688395 2019] [wsgi:error] [pid 22537] [remote
> "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
> [Thu May 16 13:42:42.688510 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] __import__(name)
> [Thu May 16 13:42:42.688585 2019] [wsgi:error] [pid 22537] [remote
> "/home/geonode/my_geonode/my_geonode/settings.py", line 30, in
> <module>
> [Thu May 16 13:42:42.688709 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] from
> geonode.settings import *
> [Thu May 16 13:42:42.688799 2019] [wsgi:error] [pid 22537] [remote
> 172.30.1.13:41727 <http://172.30.1.13:41727>] ImportError: No
> module named geonode.settings
> I blieve I lack some basic understanding here. Can you help?
> Thank you very much,
> Michael
> On 16/05/2019 12:44, Michael Härtel wrote:
>> Hello Alessio,
>> thank you very much for your efforts. I will give it a try.
>> Just 10 minutes ago I set up a local VM with 2.10 rc5 and I can
>> confirm that the layer uploads works perfectly for me with the
>> included geoserver 2.14.2.
>> (What I noted is that the admin link to geoserver from within
>> geonode didn't work in DEV mode (paver start): The url it points
>> to is "http://localhost:8000/gs/" <http://localhost:8000/gs/> but
>> I get a 404 (see output below). This isn't a big problem because
>> I don't intend to use DEV mode at all. I also didn't examine this
>> issue yet.)
>> Thanks again, I will try to fix my 2.8.1 version and keep you
>> informed
>> Regards,
>> Michael
>> output from geonode after click on geoserver link in admin menu:
>> Page not found (404)
>> Request Method: GET
>> Request URL: http://localhost:8000/gs/
>> Using the URLconf defined in geonode.urls, Django tried these URL
>> patterns, in this order:
>> ^$ [name='home']
>> ^help/$ [name='help']
>> ^developer/$ [name='developer']
>> ^about/$ [name='about']
>> ^privacy_cookies/$ [name='privacy-cookies']
>> ^layers/
>> ^maps/
>> ^catalogue/
>> ^data.json$ [name='data_json']
>> ^ident.json$ [name='ident_json']
>> ^h_keywords_api$ [name='h_keywords_api']
>> ^search/$ [name='search']
>> ^account/
>> ^invitations/
>> ^people/
>> ^avatar/
>> ^comments/
>> ^ratings/
>> ^activity/
>> ^announcements/
>> ^messages/
>> ^social/
>> ^security/
>> ^account/ajax_login$ [name='account_ajax_login']
>> ^account/ajax_lookup$ [name='account_ajax_lookup']
>> ^account/moderation_sent/(?P<inactive_user>[^/]*)$
>> [name='moderator_contacted']
>> ^lang\.js$ [name='lang']
>> ^jsi18n/$ [name='javascript-catalog']
>> ^sitemap\.xml$ [name='sitemap']
>> ^robots\.txt$ [name='robots']
>> ^autocomplete/
>> ^groups/
>> ^documents/
>> ^services/
>> ^o/
>> ^api/o/v4/tokeninfo [name='tokeninfo']
>> ^api/o/v4/userinfo [name='userinfo']
>> ^api/roles [name='roles']
>> ^api/adminRole [name='adminRole']
>> ^api/users [name='users']
>> ^(?P<api_name>api)/$ [name='api_api_top_level']
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^en/
>> ^i18n/
>> ^showmetadata/
>> ^upload/
>> ^capabilities/layer/(?P<layerid>\d+)/$
>> [name='capabilities_layer']
>> ^capabilities/map/(?P<mapid>\d+)/$ [name='capabilities_map']
>> ^capabilities/user/(?P<user>[\w. at +-]+)/$ [name='capabilities_user']
>> ^capabilities/category/(?P<category>\w+)/$
>> [name='capabilities_category']
>> ^gs/ ^rest/stores/(?P<store_type>\w+)/$ [name='stores']
>> ^gs/ ^rest/styles
>> ^gs/ ^rest/workspaces
>> ^gs/ ^rest/workspaces/(?P<workspace>\w+)/styles
>> ^gs/ ^rest/layers
>> ^gs/ ^rest/imports
>> ^gs/ ^rest/sldservice
>> ^gs/ ^ows [name='ows_endpoint']
>> ^gs/ ^gwc [name='gwc_endpoint']
>> ^gs/ ^wms [name='wms_endpoint']
>> ^gs/ ^wfs [name='wfs_endpoint']
>> ^gs/ ^wcs [name='wcs_endpoint']
>> ^gs/ ^wps [name='wps_endpoint']
>> ^gs/ ^pdf [name='pdf_endpoint']
>> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/ows
>> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wms
>> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wfs
>> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wcs
>> ^gs/ ^updatelayers/$ [name='updatelayers']
>> ^gs/ ^(?P<layername>[^/]*)/style$ [name='layer_style']
>> ^gs/ ^(?P<layername>[^/]*)/style/upload$
>> [name='layer_style_upload']
>> ^gs/ ^(?P<layername>[^/]*)/style/manage$
>> [name='layer_style_manage']
>> ^gs/ ^(?P<layername>[^/]*)/edit-check?$
>> [name='feature_edit_check']
>> ^gs/ ^(?P<layername>[^/]*)/style-check?$
>> [name='style_edit_check']
>> ^gs/ ^acls/?$ [name='layer_acls']
>> ^gs/ ^resolve_user/?$ [name='layer_resolve_user']
>> ^gs/ ^download$ [name='layer_batch_download']
>> ^gs/ ^online/?$ [name='server_online']
>> ^notifications/
>> ^ ^api/ows_endpoints/
>> ^proxy/ [name='proxy']
>> ^download/(?P<resourceid>[^/]*)$ [name='download']
>> ^static\/(?P<path>.*)$
>> ^uploaded\/(?P<path>.*)$
>> ^featured/(?P<site>[A-Za-z0-9_\-]+)/$
>> ^featured/(?P<site>[A-Za-z0-9_\-]+)/info$
>> The current path, gs/, didn't match any of these.
>> You're seeing this error because you have DEBUG = True in your
>> Django settings file. Change that to False, and Django will
>> display a standard 404 page.
>> On 16/05/2019 11:49, Alessio Fabiani wrote:
>>> Dear Michael,
>>> fwi I did a PR [1] backporting most of the fixes currently
>>> available on 2.10
>>> Once this will be merged, you will need to update the GeoNode
>>> 2.8 code base accordingly and run again migrations and
>>> collectstatic commands.
>>> [1] - https://github.com/GeoNode/geonode/pull/4402
>>> Il giorno lun 6 mag 2019 alle ore 22:36 Michael Härtel
>>> Hello Alessio,
>>> I installed mod_security and was able to produce more
>>> information by capturing the POST data. I attached the
>>> logfile to this mail.
>>> Michael
>>> On 06/05/2019 10:00, Alessio Fabiani wrote:
>>>> Hello Michael,
>>>> I'm going to do some checks on 2.8 branches and probably
>>>> backport some fixes in the next few days.
>>>> I'll keep you posted about that.
>>>> Alessio.
>>>> Il giorno sab 4 mag 2019 alle ore 00:08 Michael Härtel
>>>> Hello List,
>>>> I followed the instructions from here to install geonode:
>>>> Despite the fact that the url to Geonode from the
>>>> tutorial
>>>> ("--template=https://github.com/GeoNode/geonode-project/archive/2.8.0.zip")
>>>> is not available and I had a hard time to find a URL
>>>> that worked for me (I used the ZIP from GIT/2.8.x
>>>> branch), I eventuelly got everything working apart from
>>>> the layer upload.
>>>> I have no idea, how to debug this issue:
>>>> * The apache error.log does not show any entry.
>>>> * The apache access.log only shows an error 500
>>>> * The database doesn't show any relevant entry
>>>> * GeoServer doesn't show any relevant entry (Even
>>>> with VERBODE logging).
>>>> It seems that the file never reaches the server so the
>>>> "saved_layer" variable is empty/none/null (I am not a
>>>> Python programmer) in line 294 of
>>>> "/home/geo/Envs/geonode/src/geonode/geonode/layers/views.py"
>>>> Where is the relevant configuration?
>>>> * the directory and sub directories of
>>>> "/home/geonode/my_geonode/my_geonode/uploaded" has
>>>> correct permissions (even tested with "chmod -R
>>>> ugo+rwx /home/geonode/my_geonode/my_geonode/uploaded"
>>>> * the apache file
>>>> /etc/apache2/sites-available/geonode.conf has
>>>> correct entries:
>>>> Alias /uploaded/
>>>> /home/geonode/my_geonode/my_geonode/uploaded/
>>>> <Directory
>>>> "/home/geonode/my_geonode/my_geonode/uploaded/layers/">
>>>> Is there anyone who can tell me what else to check or
>>>> how to debug this issue?
>>>> When I select some shape files and click "upload
>>>> files", the DEBUG output on the web page looks like this:
>>>> no attribute 'charset' Request Method: POST Request
>>>> URL: http://geoportal.dummy.org/layers/upload Django
>>>> Version: 1.8.19 Python Executable: /usr/bin/python
>>>> Python Version: 2.7.12 Python Path:
>>>> ['/home/geonode/my_geonode',
>>>> '/home/geo/Envs/geonode/lib/python2.7/site-packages',
>>>> '/home/geo/Envs/geonode/src/geonode',
>>>> '/home/dummygeonode/my_geonode', '/usr/lib/python2.7',
>>>> '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>>> '/usr/lib/python2.7/lib-tk',
>>>> '/usr/lib/python2.7/lib-old',
>>>> '/usr/lib/python2.7/lib-dynload',
>>>> '/usr/local/lib/python2.7/dist-packages',
>>>> '/usr/lib/python2.7/dist-packages',
>>>> '/usr/lib/python2.7/dist-packages/PILcompat',
>>>> '/var/www', '/var/www'] Server time: Fri, 3 May 2019
>>>> 21:36:06 +0000 Installed Applications:
>>>> ('modeltranslation', 'django.contrib.auth',
>>>> 'django.contrib.contenttypes',
>>>> 'django.contrib.sessions', 'django.contrib.sites',
>>>> 'django.contrib.admin', 'django.contrib.sitemaps',
>>>> 'django.contrib.staticfiles',
>>>> 'django.contrib.messages', 'django.contrib.humanize',
>>>> 'django.contrib.gis', 'dj_pagination', 'taggit',
>>>> 'treebeard', 'geoexplorer', 'leaflet',
>>>> 'bootstrap3_datetime', 'django_extensions',
>>>> 'django_basic_auth', 'autocomplete_light', 'mptt',
>>>> 'storages', 'floppyforms', 'pinax_theme_bootstrap',
>>>> 'django_forms_bootstrap', 'avatar', 'dialogos',
>>>> 'agon_ratings', 'announcements', 'actstream',
>>>> 'user_messages', 'tastypie', 'polymorphic', 'guardian',
>>>> 'oauth2_provider', 'corsheaders', 'invitations',
>>>> 'allauth', 'allauth.account', 'allauth.socialaccount',
>>>> 'rest_framework', 'geonode', 'geonode.api',
>>>> 'geonode.base', 'geonode.layers', 'geonode.maps',
>>>> 'geonode.documents', 'geonode.security',
>>>> 'geonode.catalogue', 'geonode.people',
>>>> 'geonode.client', 'geonode.themes', 'geonode.proxy',
>>>> 'geonode.social', 'geonode.groups', 'geonode.services',
>>>> 'geonode.geoserver', 'geonode.upload', 'geonode.tasks',
>>>> 'geonode.messaging', 'geonode.contrib.metadataxsl',
>>>> 'geonode.contrib.api_basemaps',
>>>> 'geonode.contrib.ows_api', 'pinax.notifications',
>>>> 'geonode.contrib.monitoring', 'my_geonode', , )
>>>> Installed Middleware:
>>>> ('corsheaders.middleware.CorsMiddleware',
>>>> 'django.middleware.common.CommonMiddleware',
>>>> 'django.contrib.sessions.middleware.SessionMiddleware',
>>>> 'django.contrib.messages.middleware.MessageMiddleware',
>>>> 'dj_pagination.middleware.PaginationMiddleware',
>>>> 'django.middleware.locale.LocaleMiddleware',
>>>> 'django.middleware.csrf.CsrfViewMiddleware',
>>>> 'django.contrib.auth.middleware.AuthenticationMiddleware',
>>>> 'django.middleware.clickjacking.XFrameOptionsMiddleware',
>>>> 'django.middleware.security.SecurityMiddleware',
>>>> 'django.contrib.auth.middleware.SessionAuthenticationMiddleware',
>>>> 'oauth2_provider.middleware.OAuth2TokenMiddleware',
>>>> 'geonode.contrib.monitoring.middleware.MonitoringMiddleware')
>>>> Traceback: File
>>>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/handlers/base.py"
>>>> in get_response 132. response =
>>>> wrapped_callback(request, *callback_args,
>>>> **callback_kwargs) File
>>>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/contrib/auth/decorators.py"
>>>> in _wrapped_view 22. return view_func(request, *args,
>>>> **kwargs) File
>>>> in layer_upload 294. out[_k] =
>>>> out[_k].decode(saved_layer.charset).encode("utf-8")
>>>> Exception Type: AttributeError at /layers/upload
>>>> Exception Value: 'NoneType' object has no attribute
>>>> 'charset' Request information: GET: No GET data POST:
>>>> charset = u'UTF-8' permissions =
>>>> u'{"users":{"AnonymousUser":["view_resourcebase","download_resourcebase"]},"groups":{}}'
>>>> FILES: shx_file = base_file = shp_file = dbf_file =
>>>> prj_file = COOKIES: csrftoken =
>>>> 'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn' sessionid =
>>>> 'h0bcxlw4nutyik4kb63ao9d3pzxud6hq' _ga =
>>>> 'GA1.2.1615965258.1556718183' META:
>>>> mod_wsgi.listener_port = '80' HTTP_REFERER =
>>>> 'http://geoportal.dummy.org/layers/upload'
>>>> mod_wsgi.listener_host = '' HTTP_REVERSE_VIA = 'IPGW2'
>>>> CONTEXT_DOCUMENT_ROOT =
>>>> '/home/geonode/my_geonode/my_geonode' SERVER_SOFTWARE =
>>>> 'Apache/2.4.18 (Ubuntu)' SCRIPT_NAME = u''
>>>> mod_wsgi.enable_sendfile = '0' HTTP_X_CSRFTOKEN =
>>>> 'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn' SERVER_SIGNATURE = '
>>>> Apache/2.4.18 (Ubuntu) Server at geoportal.dummy.org
>>>> <http://geoportal.dummy.org> Port 80
>>>> \n' REQUEST_METHOD = 'POST' PATH_INFO =
>>>> u'/layers/upload' SERVER_PROTOCOL = 'HTTP/1.1'
>>>> QUERY_STRING = '' CONTENT_LENGTH = '4451'
>>>> HTTP_USER_AGENT = 'Mozilla/5.0 (Windows NT 10.0; Win64;
>>>> x64; rv:66.0) Gecko/20100101 Firefox/66.0'
>>>> HTTP_CONNECTION = 'Keep-Alive' HTTP_COOKIE =
>>>> 'csrftoken=RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn;
>>>> _ga=GA1.2.1615965258.1556718183;
>>>> sessionid=h0bcxlw4nutyik4kb63ao9d3pzxud6hq' SERVER_NAME
>>>> = 'geoportal.dummy.org <http://geoportal.dummy.org>'
>>>> REMOTE_ADDR = '172.30.1.13' mod_wsgi.handler_script =
>>>> '' mod_wsgi.request_handler = 'wsgi-script'
>>>> apache.version = wsgi.url_scheme = 'http'
>>>> PATH_TRANSLATED =
>>>> '/home/geonode/my_geonode/my_geonode/wsgi.py/layers/upload
>>>> <http://wsgi.py/layers/upload>' SERVER_PORT = '80'
>>>> mod_wsgi.queue_start = '1556919366052407'
>>>> wsgi.multiprocess = True mod_wsgi.input_chunked = '0'
>>>> SERVER_ADDR = '172.30.1.167' DOCUMENT_ROOT =
>>>> mod_wsgi.process_group = 'geonode'
>>>> HTTP_X_REQUESTED_WITH = 'XMLHttpRequest'
>>>> mod_wsgi.daemon_connects = '1' SCRIPT_FILENAME =
>>>> SERVER_ADMIN = 'webmaster at localhost' wsgi.input =
>>>> HTTP_HOST = 'geoportal.dummy.org
>>>> <http://geoportal.dummy.org>' CONTEXT_PREFIX = ''
>>>> wsgi.multithread = True mod_wsgi.callable_object =
>>>> 'application' mod_wsgi.daemon_restarts = '0'
>>>> REQUEST_URI = '/layers/upload' HTTP_ACCEPT = '*/*'
>>>> wsgi.file_wrapper = '' wsgi.version = GATEWAY_INTERFACE
>>>> = 'CGI/1.1' wsgi.run_once = False wsgi.errors =
>>>> REMOTE_PORT = '25591' HTTP_ACCEPT_LANGUAGE =
>>>> 'en-GB,en;q=0.5' REQUEST_SCHEME = 'http'
>>>> mod_wsgi.version = mod_wsgi.script_start =
>>>> '1556919366052600' CONTENT_TYPE = 'multipart/form-data;
>>>> boundary=---------------------------75853149526340'
>>>> mod_wsgi.application_group = 'geoportal.cgiarad.org
>>>> <http://geoportal.cgiarad.org>|'
>>>> mod_wsgi.script_reloading = '1' mod_wsgi.request_start
>>>> = '1556919366052122' CSRF_COOKIE =
>>>> u'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn'
>>>> mod_wsgi.daemon_start = '1556919366052568' Settings:
>>>> Using settings module my_geonode.settings
>>>> BROKER_TRANSPORT_OPTIONS = {'fanout_prefix': True,
>>>> 'fanout_patterns': True, 'visibility_timeout': 86400,
>>>> 'socket_timeout': 60} EMAIL_USE_TLS = False
>>>> CELERY_SEND_TASK_SENT_EVENT = True
>>>> DOWNLOAD_FORMATS_METADATA = ['Atom', 'DIF', 'Dublin
>>>> Core', 'ebRIM', 'FGDC', 'ISO', 'ISO with XSL']
>>>> SESSION_SERIALIZER =
>>>> 'django.contrib.sessions.serializers.PickleSerializer'
>>>> ACCOUNT_EMAIL_REQUIRED = True OGC_SERVER_DEFAULT_USER =
>>>> 'admin' MESSAGE_STORAGE =
>>>> 'django.contrib.messages.storage.fallback.FallbackStorage'
>>>> WSGI_APPLICATION = 'my_geonode.wsgi.application'
>>>> SESSION_COOKIE_NAME = 'sessionid' CELERY_BROKER_URL =
>>>> 'memory://' VERSION = '2.8.1rc0' AWS_BUCKET_NAME = ''
>>>> ACCOUNT_CONFIRM_EMAIL_ON_GET = True EMAIL_SSL_KEYFILE =
>>>> u'********************' SERVER_EMAIL = 'root at localhost'
>>>> ACCOUNT_EMAIL_VERIFICATION = 'optional'
>>>> FIRST_DAY_OF_WEEK = 0 CACHES = {'default': {'BACKEND':
>>>> 'django.core.cache.backends.dummy.DummyCache'}}
>>>> CKAN_ORIGINS = [{'url':
>>>> 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}¬es={abstract}&caveats={caveats}',
>>>> 'css_class': 'hdx', 'label': 'Humanitarian Data
>>>> Exchange (HDX)'}] SESSION_COOKIE_PATH = '/'
>>>> UNOCONV_ENABLE = 1 MISSING_THUMBNAIL =
>>>> 'geonode/img/missing_thumb.png'
>>>> MODELTRANSLATION_FALLBACK_LANGUAGES = 'en'
>>>> PINAX_NOTIFICATIONS_HOOKSET = CELERY_TASK_IGNORE_RESULT
>>>> = True DEFAULT_INDEX_TABLESPACE = ''
>>>> MONITORING_HOST_NAME = 'localhost' THESAURI = []
>>>> USE_X_FORWARDED_HOST = False TWITTER_HASHTAGS =
>>>> ['geonode'] PUBLIC_GEOSERVER = {'source': {'url':
>>>> 'http://localhost:8080/geoserver/ows', 'restUrl':
>>>> '/gs/rest', 'attribution': '© http://localhost:8000/',
>>>> 'ptype': 'gxp_wmscsource', 'title': 'GeoServer - Public
>>>> Layers'}} GUARDIAN_GET_INIT_ANONYMOUS_USER =
>>>> 'geonode.people.models.get_anonymous_user_instance'
>>>> CSRF_COOKIE_DOMAIN = None FILE_CHARSET = 'utf-8' DEBUG
>>>> = True SESSION_FILE_PATH = None DISPLAY_COMMENTS = 1
>>>> DATABASE_ENGINE = 'postgresql_psycopg2'
>>>> STATICFILES_DIRS = ['/etc/geonode/media',
>>>> '/home/geo/Envs/geonode/src/geonode/geonode/static',
>>>> '/home/geonode/my_geonode/my_geonode/static']
>>>> CELERY_TASK_CREATE_MISSING_QUEUES = True
>>>> SECURE_PROXY_SSL_HEADER = None AWS_SECRET_ACCESS_KEY =
>>>> u'********************' DEBUG_PROPAGATE_EXCEPTIONS =
>>>> False MONTH_DAY_FORMAT = 'F j' SEARCH_FILTERS =
>>>> {'REGION_ENABLED': True, 'EXTENT_ENABLED': True,
>>>> 'DATE_ENABLED': True, 'KEYWORDS_ENABLED':
>>>> u'********************', 'CATEGORIES_ENABLED': True,
>>>> 'TYPE_ENABLED': True, 'T_KEYWORDS_ENABLED':
>>>> u'********************', 'OWNERS_ENABLED': True,
>>>> 'H_KEYWORDS_ENABLED': u'********************',
>>>> 'TEXT_ENABLED': True} THUMBNAIL_GENERATOR =
>>>> 'geonode.layers.utils.create_gs_thumbnail_geonode'
>>>> AUTH_USER_MODEL = 'people.Profile'
>>>> USE_THOUSAND_SEPARATOR = False UNOCONV_TIMEOUT = 30
>>>> CELERY_DISABLE_RATE_LIMITS = False CSRF_FAILURE_VIEW =
>>>> 'django.views.csrf.csrf_failure'
>>>> CELERY_WORKER_SEND_TASK_EVENTS = True
>>>> CELERY_TASK_SERIALIZER = 'json' DECIMAL_SEPARATOR = '.'
>>>> IGNORABLE_404_URLS = NOSE_ARGS = ['--nocapture',
>>>> '--detailed-errors'] TEMPLATE_STRING_IF_INVALID = ''
>>>> FIXTURE_DIRS = SOCIALACCOUNT_AUTO_SIGNUP = False
>>>> PINAX_NOTIFICATIONS_BACKENDS = {(0, 'email'): }
>>>> FORMAT_MODULE_PATH = None ALLOWED_DOCUMENT_TYPES =
>>>> ['doc', 'docx', 'gif', 'jpg', 'jpeg', 'ods', 'odt',
>>>> 'odp', 'pdf', 'png', 'ppt', 'pptx', 'rar', 'sld',
>>>> 'tif', 'tiff', 'txt', 'xls', 'xlsx', 'xml', 'zip',
>>>> 'gz', 'qml'] RESOURCE_PUBLISHING = False
>>>> DISALLOWED_USER_AGENTS = DEFAULT_LAYER_FORMAT =
>>>> 'image/png' THUNDERFOREST_BASEMAPS = False
>>>> CELERY_REDIRECT_STDOUTS = True SITENAME = 'my_geonode'
>>>> CELERY_MESSAGE_COMPRESSION = 'gzip' USE_ETAGS = False
>>>> DISPLAY_WMS_LINKS = True GEOTIFF_IO_ENABLED = 0
>>>> PINAX_NOTIFICATIONS_GET_LANGUAGE_MODEL = at
>>>> 0x7f8c98343c80> USE_TZ = True SHORT_DATETIME_FORMAT =
>>>> 'm/d/Y P' LANGUAGE_COOKIE_PATH = '/' MAX_DOCUMENT_SIZE
>>>> = 2 YEAR_MONTH_FORMAT = 'F Y' AWS_QUERYSTRING_AUTH =
>>>> False CELERY_SEND_TASK_EVENTS = True LANGUAGE_CODE =
>>>> 'en' ROOT_URLCONF = 'my_geonode.urls' LOGIN_URL =
>>>> '/account/login/' DEFAULT_MAP_CENTER = DATABASE_HOST =
>>>> 'localhost' TEMPLATE_DIRS = BROKER_HEARTBEAT = 0
>>>> SESSION_CACHE_ALIAS = 'default' SESSION_COOKIE_DOMAIN =
>>>> None PINAX_NOTIFICATIONS_QUEUE_ALL = False
>>>> FILE_UPLOAD_PERMISSIONS = None BING_API_KEY =
>>>> u'********************' APPEND_SLASH = True
>>>> DATABASE_ROUTERS = [] STAMEN_BASEMAPS = False
>>>> GEOSERVER_LOCATION = 'http://localhost/geoserver/'
>>>> INVITATIONS_ADAPTER =
>>>> 'geonode.people.adapters.LocalAccountAdapter' HOSTNAME
>>>> = 'localhost' EXIF_ENABLED = False CATALOGUE =
>>>> {'default': {'ENGINE':
>>>> 'geonode.catalogue.backends.pycsw_local', 'URL':
>>>> 'http://geoportal.dummy.org/catalogue/csw'}}
>>>> LOCKDOWN_GEONODE = 0 MIDDLEWARE_CLASSES = USE_I18N = 1
>>>> LANGUAGE_COOKIE_NAME = 'django_language'
>>>> CELERY_TASK_ALWAYS_EAGER = True TEST_RUNNER_PARALLEL =
>>>> 0 CELERYD_HIJACK_ROOT_LOGGER = True HAYSTACK_SEARCH = 0
>>>> X_FRAME_OPTIONS = 'DENY' UNOCONV_EXECUTABLE =
>>>> '/usr/bin/unoconv' OAUTH2_PROVIDER = {'SCOPES':
>>>> {'read': 'Read scope', 'write': 'Write scope',
>>>> 'groups': 'Access to your groups'},
>>>> 'CLIENT_ID_GENERATOR_CLASS':
>>>> 'oauth2_provider.generators.ClientIdGenerator'}
>>>> GEOSERVER_PUBLIC_LOCATION =
>>>> 'http://geoportal.dummy.org/geoserver/' SECURE_SSL_HOST
>>>> = None NLP_ENABLED = False MONITORING_DISABLE_CSRF =
>>>> False SOCIAL_ORIGINS = [{'url':
>>>> 'mailto:?subject={name}&body={url}', 'css_class':
>>>> 'email', 'label': 'Email'}, {'url':
>>>> 'http://www.facebook.com/sharer.php?u={url}',
>>>> 'css_class': 'fb', 'label': 'Facebook'}, {'url':
>>>> 'https://twitter.com/share?url={url}&hashtags={hashtags}',
>>>> 'css_class': 'tw', 'label': 'Twitter'}, {'url':
>>>> 'https://plus.google.com/share?url={url}', 'css_class':
>>>> 'gp', 'label': 'Google +'}] PREPEND_WWW = False
>>>> AUTH_IP_WHITELIST = [] DATABASE_PORT = '5432'
>>>> DEFAULT_ANONYMOUS_VIEW_PERMISSION = 1 GOOGLE_API_KEY =
>>>> u'********************' GEOIP_PATH =
>>>> '/usr/local/share/GeoIP' ADMIN_MODERATE_UPLOADS = False
>>>> TASTYPIE_DEFAULT_FORMATS = ['json']
>>>> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION = 1
>>>> FORCE_SCRIPT_NAME = None DISPLAY_RATINGS = 1
>>>> TEST_RUNNER_KEEPDB = 0 PASSWORD_RESET_TIMEOUT_DAYS =
>>>> u'********************' DEFAULT_SEARCH_SIZE = 10
>>>> CELERYD_CONCURENCY = 1 SESSION_ENGINE =
>>>> 'django.contrib.sessions.backends.db'
>>>> API_INCLUDE_REGIONS_COUNT = u'********************'
>>>> PINAX_NOTIFICATIONS_LOCK_WAIT_TIMEOUT = -1
>>>> MIGRATION_MODULES = {} NLP_MODEL_PATH =
>>>> '/opt/MITIE/MITIE-models/english/ner_model.dat'
>>>> PROXY_ALLOWED_HOSTS = ['geoportal.dummy.org
>>>> <http://geoportal.dummy.org>', 'geoportal.cgiarad.org
>>>> <http://geoportal.cgiarad.org>', '172.30.1.167',
>>>> 'localhost'] CARTODB_BASEMAPS = False
>>>> SECURE_BROWSER_XSS_FILTER = True GEONODE_CONTRIB_APPS =
>>>> SRID = {'DETAIL': 'never'}
>>>> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE =
>>>> u'********************' AGON_RATINGS_CATEGORY_CHOICES =
>>>> {'maps.Map': {'map': 'How good is this map?'},
>>>> 'layers.Layer': {'layer': 'How good is this layer?'},
>>>> 'documents.Document': {'document': 'How good is this
>>>> document?'}} DEFAULT_EXCEPTION_REPORTER_FILTER =
>>>> 'django.views.debug.SafeExceptionReporterFilter' ADMINS
>>>> = [] MONITORING_DATA_TTL = datetime.timedelta(7)
>>>> GEOSERVER_EXCHANGE = CELERY_ACCEPT_CONTENT = ['json']
>>>> LOCAL_MEDIA_URL = '/uploaded/' LOGOUT_URL =
>>>> '/account/logout/' USE_GEOSERVER = True EXTRA_LANG_INFO
>>>> = {'tl': {'code': 'tl', 'name': 'Tagalog', 'bidi':
>>>> False, 'name_local': 'tagalog'}, 'am': {'code': 'am',
>>>> 'name': 'Amharic', 'bidi': False, 'name_local':
>>>> 'Amharic'}, 'si': {'code': 'si', 'name': 'Sinhala',
>>>> 'bidi': False, 'name_local': 'sinhala'}, 'ta': {'code':
>>>> 'ta', 'name': 'Tamil', 'bidi': False, 'name_local':
>>>> u'tamil'}} SHOW_PROFILE_EMAIL = False CELERYD_LOG_LEVEL
>>>> = 1 DATABASE_USER = 'geonode' TEMPLATES = [{'DIRS':
>>>> ['/home/geonode/my_geonode/my_geonode/templates',
>>>> '/home/geo/Envs/geonode/src/geonode/geonode/templates'],
>>>> 'OPTIONS': {'debug': 1, 'context_processors':
>>>> ['django.template.context_processors.debug',
>>>> 'django.template.context_processors.i18n',
>>>> 'django.template.context_processors.tz
>>>> <http://django.template.context_processors.tz>',
>>>> 'django.template.context_processors.request',
>>>> 'django.template.context_processors.media',
>>>> 'django.template.context_processors.static',
>>>> 'django.contrib.auth.context_processors.auth',
>>>> 'django.contrib.messages.context_processors.messages',
>>>> 'geonode.context_processors.resource_urls',
>>>> 'geonode.geoserver.context_processors.geoserver_urls',
>>>> 'geonode.themes.context_processors.custom_theme'],
>>>> 'loaders':
>>>> ['django.template.loaders.filesystem.Loader',
>>>> 'django.template.loaders.app_directories.Loader']},
>>>> 'NAME': 'GeoNode Project Templates', 'BACKEND':
>>>> 'django.template.backends.django.DjangoTemplates'}]
>>>> EMAIL_SSL_CERTFILE = None CELERY_TASK_QUEUES =
>>>> DEFAULT_WORKSPACE = 'geonode' ASYNC_SIGNALS = False
>>>> LOCAL_GEOSERVER = {'source': {'url':
>>>> 'http://geoportal.dummy.org/geoserver/wms', 'restUrl':
>>>> '/gs/rest', 'ptype': 'gxp_wmscsource'}}
>>>> DEFAULT_TABLESPACE = '' CELERY_ACKS_LATE = True
>>>> EMAIL_ENABLE = True SESSION_COOKIE_AGE = 1209600
>>>> THEME_ACCOUNT_CONTACT_EMAIL = 'admin at example.com
>>>> <mailto:admin at example.com>' NOTIFICATION_ENABLED = True
>>>> LANGUAGES = CELERY_TASK_RESULT_EXPIRES = 43200
>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'geoext'
>>>> ABSOLUTE_URL_OVERRIDES = {} OGC_SERVER_DEFAULT_PASSWORD
>>>> = u'********************' CACHE_MIDDLEWARE_SECONDS =
>>>> 600 CSRF_COOKIE_HTTPONLY = False TEST = False
>>>> EMAIL_HOST_USER = 'Geoportal dummy ' CASCADE_WORKSPACE
>>>> = 'geonode' CSRF_COOKIE_SECURE = False
>>>> CELERY_TRACK_STARTED = True UPLOADER =
>>>> {'SUPPORTED_CRS': ['EPSG:4326', 'EPSG:3785',
>>>> 'EPSG:3857', 'EPSG:900913', 'EPSG:32647',
>>>> 'EPSG:32736'], 'BACKEND': 'geonode.rest', 'OPTIONS':
>>>> {'TIME_ENABLED': False, 'MOSAIC_ENABLED': False,
>>>> 'GEOGIG_ENABLED': False}, 'SUPPORTED_EXT': ['.shp',
>>>> '.csv', '.kml', '.kmz', '.json', '.geojson', '.tif',
>>>> '.tiff', '.geotiff', '.gml', '.xml']} LICENSES =
>>>> {'ENABLED': True, 'DETAIL': 'above', 'METADATA':
>>>> 'verbose'} EMAIL_HOST_PASSWORD =
>>>> u'********************' PYCSW = {'CONFIGURATION':
>>>> {'metadata:main': {'identification_fees': 'None',
>>>> 'provider_url': 'http://geoportal.dummy.org/',
>>>> 'identification_keywords': 'sdi, catalogue, discovery,
>>>> metadata, GeoNode', 'contact_address': 'Mailing
>>>> Address', 'identification_accessconstraints': 'None',
>>>> 'contact_name': 'Lastname, Firstname',
>>>> 'contact_stateorprovince': 'Administrative Area',
>>>> 'contact_country': 'Country', 'contact_url': 'Contact
>>>> URL', 'provider_name': 'Organization Name',
>>>> 'contact_phone': '+xx-xxx-xxx-xxxx', 'contact_hours':
>>>> 'Hours of Service', 'contact_role': 'pointOfContact',
>>>> 'contact_email': 'Email Address',
>>>> 'identification_title': 'GeoNode Catalogue',
>>>> 'contact_postalcode': 'Zip or Postal Code',
>>>> 'contact_city': 'City', 'identification_keywords_type':
>>>> 'theme', 'identification_abstract': 'GeoNode is an open
>>>> source platform that facilitates the creation, sharing,
>>>> and collaborative use of geospatial data',
>>>> 'contact_fax': '+xx-xxx-xxx-xxxx',
>>>> 'contact_instructions': 'During hours of service. Off
>>>> on weekends.', 'contact_position': 'Position Title'},
>>>> 'metadata:inspire': {'languages_supported': 'eng,gre',
>>>> 'default_language': 'eng', 'temp_extent':
>>>> 'YYYY-MM-DD/YYYY-MM-DD', 'conformity_service':
>>>> 'notEvaluated', 'contact_email': 'Email Address',
>>>> 'date': 'YYYY-MM-DD', 'contact_name': 'Organization
>>>> Name', 'gemet_keywords': 'Utility and governmental
>>>> services', 'enabled': 'true'}}}
>>>> CELERY_RESULT_SERIALIZER = 'json'
>>>> AWS_STORAGE_BUCKET_NAME = ''
>>>> FILE_UPLOAD_DIRECTORY_PERMISSIONS = None LOCAL_ROOT =
>>>> FILE_UPLOAD_HANDLERS = DEFAULT_CONTENT_TYPE =
>>>> 'text/html' DEBUG_STATIC = False
>>>> MONITORING_SERVICE_NAME = 'local-geonode'
>>>> SOCIALACCOUNT_PROVIDERS = {'linkedin_oauth2': {'SCOPE':
>>>> ['r_emailaddress', 'r_basicprofile'], 'PROFILE_FIELDS':
>>>> ['emailAddress', 'firstName', 'headline', 'id',
>>>> 'industry', 'lastName', 'pictureUrl', 'positions',
>>>> 'publicProfileUrl', 'location', 'specialties',
>>>> 'summary']}, 'facebook': {'SCOPE': ['email',
>>>> 'public_profile'], 'METHOD': 'oauth2', 'FIELDS': ['id',
>>>> 'email', 'name', 'first_name', 'last_name', 'verified',
>>>> 'locale', 'timezone', 'link', 'gender']}}
>>>> STATICFILES_STORAGE =
>>>> 'django.contrib.staticfiles.storage.StaticFilesStorage'
>>>> USE_WORLDMAP = 0 SILENCED_SYSTEM_CHECKS = ['1_8.W001',
>>>> 'fields.W340'] LOGGING_CONFIG =
>>>> 'logging.config.dictConfig' TEMPLATE_LOADERS =
>>>> AUTO_GENERATE_AVATAR_SIZES = HAYSTACK_CONNECTIONS =
>>>> 'haystack.backends.elasticsearch2_backend.Elasticsearch2SearchEngine',
>>>> 'URL': 'http://127.0.0.1:9200/', 'INDEX_NAME':
>>>> 'haystack'}} GEONODE_INTERNAL_APPS =
>>>> ACCOUNT_LOGIN_REDIRECT_URL = 'http://localhost:8000/'
>>>> EMAIL_TIMEOUT = None SESSION_COOKIE_SECURE = False
>>>> GEONODE_CORE_APPS = CACHE_TIME = 0 AWS_ACCESS_KEY_ID =
>>>> u'********************' INSTALLED_APPS =
>>>> THUMBNAIL_GENERATOR_DEFAULT_BG =
>>>> 'http://a.tile.openstreetmap.org/{z}/{x}/{y}.png'
>>>> STATIC_ROOT = '/var/www/geonode/static/'
>>>> SECURE_HSTS_INCLUDE_SUBDOMAINS = True GEONODE_APPS =
>>>> SESSION_COOKIE_HTTPONLY = True DATETIME_FORMAT = 'N j,
>>>> Y, P' USER_MESSAGES_ALLOW_MULTIPLE_RECIPIENTS = True
>>>> GEOTIFF_IO_BASE_URL = 'https://app.geotiff.io'
>>>> DATE_INPUT_FORMATS = ACCOUNT_LOGOUT_REDIRECT_URL =
>>>> 'http://localhost:8000/' TWITTER_CARD = 1
>>>> CSRF_COOKIE_NAME = 'csrftoken'
>>>> SESSION_SAVE_EVERY_REQUEST = False NUMBER_GROUPING = 0
>>>> LOCALE_PATHS = GEONODE_ROOT =
>>>> '/home/geo/Envs/geonode/src/geonode/geonode' LOGGING =
>>>> {'loggers': {'geonode': {'handlers': ['applogfile'],
>>>> 'level': 'DEBUG'}, 'django': {'handlers':
>>>> ['applogfile'], 'level': 'DEBUG'}, 'pycsw':
>>>> {'handlers': ['applogfile'], 'level': 'DEBUG'},
>>>> 'owslib': {'handlers': ['applogfile'], 'level':
>>>> 'DEBUG'}, 'gsconfig.catalog': {'handlers':
>>>> ['applogfile'], 'level': 'DEBUG'}},
>>>> 'disable_existing_loggers': True, 'handlers':
>>>> {'console': {'formatter': 'simple', 'class':
>>>> 'logging.StreamHandler', 'level': 'DEBUG'},
>>>> 'applogfile': {'level': 'DEBUG', 'maxBytes': 15728640,
>>>> 'backupCount': 10, 'class':
>>>> 'logging.handlers.RotatingFileHandler', 'filename':
>>>> '/tmp/GEONODE_APP.log'}, 'mail_admins': {'class':
>>>> 'django.utils.log.AdminEmailHandler', 'filters':
>>>> ['require_debug_false'], 'level': 'ERROR'}},
>>>> 'formatters': {'simple': {'format': '%(message)s'},
>>>> 'verbose': {'format': '%(levelname)s %(asctime)s
>>>> %(module)s %(process)d %(thread)d %(message)s'}},
>>>> 'version': 1, 'filters': {'require_debug_false': {'()':
>>>> 'django.utils.log.RequireDebugFalse'}}} INTEGRATION =
>>>> False OGP_URL = 'http://geodata.tufts.edu/solr/select'
>>>> USE_L10N = 1 CELERYD_LOG_FILE = None EMAIL_HOST =
>>>> 'dummysmtp4.cgiarad.org
>>>> <http://dummysmtp4.cgiarad.org>' NLP_LOCATION_THRESHOLD
>>>> = 1.0 REST_FRAMEWORK = {'DEFAULT_PERMISSION_CLASSES':
>>>> ['rest_framework.permissions.DjangoModelPermissionsOrAnonReadOnly']}
>>>> DATABASE_NAME = 'geonode' MEDIA_URL = '/uploaded/'
>>>> RABBITMQ_SIGNALS_BROKER_URL = 'amqp://localhost:5672'
>>>> DJANGO_LIVE_TEST_SERVER_ADDRESS = 'localhost:8000'
>>>> MONITORING_ENABLED = True DOWNLOAD_FORMATS_VECTOR =
>>>> ['JPEG', 'PDF', 'PNG', 'Zipped Shapefile', 'GML 2.0',
>>>> 'GML 3.1.1', 'CSV', 'Excel', 'GeoJSON', 'KML', 'View in
>>>> Google Earth', 'Tiles', 'QGIS layer file (.qlr)', 'QGIS
>>>> project file (.qgs)'] SKIP_PERMS_FILTER = False
>>>> GEONODE_CLIENT_HOOKSET = TWITTER_SITE = '@GeoNode'
>>>> SLACK_ENABLED = False PROJECT_NAME = 'my_geonode'
>>>> TEST_RUNNER = 'django_nose.NoseTestSuiteRunner'
>>>> HAYSTACK_FACET_COUNTS = True SECURE_SSL_REDIRECT =
>>>> False TIME_ZONE = 'UTC' CORS_ORIGIN_ALLOW_ALL = True
>>>> EMAIL_BACKEND =
>>>> 'django.core.mail.backends.smtp.EmailBackend'
>>>> DEFAULT_MAP_ZOOM = 0 TEMPLATE_CONTEXT_PROCESSORS =
>>>> MAPBOX_ACCESS_TOKEN = u'********************'
>>>> S3_STATIC_ENABLED = False
>>>> PINAX_NOTIFICATIONS_LANGUAGE_MODEL = None
>>>> LANGUAGES_BIDI = HAYSTACK_SIGNAL_PROCESSOR =
>>>> 'haystack.signals.RealtimeSignalProcessor'
>>>> CLIENT_RESULTS_LIMIT = 20
>>>> MODELTRANSLATION_DEFAULT_LANGUAGE = 'en'
>>>> GEOFENCE_SECURITY_ENABLED = True SOCIALACCOUNT_ADAPTER
>>>> = 'geonode.people.adapters.SocialAccountAdapter'
>>>> DATABASE_PASSWORD = u'********************'
>>>> SECURE_HSTS_SECONDS = 3600 TEST_NON_SERIALIZED_APPS =
>>>> [] DEFAULT_CHARSET = 'utf-8' OPENGRAPH_ENABLED = 1
>>>> CELERY_MAX_CACHED_RESULTS = 32768
>>>> CELERY_RESULT_PERSISTENT = False ALLOWED_HOSTS =
>>>> ['geoportal.dummy.org <http://geoportal.dummy.org>',
>>>> 'geoportal.cgiarad.org <http://geoportal.cgiarad.org>',
>>>> '172.30.1.167', 'localhost'] OGC_SERVER = {'default':
>>>> {'BACKEND_WRITE_ENABLED': True, 'PASSWORD':
>>>> u'********************', 'WPS_ENABLED': True,
>>>> 'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
>>>> 'PUBLIC_LOCATION':
>>>> 'http://geoportal.dummy.org/geoserver/',
>>>> 'GEONODE_SECURITY_ENABLED': True, 'PRINT_NG_ENABLED':
>>>> True, 'GEOGIG_DATASTORE_DIR': '', 'PG_GEOGIG': False,
>>>> 'GEOFENCE_SECURITY_ENABLED': True, 'LOCATION':
>>>> 'http://localhost/geoserver/', 'MAPFISH_PRINT_ENABLED':
>>>> True, 'LOGOUT_ENDPOINT':
>>>> 'j_spring_oauth2_geonode_logout', 'TIMEOUT': 10,
>>>> 'WMST_ENABLED': False, 'DATASTORE': 'datastore',
>>>> 'LOG_FILE':
>>>> '/usr/share/geoserver/data/logs/geoserver.log',
>>>> 'BACKEND': 'geonode.geoserver', 'GEOGIG_ENABLED':
>>>> False, 'USER': 'admin'}} DOWNLOAD_FORMATS_RASTER =
>>>> ['JPEG', 'PDF', 'PNG', 'ArcGrid', 'GeoTIFF', 'Gtopo30',
>>>> 'ImageMosaic', 'KML', 'View in Google Earth', 'Tiles',
>>>> 'GML', 'GZIP', 'QGIS layer file (.qlr)', 'QGIS project
>>>> file (.qgs)', 'Zipped All Files'] AUTH_EXEMPT_URLS =
>>>> EMAIL_SUBJECT_PREFIX = '[Django] ' THOUSAND_SEPARATOR =
>>>> ',' STATICFILES_FINDERS = S3_MEDIA_ENABLED = False
>>>> CELERY_WORKER_DISABLE_RATE_LIMITS = False STATIC_URL =
>>>> '/static/' TIME_INPUT_FORMATS = SECURE_REDIRECT_EXEMPT
>>>> = [] DATABASES = {'default': {'ENGINE':
>>>> 'django.db.backends.postgresql_psycopg2', 'AUTOCOMMIT':
>>>> True, 'ATOMIC_REQUESTS': False, 'NAME': 'geonode',
>>>> 'CONN_MAX_AGE': 0, 'CONN_TOUT': 900, 'TIME_ZONE':
>>>> 'UTC', 'PORT': '5432', 'HOST': 'localhost', 'USER':
>>>> 'geonode', 'TEST': {'COLLATION': None, 'CHARSET': None,
>>>> 'NAME': None, 'MIRROR': None}, 'PASSWORD':
>>>> u'********************', 'OPTIONS': {}}, 'datastore':
>>>> {'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>>> 'AUTOCOMMIT': True, 'ATOMIC_REQUESTS': False, 'NAME':
>>>> 'geonode_data', 'CONN_MAX_AGE': 0, 'CONN_TOUT': 900,
>>>> 'TIME_ZONE': 'UTC', 'PORT': '5432', 'HOST':
>>>> 'localhost', 'USER': 'geonode', 'TEST': {'COLLATION':
>>>> None, 'CHARSET': None, 'NAME': None, 'MIRROR': None},
>>>> 'PASSWORD': u'********************', 'OPTIONS': {}}}
>>>> LEAFLET_CONFIG = {'SRID': 3857, 'RESET_VIEW': False,
>>>> 'TILES': [('Watercolor',
>>>> 'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png
>>>> <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>>> 'Map tiles by Stamen Design, CC BY 3.0 — Map data ©
>>>> OpenStreetMap contributors, CC-BY-SA'), ('Toner Lite',
>>>> 'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png
>>>> <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>>> OpenStreetMap contributors, CC-BY-SA')], 'PLUGINS':
>>>> {u'forms': {u'css': , u'auto-include': False, u'js': },
>>>> u'__default__': {u'css': , u'js': }, u'ALL': {u'css': ,
>>>> u'js': }, 'leaflet-plugins': {'css': , 'auto-include':
>>>> True, 'js': }, u'__is_normalized__': True}}
>>>> ACCOUNT_APPROVAL_REQUIRED = 0 DATABASE_URL =
>>>> 'sqlite:////home/geo/Envs/geonode/src/geonode/geonode/development.db'
>>>> MODELTRANSLATION_LANGUAGES = ['en'] SLACK_WEBHOOK_URLS
>>>> = ['https://hooks.slack.com/services/T000/B000/XX']
>>>> ALT_OSM_BASEMAPS = False ACCOUNT_OPEN_SIGNUP = True
>>>> ACCOUNT_ADAPTER =
>>>> SECURE_CONTENT_TYPE_NOSNIFF = True SECRET_KEY =
>>>> u'********************' FILE_UPLOAD_TEMP_DIR = None
>>>> DEFAULT_MAP_CRS = 'EPSG:900913'
>>>> DATA_UPLOAD_MAX_NUMBER_FIELDS = 100000
>>>> MAP_CLIENT_USE_CROSS_ORIGIN_CREDENTIALS = 0
>>>> REDIS_SIGNALS_BROKER_URL = 'redis://localhost:6379/0'
>>>> SETTINGS_MODULE = 'my_geonode.settings'
>>>> AUTHENTICATION_BACKENDS = CELERY_ALWAYS_EAGER = True
>>>> MODIFY_TOPICCATEGORY = True SIGNING_BACKEND =
>>>> 'django.core.signing.TimestampSigner'
>>>> LANGUAGE_COOKIE_DOMAIN = None DEFAULT_FILE_STORAGE =
>>>> 'django.core.files.storage.FileSystemStorage' SITEURL =
>>>> 'http://geoportal.dummy.org/' LANGUAGE_COOKIE_AGE =
>>>> None SOCIALACCOUNT_PROFILE_EXTRACTORS =
>>>> {'linkedin_oauth2':
>>>> 'geonode.people.profileextractors.LinkedInExtractor',
>>>> 'facebook':
>>>> 'geonode.people.profileextractors.FacebookExtractor'}
>>>> MANAGERS = [] SESSION_EXPIRE_AT_BROWSER_CLOSE = False
>>>> TIME_FORMAT = 'P' CACHE_MIDDLEWARE_ALIAS = 'default'
>>>> SERVICE_UPDATE_INTERVAL = 0 CSRF_COOKIE_PATH = '/'
>>>> NLP_LIBRARY_PATH = '/opt/MITIE/mitielib'
>>>> MONITORING_CONFIG = None CELERYD_POOL_RESTARTS = True
>>>> PROJECT_ROOT =
>>>> CACHE_MIDDLEWARE_KEY_PREFIX = u'********************'
>>>> RISKS = {'PDF_GENERATOR': {'BIN':
>>>> '/usr/bin/wkhtml2pdf', 'ARGS': [], 'NAME':
>>>> 'wkhtml2pdf'}, 'DEFAULT_LOCATION': None} MAP_BASELAYERS
>>>> = [{'source': {'url':
>>>> '/gs/rest', 'ptype': 'gxp_wmscsource'}}, {'group':
>>>> 'background', 'name': 'background', 'args': ['No
>>>> background'], 'visibility': False, 'source': {'ptype':
>>>> 'gxp_olsource'}, 'fixed': True, 'type':
>>>> 'OpenLayers.Layer'}, {'source': {'ptype':
>>>> 'gxp_olsource'}, 'wrapDateLine': True, 'fixed': True,
>>>> 'attribution': '© UNESCO', 'name': 'background',
>>>> 'title': 'UNESCO', 'group': 'background', 'args':
>>>> ['UNESCO',
>>>> 'http://en.unesco.org/tiles/${z}/${x}/${y}.png'],
>>>> 'type': 'OpenLayers.Layer.XYZ
>>>> <http://OpenLayers.Layer.XYZ>', 'visibility': False},
>>>> {'source': {'ptype': 'gxp_olsource'}, 'wrapDateLine':
>>>> True, 'fixed': True, 'attribution': '© UNESCO', 'name':
>>>> 'background', 'title': 'UNESCO GEODATA', 'group':
>>>> 'background', 'args': ['UNESCO GEODATA',
>>>> 'http://en.unesco.org/tiles/geodata/${z}/${x}/${y}.png'],
>>>> True, 'fixed': True, 'attribution': "© OpenStreetMap,
>>>> Tiles courtesy of Humanitarian OpenStreetMap Team",
>>>> 'name': 'background', 'title': 'Humanitarian
>>>> OpenStreetMap', 'group': 'background', 'args':
>>>> ['Humanitarian OpenStreetMap',
>>>> 'http://a.tile.openstreetmap.fr/hot/${z}/${x}/${y}.png'],
>>>> True, 'fixed': True, 'attribution': "© Mapbox ©
>>>> OpenStreetMap Improve this map", 'name': 'background',
>>>> 'title': 'MapBox Satellite Streets', 'group':
>>>> 'background', 'args': ['MapBox Satellite Streets',
>>>> 'http://api.mapbox.com/styles/v1/mapbox/satellite-streets-v9/tiles/${z}/${x}/${y}?access_token='],
>>>> 'title': 'MapBox Streets', 'group': 'background',
>>>> 'args': ['MapBox Streets',
>>>> 'http://api.mapbox.com/styles/v1/mapbox/streets-v9/tiles/${z}/${x}/${y}?access_token='],
>>>> {'source': {'ptype': 'gxp_osmsource'}, 'wrapDateLine':
>>>> True, 'attribution': "© OpenStreetMap contributors",
>>>> 'name': 'mapnik', 'title': 'OpenStreetMap', 'group':
>>>> 'background', 'fixed': True, 'type':
>>>> 'OpenLayers.Layer.OSM', 'visibility': True}]
>>>> LOGIN_REDIRECT_URL = '/' GROUP_PRIVATE_RESOURCES =
>>>> False DATE_FORMAT = 'N j, Y' LOCAL_SIGNALS_BROKER_URL =
>>>> 'memory://' MEDIA_ROOT = '/var/www/geonode/uploaded'
>>>> PROXY_URL = '/proxy/?url=' TEMPLATE_DEBUG = False
>>>> DEFAULT_FROM_EMAIL = 'Geoportal dummy '
>>>> FREETEXT_KEYWORDS_READONLY = u'********************'
>>>> GEONODE_EXCHANGE = NOTIFICATIONS_MODULE =
>>>> 'pinax.notifications' SITE_ID = 1 ALLOWED_INCLUDE_ROOTS
>>>> = API_LIMIT_PER_PAGE = u'********************'
>>>> SHORT_DATE_FORMAT = 'm/d/Y' ACTSTREAM_SETTINGS =
>>>> {'GFK_FETCH_DEPTH': 1, 'USE_JSONFIELD': True,
>>>> 'FETCH_RELATIONS': True, 'USE_PREFETCH': False}
>>>> AWS_S3_BUCKET_DOMAIN = '.s3.amazonaws.com
>>>> <http://s3.amazonaws.com>' FILE_UPLOAD_MAX_MEMORY_SIZE
>>>> = 2621440 DISPLAY_SOCIAL = 1 CSRF_COOKIE_AGE = 31449600
>>>> EMAIL_USE_SSL = False INTERNAL_IPS = EMAIL_PORT = 25
>>>> GROUP_MANDATORY_RESOURCES = False PASSWORD_HASHERS =
>>>> u'********************' ANONYMOUS_USER_ID = '-1'
>>>> DATETIME_INPUT_FORMATS = You're seeing this error
>>>> because you have DEBUG = True in your Django settings
>>>> file. Change that to False, and Django will display a
>>>> standard page generated by the handler for this status
>>>> code.
>>>> Michael Härtel
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> <mailto:geonode-devel at lists.osgeo.org>
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.==Ing. Alessio
>>>> Fabiani
>>>> @alfa7691Founder/Technical Lead
>>>> GeoSolutions S.A.S.Via di Montramito 3/A - 55054 Massarosa
>>>> (LU) - Italyphone: +39 0584 962313fax: +39 0584
>>>> 1660272mob: +39 331 6233686
>>>> http://www.geo-solutions.ithttp://twitter.com/geosolutions_it-------------------------------------------------------
>>>> Con riferimento alla normativa sul trattamento dei dati
>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla
>>>> protezione dei dati “GDPR”), si precisa che ogni
>>>> circostanza inerente alla presente email (il suo contenuto,
>>>> gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo
>>>> scrivente. Se il messaggio Le è giunto per errore, è
>>>> tenuta/o a cancellarlo, ogni altra operazione è illecita.
>>>> Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to
>>>> which it is addressed and may contain information that is
>>>> privileged, confidential or otherwise protected from
>>>> disclosure. We remind that - as provided by European
>>>> Regulation 2016/679 “GDPR” - copying, dissemination or use
>>>> of this e-mail or the information herein by anyone other
>>>> than the intended recipient is prohibited. If you have
>>>> received this email by mistake, please notify us
>>>> immediately by telephone or e-mail.
>>> http://goo.gl/it488V for more information.==Ing. Alessio Fabiani
>>> GeoSolutions S.A.S.Via di Montramito 3/A - 55054 Massarosa (LU)
>>> - Italyphone: +39 0584 962313fax: +39 0584 1660272mob: +39
>>> 331 6233686
>>> protezione dei dati “GDPR”), si precisa che ogni circostanza
>>> inerente alla presente email (il suo contenuto, gli eventuali
>>> allegati, etc.) è un dato la cui conoscenza è riservata al/i
>>> solo/i destinatario/i indicati dallo scrivente. Se il messaggio
>>> Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse
>>> darmene notizia.
>>> This email is intended only for the person or entity to which it
>>> is addressed and may contain information that is privileged,
>>> confidential or otherwise protected from disclosure. We remind
>>> that - as provided by European Regulation 2016/679 “GDPR” -
>>> copying, dissemination or use of this e-mail or the information
>>> herein by anyone other than the intended recipient is
>>> prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>> geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
> GeoSolutions S.A.S.Via di Montramito 3/A - 55054 Massarosa (LU) -
> Italyphone: +39 0584 962313fax: +39 0584 1660272mob: +39 331 6233686
> Con riferimento alla normativa sul trattamento dei dati personali
> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
> “GDPR”), si precisa che ogni circostanza inerente alla presente email
> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
> conoscenza è riservata al/i solo/i destinatario/i indicati dallo
> scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
> cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential
> or otherwise protected from disclosure. We remind that - as provided
> by European Regulation 2016/679 “GDPR” - copying, dissemination or use
> of this e-mail or the information herein by anyone other than the
> intended recipient is prohibited. If you have received this email by
> mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190516/f49a2ec5/attachment-0001.html>
More information about the geonode-devel
