[GeoNode-devel] Layer Upload doesn't work in GeoNode 2.8.1rc0: "AttributeError at /layers/upload 'NoneType' object has no attribute 'charset'"
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu May 16 06:28:31 PDT 2019
That's very strange, from the error it looks like the "geonode" is not
listed among the INSTALLED_APPS or there's some error preventing geonode to
be correctly loaded. But it is hard to say what's going on.
Il giorno gio 16 mag 2019 alle ore 15:19 Michael Härtel <haerta at haerta.de>
ha scritto:
> Thanks for your answer but it didn't help. PIP downloaded the packages
> again and re-installed same version. The result in the browser is an error
> 500 and the log shows exactly the same error :-(
> On 16/05/2019 14:58, Alessio Fabiani wrote:
> Maybe try to run a
> pip install -e .
> from inside the GeoNode source code
> Il giorno gio 16 mag 2019 alle ore 14:50 Michael Härtel <haerta at haerta.de>
> ha scritto:
>> Hello Alessio, list
>> I tried to incorporate your changes. I followed these steps:
>> - Downloaded "geonode-ISSUE_-4401.zip" from github
>> - unpacked the contents of the ZIP file to
>> "/home/geo/Envs/geonode/src/geonode" (I followed the instructions from
>> this
>> <http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>> link to set up geonode).
>> - Deleted all pyc files in /home/geo
>> - restarted apache
>> What I get is this error. Strange enough is that I get same error when I
>> roll back the changes (copy the backup folder back to
>> /home/geo/Envs/geonode/src/geonode).
>> [Thu May 16 13:42:42.686733 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] mod_wsgi (pid=22537): Exception occurred processing
>> WSGI script '/home/geonode/my_geonode/my_geonode/wsgi.py'.
>> [Thu May 16 13:42:42.686885 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] Traceback (most recent call last):
>> [Thu May 16 13:42:42.687030 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] File "/home/geonode/my_geonode/my_geonode/wsgi.py",
>> line 44, in <module>
>> [Thu May 16 13:42:42.687205 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] application = get_wsgi_application()
>> [Thu May 16 13:42:42.687284 2019] [wsgi:error] [pid 22537] [remote
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/wsgi.py",
>> line 14, in get_wsgi_application
>> [Thu May 16 13:42:42.687425 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] django.setup()
>> [Thu May 16 13:42:42.687541 2019] [wsgi:error] [pid 22537] [remote
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/__init__.py",
>> line 17, in setup
>> [Thu May 16 13:42:42.687677 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] configure_logging(settings.LOGGING_CONFIG,
>> settings.LOGGING)
>> [Thu May 16 13:42:42.687777 2019] [wsgi:error] [pid 22537] [remote
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/conf/__init__.py",
>> line 48, in __getattr__
>> [Thu May 16 13:42:42.687964 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] self._setup(name)
>> [Thu May 16 13:42:42.688062 2019] [wsgi:error] [pid 22537] [remote
>> line 44, in _setup
>> [Thu May 16 13:42:42.688154 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] self._wrapped = Settings(settings_module)
>> [Thu May 16 13:42:42.688237 2019] [wsgi:error] [pid 22537] [remote
>> line 92, in __init__
>> [Thu May 16 13:42:42.688322 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] mod =
>> importlib.import_module(self.SETTINGS_MODULE)
>> [Thu May 16 13:42:42.688395 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] File "/usr/lib/python2.7/importlib/__init__.py",
>> line 37, in import_module
>> [Thu May 16 13:42:42.688510 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] __import__(name)
>> [Thu May 16 13:42:42.688585 2019] [wsgi:error] [pid 22537] [remote
>> "/home/geonode/my_geonode/my_geonode/settings.py", line 30, in <module>
>> [Thu May 16 13:42:42.688709 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] from geonode.settings import *
>> [Thu May 16 13:42:42.688799 2019] [wsgi:error] [pid 22537] [remote
>> 172.30.1.13:41727] ImportError: No module named geonode.settings
>> I blieve I lack some basic understanding here. Can you help?
>> Thank you very much,
>> Michael
>> On 16/05/2019 12:44, Michael Härtel wrote:
>> Hello Alessio,
>> thank you very much for your efforts. I will give it a try.
>> Just 10 minutes ago I set up a local VM with 2.10 rc5 and I can confirm
>> that the layer uploads works perfectly for me with the included geoserver
>> 2.14.2.
>> (What I noted is that the admin link to geoserver from within geonode
>> didn't work in DEV mode (paver start): The url it points to is
>> "http://localhost:8000/gs/" <http://localhost:8000/gs/> but I get a 404
>> (see output below). This isn't a big problem because I don't intend to use
>> DEV mode at all. I also didn't examine this issue yet.)
>> Thanks again, I will try to fix my 2.8.1 version and keep you informed
>> Regards,
>> Michael
>> output from geonode after click on geoserver link in admin menu:
>> Page not found (404)
>> Request Method: GET
>> Request URL: http://localhost:8000/gs/
>> Using the URLconf defined in geonode.urls, Django tried these URL
>> patterns, in this order:
>> ^$ [name='home']
>> ^help/$ [name='help']
>> ^developer/$ [name='developer']
>> ^about/$ [name='about']
>> ^privacy_cookies/$ [name='privacy-cookies']
>> ^layers/
>> ^maps/
>> ^catalogue/
>> ^data.json$ [name='data_json']
>> ^ident.json$ [name='ident_json']
>> ^h_keywords_api$ [name='h_keywords_api']
>> ^search/$ [name='search']
>> ^account/
>> ^invitations/
>> ^people/
>> ^avatar/
>> ^comments/
>> ^ratings/
>> ^activity/
>> ^announcements/
>> ^messages/
>> ^social/
>> ^security/
>> ^account/ajax_login$ [name='account_ajax_login']
>> ^account/ajax_lookup$ [name='account_ajax_lookup']
>> ^account/moderation_sent/(?P<inactive_user>[^/]*)$
>> [name='moderator_contacted']
>> ^lang\.js$ [name='lang']
>> ^jsi18n/$ [name='javascript-catalog']
>> ^sitemap\.xml$ [name='sitemap']
>> ^robots\.txt$ [name='robots']
>> ^autocomplete/
>> ^groups/
>> ^documents/
>> ^services/
>> ^o/
>> ^api/o/v4/tokeninfo [name='tokeninfo']
>> ^api/o/v4/userinfo [name='userinfo']
>> ^api/roles [name='roles']
>> ^api/adminRole [name='adminRole']
>> ^api/users [name='users']
>> ^(?P<api_name>api)/$ [name='api_api_top_level']
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^(?P<api_name>api)/
>> ^en/
>> ^i18n/
>> ^showmetadata/
>> ^upload/
>> ^capabilities/layer/(?P<layerid>\d+)/$ [name='capabilities_layer']
>> ^capabilities/map/(?P<mapid>\d+)/$ [name='capabilities_map']
>> ^capabilities/user/(?P<user>[\w. at +-]+)/$ [name='capabilities_user']
>> ^capabilities/category/(?P<category>\w+)/$
>> [name='capabilities_category']
>> ^gs/ ^rest/stores/(?P<store_type>\w+)/$ [name='stores']
>> ^gs/ ^rest/styles
>> ^gs/ ^rest/workspaces
>> ^gs/ ^rest/workspaces/(?P<workspace>\w+)/styles
>> ^gs/ ^rest/layers
>> ^gs/ ^rest/imports
>> ^gs/ ^rest/sldservice
>> ^gs/ ^ows [name='ows_endpoint']
>> ^gs/ ^gwc [name='gwc_endpoint']
>> ^gs/ ^wms [name='wms_endpoint']
>> ^gs/ ^wfs [name='wfs_endpoint']
>> ^gs/ ^wcs [name='wcs_endpoint']
>> ^gs/ ^wps [name='wps_endpoint']
>> ^gs/ ^pdf [name='pdf_endpoint']
>> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/ows
>> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wms
>> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wfs
>> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wcs
>> ^gs/ ^updatelayers/$ [name='updatelayers']
>> ^gs/ ^(?P<layername>[^/]*)/style$ [name='layer_style']
>> ^gs/ ^(?P<layername>[^/]*)/style/upload$ [name='layer_style_upload']
>> ^gs/ ^(?P<layername>[^/]*)/style/manage$ [name='layer_style_manage']
>> ^gs/ ^(?P<layername>[^/]*)/edit-check?$ [name='feature_edit_check']
>> ^gs/ ^(?P<layername>[^/]*)/style-check?$ [name='style_edit_check']
>> ^gs/ ^acls/?$ [name='layer_acls']
>> ^gs/ ^resolve_user/?$ [name='layer_resolve_user']
>> ^gs/ ^download$ [name='layer_batch_download']
>> ^gs/ ^online/?$ [name='server_online']
>> ^notifications/
>> ^ ^api/ows_endpoints/
>> ^proxy/ [name='proxy']
>> ^download/(?P<resourceid>[^/]*)$ [name='download']
>> ^static\/(?P<path>.*)$
>> ^uploaded\/(?P<path>.*)$
>> ^featured/(?P<site>[A-Za-z0-9_\-]+)/$
>> ^featured/(?P<site>[A-Za-z0-9_\-]+)/info$
>> The current path, gs/, didn't match any of these.
>> You're seeing this error because you have DEBUG = True in your Django
>> settings file. Change that to False, and Django will display a standard 404
>> page.
>> On 16/05/2019 11:49, Alessio Fabiani wrote:
>> Dear Michael,
>> fwi I did a PR [1] backporting most of the fixes currently available on
>> 2.10
>> Once this will be merged, you will need to update the GeoNode 2.8 code
>> base accordingly and run again migrations and collectstatic commands.
>> [1] - https://github.com/GeoNode/geonode/pull/4402
>> Il giorno lun 6 mag 2019 alle ore 22:36 Michael Härtel <haerta at haerta.de>
>> ha scritto:
>>> Hello Alessio,
>>> I installed mod_security and was able to produce more information by
>>> capturing the POST data. I attached the logfile to this mail.
>>> Michael
>>> On 06/05/2019 10:00, Alessio Fabiani wrote:
>>> Hello Michael,
>>> I'm going to do some checks on 2.8 branches and probably backport some
>>> fixes in the next few days.
>>> I'll keep you posted about that.
>>> Alessio.
>>> Il giorno sab 4 mag 2019 alle ore 00:08 Michael Härtel <haerta at haerta.de>
>>> ha scritto:
>>>> Hello List,
>>>> I followed the instructions from here to install geonode:
>>>> Despite the fact that the url to Geonode from the tutorial ("--template=
>>>> https://github.com/GeoNode/geonode-project/archive/2.8.0.zip") is not
>>>> available and I had a hard time to find a URL that worked for me (I used
>>>> the ZIP from GIT/2.8.x branch), I eventuelly got everything working apart
>>>> from the layer upload.
>>>> I have no idea, how to debug this issue:
>>>> - The apache error.log does not show any entry.
>>>> - The apache access.log only shows an error 500
>>>> - The database doesn't show any relevant entry
>>>> - GeoServer doesn't show any relevant entry (Even with VERBODE
>>>> logging).
>>>> It seems that the file never reaches the server so the "saved_layer"
>>>> variable is empty/none/null (I am not a Python programmer) in line 294 of
>>>> "/home/geo/Envs/geonode/src/geonode/geonode/layers/views.py"
>>>> Where is the relevant configuration?
>>>> - the directory and sub directories of
>>>> "/home/geonode/my_geonode/my_geonode/uploaded" has correct permissions
>>>> (even tested with "chmod -R ugo+rwx
>>>> - the apache file /etc/apache2/sites-available/geonode.conf has
>>>> correct entries:
>>>> Alias /uploaded/ /home/geonode/my_geonode/my_geonode/uploaded/
>>>> <Directory "/home/geonode/my_geonode/my_geonode/uploaded/layers/">
>>>> Is there anyone who can tell me what else to check or how to debug this
>>>> issue?
>>>> When I select some shape files and click "upload files", the DEBUG
>>>> output on the web page looks like this:
>>>> 'charset' Request Method: POST Request URL:
>>>> http://geoportal.dummy.org/layers/upload Django Version: 1.8.19 Python
>>>> Executable: /usr/bin/python Python Version: 2.7.12 Python Path:
>>>> ['/home/geonode/my_geonode',
>>>> '/home/geo/Envs/geonode/lib/python2.7/site-packages',
>>>> '/home/geo/Envs/geonode/src/geonode', '/home/dummygeonode/my_geonode',
>>>> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>>>> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
>>>> '/usr/lib/python2.7/dist-packages',
>>>> '/usr/lib/python2.7/dist-packages/PILcompat', '/var/www', '/var/www']
>>>> Server time: Fri, 3 May 2019 21:36:06 +0000 Installed Applications:
>>>> ('modeltranslation', 'django.contrib.auth', 'django.contrib.contenttypes',
>>>> 'django.contrib.sessions', 'django.contrib.sites', 'django.contrib.admin',
>>>> 'django.contrib.sitemaps', 'django.contrib.staticfiles',
>>>> 'django.contrib.messages', 'django.contrib.humanize', 'django.contrib.gis',
>>>> 'dj_pagination', 'taggit', 'treebeard', 'geoexplorer', 'leaflet',
>>>> 'bootstrap3_datetime', 'django_extensions', 'django_basic_auth',
>>>> 'autocomplete_light', 'mptt', 'storages', 'floppyforms',
>>>> 'pinax_theme_bootstrap', 'django_forms_bootstrap', 'avatar', 'dialogos',
>>>> 'agon_ratings', 'announcements', 'actstream', 'user_messages', 'tastypie',
>>>> 'polymorphic', 'guardian', 'oauth2_provider', 'corsheaders', 'invitations',
>>>> 'allauth', 'allauth.account', 'allauth.socialaccount', 'rest_framework',
>>>> 'geonode', 'geonode.api', 'geonode.base', 'geonode.layers', 'geonode.maps',
>>>> 'geonode.documents', 'geonode.security', 'geonode.catalogue',
>>>> 'geonode.people', 'geonode.client', 'geonode.themes', 'geonode.proxy',
>>>> 'geonode.social', 'geonode.groups', 'geonode.services',
>>>> 'geonode.geoserver', 'geonode.upload', 'geonode.tasks',
>>>> 'geonode.messaging', 'geonode.contrib.metadataxsl',
>>>> 'geonode.contrib.api_basemaps', 'geonode.contrib.ows_api',
>>>> 'pinax.notifications', 'geonode.contrib.monitoring', 'my_geonode', , )
>>>> Installed Middleware: ('corsheaders.middleware.CorsMiddleware',
>>>> 'django.middleware.common.CommonMiddleware',
>>>> 'django.contrib.sessions.middleware.SessionMiddleware',
>>>> 'django.contrib.messages.middleware.MessageMiddleware',
>>>> 'dj_pagination.middleware.PaginationMiddleware',
>>>> 'django.middleware.locale.LocaleMiddleware',
>>>> 'django.middleware.csrf.CsrfViewMiddleware',
>>>> 'django.contrib.auth.middleware.AuthenticationMiddleware',
>>>> 'django.middleware.clickjacking.XFrameOptionsMiddleware',
>>>> 'django.middleware.security.SecurityMiddleware',
>>>> 'django.contrib.auth.middleware.SessionAuthenticationMiddleware',
>>>> 'oauth2_provider.middleware.OAuth2TokenMiddleware',
>>>> 'geonode.contrib.monitoring.middleware.MonitoringMiddleware') Traceback:
>>>> File
>>>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/handlers/base.py"
>>>> in get_response 132. response = wrapped_callback(request, *callback_args,
>>>> **callback_kwargs) File
>>>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/contrib/auth/decorators.py"
>>>> in _wrapped_view 22. return view_func(request, *args, **kwargs) File
>>>> "/home/geo/Envs/geonode/src/geonode/geonode/layers/views.py" in
>>>> layer_upload 294. out[_k] =
>>>> out[_k].decode(saved_layer.charset).encode("utf-8") Exception Type:
>>>> AttributeError at /layers/upload Exception Value: 'NoneType' object has no
>>>> attribute 'charset' Request information: GET: No GET data POST: charset =
>>>> u'UTF-8' permissions =
>>>> u'{"users":{"AnonymousUser":["view_resourcebase","download_resourcebase"]},"groups":{}}'
>>>> FILES: shx_file = base_file = shp_file = dbf_file = prj_file = COOKIES:
>>>> csrftoken = 'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn' sessionid =
>>>> 'h0bcxlw4nutyik4kb63ao9d3pzxud6hq' _ga = 'GA1.2.1615965258.1556718183'
>>>> META: mod_wsgi.listener_port = '80' HTTP_REFERER = '
>>>> http://geoportal.dummy.org/layers/upload' mod_wsgi.listener_host = ''
>>>> HTTP_REVERSE_VIA = 'IPGW2' CONTEXT_DOCUMENT_ROOT =
>>>> '/home/geonode/my_geonode/my_geonode' SERVER_SOFTWARE = 'Apache/2.4.18
>>>> (Ubuntu)' SCRIPT_NAME = u'' mod_wsgi.enable_sendfile = '0' HTTP_X_CSRFTOKEN
>>>> = 'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn' SERVER_SIGNATURE = '
>>>> Apache/2.4.18 (Ubuntu) Server at geoportal.dummy.org Port 80
>>>> \n' REQUEST_METHOD = 'POST' PATH_INFO = u'/layers/upload'
>>>> SERVER_PROTOCOL = 'HTTP/1.1' QUERY_STRING = '' CONTENT_LENGTH = '4451'
>>>> HTTP_USER_AGENT = 'Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:66.0)
>>>> Gecko/20100101 Firefox/66.0' HTTP_CONNECTION = 'Keep-Alive' HTTP_COOKIE =
>>>> 'csrftoken=RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn;
>>>> _ga=GA1.2.1615965258.1556718183;
>>>> sessionid=h0bcxlw4nutyik4kb63ao9d3pzxud6hq' SERVER_NAME = '
>>>> geoportal.dummy.org' REMOTE_ADDR = '172.30.1.13'
>>>> mod_wsgi.handler_script = '' mod_wsgi.request_handler = 'wsgi-script'
>>>> apache.version = wsgi.url_scheme = 'http' PATH_TRANSLATED =
>>>> '/home/geonode/my_geonode/my_geonode/wsgi.py/layers/upload'
>>>> SERVER_PORT = '80' mod_wsgi.queue_start = '1556919366052407'
>>>> wsgi.multiprocess = True mod_wsgi.input_chunked = '0' SERVER_ADDR =
>>>> '172.30.1.167' DOCUMENT_ROOT = '/home/geonode/my_geonode/my_geonode'
>>>> mod_wsgi.process_group = 'geonode' HTTP_X_REQUESTED_WITH = 'XMLHttpRequest'
>>>> mod_wsgi.daemon_connects = '1' SCRIPT_FILENAME =
>>>> '/home/geonode/my_geonode/my_geonode/wsgi.py' SERVER_ADMIN =
>>>> 'webmaster at localhost' wsgi.input = HTTP_HOST = 'geoportal.dummy.org'
>>>> CONTEXT_PREFIX = '' wsgi.multithread = True mod_wsgi.callable_object =
>>>> 'application' mod_wsgi.daemon_restarts = '0' REQUEST_URI = '/layers/upload'
>>>> HTTP_ACCEPT = '*/*' wsgi.file_wrapper = '' wsgi.version = GATEWAY_INTERFACE
>>>> = 'CGI/1.1' wsgi.run_once = False wsgi.errors = REMOTE_PORT = '25591'
>>>> HTTP_ACCEPT_LANGUAGE = 'en-GB,en;q=0.5' REQUEST_SCHEME = 'http'
>>>> mod_wsgi.version = mod_wsgi.script_start = '1556919366052600' CONTENT_TYPE
>>>> = 'multipart/form-data; boundary=---------------------------75853149526340'
>>>> mod_wsgi.application_group = 'geoportal.cgiarad.org|'
>>>> mod_wsgi.script_reloading = '1' mod_wsgi.request_start = '1556919366052122'
>>>> CSRF_COOKIE = u'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn' mod_wsgi.daemon_start =
>>>> '1556919366052568' Settings: Using settings module my_geonode.settings
>>>> BROKER_TRANSPORT_OPTIONS = {'fanout_prefix': True, 'fanout_patterns': True,
>>>> 'visibility_timeout': 86400, 'socket_timeout': 60} EMAIL_USE_TLS = False
>>>> CELERY_SEND_TASK_SENT_EVENT = True DOWNLOAD_FORMATS_METADATA = ['Atom',
>>>> 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO', 'ISO with XSL']
>>>> SESSION_SERIALIZER = 'django.contrib.sessions.serializers.PickleSerializer'
>>>> ACCOUNT_EMAIL_REQUIRED = True OGC_SERVER_DEFAULT_USER = 'admin'
>>>> MESSAGE_STORAGE =
>>>> 'django.contrib.messages.storage.fallback.FallbackStorage' WSGI_APPLICATION
>>>> = 'my_geonode.wsgi.application' SESSION_COOKIE_NAME = 'sessionid'
>>>> CELERY_BROKER_URL = 'memory://' VERSION = '2.8.1rc0' AWS_BUCKET_NAME = ''
>>>> ACCOUNT_CONFIRM_EMAIL_ON_GET = True EMAIL_SSL_KEYFILE =
>>>> u'********************' SERVER_EMAIL = 'root at localhost'
>>>> ACCOUNT_EMAIL_VERIFICATION = 'optional' FIRST_DAY_OF_WEEK = 0 CACHES =
>>>> {'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
>>>> CKAN_ORIGINS = [{'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}¬es={abstract}&caveats={caveats}',
>>>> 'css_class': 'hdx', 'label': 'Humanitarian Data Exchange (HDX)'}]
>>>> SESSION_COOKIE_PATH = '/' UNOCONV_ENABLE = 1 MISSING_THUMBNAIL =
>>>> 'geonode/img/missing_thumb.png' MODELTRANSLATION_FALLBACK_LANGUAGES = 'en'
>>>> PINAX_NOTIFICATIONS_HOOKSET = CELERY_TASK_IGNORE_RESULT = True
>>>> DEFAULT_INDEX_TABLESPACE = '' MONITORING_HOST_NAME = 'localhost' THESAURI =
>>>> [] USE_X_FORWARDED_HOST = False TWITTER_HASHTAGS = ['geonode']
>>>> PUBLIC_GEOSERVER = {'source': {'url': '
>>>> http://localhost:8080/geoserver/ows', 'restUrl': '/gs/rest',
>>>> 'attribution': '© http://localhost:8000/', 'ptype': 'gxp_wmscsource',
>>>> 'title': 'GeoServer - Public Layers'}} GUARDIAN_GET_INIT_ANONYMOUS_USER =
>>>> 'geonode.people.models.get_anonymous_user_instance' CSRF_COOKIE_DOMAIN =
>>>> None FILE_CHARSET = 'utf-8' DEBUG = True SESSION_FILE_PATH = None
>>>> DISPLAY_COMMENTS = 1 DATABASE_ENGINE = 'postgresql_psycopg2'
>>>> STATICFILES_DIRS = ['/etc/geonode/media',
>>>> '/home/geo/Envs/geonode/src/geonode/geonode/static',
>>>> '/home/geonode/my_geonode/my_geonode/static']
>>>> CELERY_TASK_CREATE_MISSING_QUEUES = True SECURE_PROXY_SSL_HEADER = None
>>>> AWS_SECRET_ACCESS_KEY = u'********************' DEBUG_PROPAGATE_EXCEPTIONS
>>>> = False MONTH_DAY_FORMAT = 'F j' SEARCH_FILTERS = {'REGION_ENABLED': True,
>>>> 'EXTENT_ENABLED': True, 'DATE_ENABLED': True, 'KEYWORDS_ENABLED':
>>>> u'********************', 'CATEGORIES_ENABLED': True, 'TYPE_ENABLED': True,
>>>> 'T_KEYWORDS_ENABLED': u'********************', 'OWNERS_ENABLED': True,
>>>> 'H_KEYWORDS_ENABLED': u'********************', 'TEXT_ENABLED': True}
>>>> THUMBNAIL_GENERATOR = 'geonode.layers.utils.create_gs_thumbnail_geonode'
>>>> AUTH_USER_MODEL = 'people.Profile' USE_THOUSAND_SEPARATOR = False
>>>> UNOCONV_TIMEOUT = 30 CELERY_DISABLE_RATE_LIMITS = False CSRF_FAILURE_VIEW =
>>>> 'django.views.csrf.csrf_failure' CELERY_WORKER_SEND_TASK_EVENTS = True
>>>> CELERY_TASK_SERIALIZER = 'json' DECIMAL_SEPARATOR = '.' IGNORABLE_404_URLS
>>>> = NOSE_ARGS = ['--nocapture', '--detailed-errors']
>>>> TEMPLATE_STRING_IF_INVALID = '' FIXTURE_DIRS = SOCIALACCOUNT_AUTO_SIGNUP =
>>>> False PINAX_NOTIFICATIONS_BACKENDS = {(0, 'email'): } FORMAT_MODULE_PATH =
>>>> None ALLOWED_DOCUMENT_TYPES = ['doc', 'docx', 'gif', 'jpg', 'jpeg', 'ods',
>>>> 'odt', 'odp', 'pdf', 'png', 'ppt', 'pptx', 'rar', 'sld', 'tif', 'tiff',
>>>> 'txt', 'xls', 'xlsx', 'xml', 'zip', 'gz', 'qml'] RESOURCE_PUBLISHING =
>>>> False DISALLOWED_USER_AGENTS = DEFAULT_LAYER_FORMAT = 'image/png'
>>>> THUNDERFOREST_BASEMAPS = False CELERY_REDIRECT_STDOUTS = True SITENAME =
>>>> 'my_geonode' CELERY_MESSAGE_COMPRESSION = 'gzip' USE_ETAGS = False
>>>> DISPLAY_WMS_LINKS = True GEOTIFF_IO_ENABLED = 0
>>>> PINAX_NOTIFICATIONS_GET_LANGUAGE_MODEL = at 0x7f8c98343c80> USE_TZ = True
>>>> SHORT_DATETIME_FORMAT = 'm/d/Y P' LANGUAGE_COOKIE_PATH = '/'
>>>> MAX_DOCUMENT_SIZE = 2 YEAR_MONTH_FORMAT = 'F Y' AWS_QUERYSTRING_AUTH =
>>>> False CELERY_SEND_TASK_EVENTS = True LANGUAGE_CODE = 'en' ROOT_URLCONF =
>>>> 'my_geonode.urls' LOGIN_URL = '/account/login/' DEFAULT_MAP_CENTER =
>>>> DATABASE_HOST = 'localhost' TEMPLATE_DIRS = BROKER_HEARTBEAT = 0
>>>> SESSION_CACHE_ALIAS = 'default' SESSION_COOKIE_DOMAIN = None
>>>> PINAX_NOTIFICATIONS_QUEUE_ALL = False FILE_UPLOAD_PERMISSIONS = None
>>>> BING_API_KEY = u'********************' APPEND_SLASH = True DATABASE_ROUTERS
>>>> = [] STAMEN_BASEMAPS = False GEOSERVER_LOCATION = '
>>>> http://localhost/geoserver/' INVITATIONS_ADAPTER =
>>>> 'geonode.people.adapters.LocalAccountAdapter' HOSTNAME = 'localhost'
>>>> EXIF_ENABLED = False CATALOGUE = {'default': {'ENGINE':
>>>> 'geonode.catalogue.backends.pycsw_local', 'URL': '
>>>> http://geoportal.dummy.org/catalogue/csw'}} LOCKDOWN_GEONODE = 0
>>>> MIDDLEWARE_CLASSES = USE_I18N = 1 LANGUAGE_COOKIE_NAME = 'django_language'
>>>> CELERY_TASK_ALWAYS_EAGER = True TEST_RUNNER_PARALLEL = 0
>>>> CELERYD_HIJACK_ROOT_LOGGER = True HAYSTACK_SEARCH = 0 X_FRAME_OPTIONS =
>>>> 'DENY' UNOCONV_EXECUTABLE = '/usr/bin/unoconv' OAUTH2_PROVIDER = {'SCOPES':
>>>> {'read': 'Read scope', 'write': 'Write scope', 'groups': 'Access to your
>>>> groups'}, 'CLIENT_ID_GENERATOR_CLASS':
>>>> 'oauth2_provider.generators.ClientIdGenerator'} GEOSERVER_PUBLIC_LOCATION =
>>>> 'http://geoportal.dummy.org/geoserver/' SECURE_SSL_HOST = None
>>>> NLP_ENABLED = False MONITORING_DISABLE_CSRF = False SOCIAL_ORIGINS =
>>>> [{'url': 'mailto:?subject= <?subject=>{name}&body={url}', 'css_class':
>>>> 'email', 'label': 'Email'}, {'url': '
>>>> http://www.facebook.com/sharer.php?u={url}', 'css_class': 'fb',
>>>> 'label': 'Facebook'}, {'url': 'https://twitter.com/share?url={url}&hashtags={hashtags}',
>>>> 'css_class': 'tw', 'label': 'Twitter'}, {'url': '
>>>> https://plus.google.com/share?url={url}', 'css_class': 'gp', 'label':
>>>> 'Google +'}] PREPEND_WWW = False AUTH_IP_WHITELIST = [] DATABASE_PORT =
>>>> '5432' DEFAULT_ANONYMOUS_VIEW_PERMISSION = 1 GOOGLE_API_KEY =
>>>> u'********************' GEOIP_PATH = '/usr/local/share/GeoIP'
>>>> ADMIN_MODERATE_UPLOADS = False TASTYPIE_DEFAULT_FORMATS = ['json']
>>>> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION = 1 FORCE_SCRIPT_NAME = None
>>>> DISPLAY_RATINGS = 1 TEST_RUNNER_KEEPDB = 0 PASSWORD_RESET_TIMEOUT_DAYS =
>>>> u'********************' DEFAULT_SEARCH_SIZE = 10 CELERYD_CONCURENCY = 1
>>>> SESSION_ENGINE = 'django.contrib.sessions.backends.db'
>>>> API_INCLUDE_REGIONS_COUNT = u'********************'
>>>> PINAX_NOTIFICATIONS_LOCK_WAIT_TIMEOUT = -1 MIGRATION_MODULES = {}
>>>> NLP_MODEL_PATH = '/opt/MITIE/MITIE-models/english/ner_model.dat'
>>>> PROXY_ALLOWED_HOSTS = ['geoportal.dummy.org', 'geoportal.cgiarad.org',
>>>> '172.30.1.167', 'localhost'] CARTODB_BASEMAPS = False
>>>> SECURE_BROWSER_XSS_FILTER = True GEONODE_CONTRIB_APPS = SRID = {'DETAIL':
>>>> 'never'} ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE = u'********************'
>>>> AGON_RATINGS_CATEGORY_CHOICES = {'maps.Map': {'map': 'How good is this
>>>> map?'}, 'layers.Layer': {'layer': 'How good is this layer?'},
>>>> 'documents.Document': {'document': 'How good is this document?'}}
>>>> DEFAULT_EXCEPTION_REPORTER_FILTER =
>>>> 'django.views.debug.SafeExceptionReporterFilter' ADMINS = []
>>>> MONITORING_DATA_TTL = datetime.timedelta(7) GEOSERVER_EXCHANGE =
>>>> CELERY_ACCEPT_CONTENT = ['json'] LOCAL_MEDIA_URL = '/uploaded/' LOGOUT_URL
>>>> = '/account/logout/' USE_GEOSERVER = True EXTRA_LANG_INFO = {'tl': {'code':
>>>> 'tl', 'name': 'Tagalog', 'bidi': False, 'name_local': 'tagalog'}, 'am':
>>>> {'code': 'am', 'name': 'Amharic', 'bidi': False, 'name_local': 'Amharic'},
>>>> 'si': {'code': 'si', 'name': 'Sinhala', 'bidi': False, 'name_local':
>>>> 'sinhala'}, 'ta': {'code': 'ta', 'name': 'Tamil', 'bidi': False,
>>>> 'name_local': u'tamil'}} SHOW_PROFILE_EMAIL = False CELERYD_LOG_LEVEL = 1
>>>> DATABASE_USER = 'geonode' TEMPLATES = [{'DIRS':
>>>> ['/home/geonode/my_geonode/my_geonode/templates',
>>>> '/home/geo/Envs/geonode/src/geonode/geonode/templates'], 'OPTIONS':
>>>> {'debug': 1, 'context_processors':
>>>> ['django.template.context_processors.debug',
>>>> 'django.template.context_processors.i18n', '
>>>> django.template.context_processors.tz',
>>>> 'django.template.context_processors.request',
>>>> 'django.template.context_processors.media',
>>>> 'django.template.context_processors.static',
>>>> 'django.contrib.auth.context_processors.auth',
>>>> 'django.contrib.messages.context_processors.messages',
>>>> 'geonode.context_processors.resource_urls',
>>>> 'geonode.geoserver.context_processors.geoserver_urls',
>>>> 'geonode.themes.context_processors.custom_theme'], 'loaders':
>>>> ['django.template.loaders.filesystem.Loader',
>>>> 'django.template.loaders.app_directories.Loader']}, 'NAME': 'GeoNode
>>>> Project Templates', 'BACKEND':
>>>> 'django.template.backends.django.DjangoTemplates'}] EMAIL_SSL_CERTFILE =
>>>> None CELERY_TASK_QUEUES = DEFAULT_WORKSPACE = 'geonode' ASYNC_SIGNALS =
>>>> False LOCAL_GEOSERVER = {'source': {'url': '
>>>> http://geoportal.dummy.org/geoserver/wms', 'restUrl': '/gs/rest',
>>>> 'ptype': 'gxp_wmscsource'}} DEFAULT_TABLESPACE = '' CELERY_ACKS_LATE = True
>>>> EMAIL_ENABLE = True SESSION_COOKIE_AGE = 1209600
>>>> THEME_ACCOUNT_CONTACT_EMAIL = 'admin at example.com' NOTIFICATION_ENABLED
>>>> = True LANGUAGES = CELERY_TASK_RESULT_EXPIRES = 43200
>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'geoext' ABSOLUTE_URL_OVERRIDES = {}
>>>> OGC_SERVER_DEFAULT_PASSWORD = u'********************'
>>>> CACHE_MIDDLEWARE_SECONDS = 600 CSRF_COOKIE_HTTPONLY = False TEST = False
>>>> EMAIL_HOST_USER = 'Geoportal dummy ' CASCADE_WORKSPACE = 'geonode'
>>>> CSRF_COOKIE_SECURE = False CELERY_TRACK_STARTED = True UPLOADER =
>>>> {'SUPPORTED_CRS': ['EPSG:4326', 'EPSG:3785', 'EPSG:3857', 'EPSG:900913',
>>>> 'EPSG:32647', 'EPSG:32736'], 'BACKEND': 'geonode.rest', 'OPTIONS':
>>>> {'TIME_ENABLED': False, 'MOSAIC_ENABLED': False, 'GEOGIG_ENABLED': False},
>>>> 'SUPPORTED_EXT': ['.shp', '.csv', '.kml', '.kmz', '.json', '.geojson',
>>>> '.tif', '.tiff', '.geotiff', '.gml', '.xml']} LICENSES = {'ENABLED': True,
>>>> 'DETAIL': 'above', 'METADATA': 'verbose'} EMAIL_HOST_PASSWORD =
>>>> u'********************' PYCSW = {'CONFIGURATION': {'metadata:main':
>>>> {'identification_fees': 'None', 'provider_url': '
>>>> http://geoportal.dummy.org/', 'identification_keywords': 'sdi,
>>>> catalogue, discovery, metadata, GeoNode', 'contact_address': 'Mailing
>>>> Address', 'identification_accessconstraints': 'None', 'contact_name':
>>>> 'Lastname, Firstname', 'contact_stateorprovince': 'Administrative Area',
>>>> 'contact_country': 'Country', 'contact_url': 'Contact URL',
>>>> 'provider_name': 'Organization Name', 'contact_phone': '+xx-xxx-xxx-xxxx',
>>>> 'contact_hours': 'Hours of Service', 'contact_role': 'pointOfContact',
>>>> 'contact_email': 'Email Address', 'identification_title': 'GeoNode
>>>> Catalogue', 'contact_postalcode': 'Zip or Postal Code', 'contact_city':
>>>> 'City', 'identification_keywords_type': 'theme', 'identification_abstract':
>>>> 'GeoNode is an open source platform that facilitates the creation, sharing,
>>>> and collaborative use of geospatial data', 'contact_fax':
>>>> '+xx-xxx-xxx-xxxx', 'contact_instructions': 'During hours of service. Off
>>>> on weekends.', 'contact_position': 'Position Title'}, 'metadata:inspire':
>>>> {'languages_supported': 'eng,gre', 'default_language': 'eng',
>>>> 'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD', 'conformity_service':
>>>> 'notEvaluated', 'contact_email': 'Email Address', 'date': 'YYYY-MM-DD',
>>>> 'contact_name': 'Organization Name', 'gemet_keywords': 'Utility and
>>>> governmental services', 'enabled': 'true'}}} CELERY_RESULT_SERIALIZER =
>>>> 'json' AWS_STORAGE_BUCKET_NAME = '' FILE_UPLOAD_DIRECTORY_PERMISSIONS =
>>>> None LOCAL_ROOT = '/home/geonode/my_geonode/my_geonode'
>>>> FILE_UPLOAD_HANDLERS = DEFAULT_CONTENT_TYPE = 'text/html' DEBUG_STATIC =
>>>> False MONITORING_SERVICE_NAME = 'local-geonode' SOCIALACCOUNT_PROVIDERS =
>>>> {'linkedin_oauth2': {'SCOPE': ['r_emailaddress', 'r_basicprofile'],
>>>> 'PROFILE_FIELDS': ['emailAddress', 'firstName', 'headline', 'id',
>>>> 'industry', 'lastName', 'pictureUrl', 'positions', 'publicProfileUrl',
>>>> 'location', 'specialties', 'summary']}, 'facebook': {'SCOPE': ['email',
>>>> 'public_profile'], 'METHOD': 'oauth2', 'FIELDS': ['id', 'email', 'name',
>>>> 'first_name', 'last_name', 'verified', 'locale', 'timezone', 'link',
>>>> 'gender']}} STATICFILES_STORAGE =
>>>> 'django.contrib.staticfiles.storage.StaticFilesStorage' USE_WORLDMAP = 0
>>>> SILENCED_SYSTEM_CHECKS = ['1_8.W001', 'fields.W340'] LOGGING_CONFIG =
>>>> 'logging.config.dictConfig' TEMPLATE_LOADERS = AUTO_GENERATE_AVATAR_SIZES =
>>>> HAYSTACK_CONNECTIONS = {'default': {'ENGINE':
>>>> 'haystack.backends.elasticsearch2_backend.Elasticsearch2SearchEngine',
>>>> 'URL': 'http://127.0.0.1:9200/', 'INDEX_NAME': 'haystack'}}
>>>> GEONODE_INTERNAL_APPS = ACCOUNT_LOGIN_REDIRECT_URL = '
>>>> http://localhost:8000/' EMAIL_TIMEOUT = None SESSION_COOKIE_SECURE =
>>>> False GEONODE_CORE_APPS = CACHE_TIME = 0 AWS_ACCESS_KEY_ID =
>>>> u'********************' INSTALLED_APPS = THUMBNAIL_GENERATOR_DEFAULT_BG = '
>>>> http://a.tile.openstreetmap.org/{z}/{x}/{y}.png' STATIC_ROOT =
>>>> '/var/www/geonode/static/' SECURE_HSTS_INCLUDE_SUBDOMAINS = True
>>>> GEONODE_APPS = SESSION_COOKIE_HTTPONLY = True DATETIME_FORMAT = 'N j, Y, P'
>>>> USER_MESSAGES_ALLOW_MULTIPLE_RECIPIENTS = True GEOTIFF_IO_BASE_URL = '
>>>> https://app.geotiff.io' DATE_INPUT_FORMATS =
>>>> ACCOUNT_LOGOUT_REDIRECT_URL = 'http://localhost:8000/' TWITTER_CARD =
>>>> 1 CSRF_COOKIE_NAME = 'csrftoken' SESSION_SAVE_EVERY_REQUEST = False
>>>> NUMBER_GROUPING = 0 LOCALE_PATHS = GEONODE_ROOT =
>>>> '/home/geo/Envs/geonode/src/geonode/geonode' LOGGING = {'loggers':
>>>> {'geonode': {'handlers': ['applogfile'], 'level': 'DEBUG'}, 'django':
>>>> {'handlers': ['applogfile'], 'level': 'DEBUG'}, 'pycsw': {'handlers':
>>>> ['applogfile'], 'level': 'DEBUG'}, 'owslib': {'handlers': ['applogfile'],
>>>> 'level': 'DEBUG'}, 'gsconfig.catalog': {'handlers': ['applogfile'],
>>>> 'level': 'DEBUG'}}, 'disable_existing_loggers': True, 'handlers':
>>>> {'console': {'formatter': 'simple', 'class': 'logging.StreamHandler',
>>>> 'level': 'DEBUG'}, 'applogfile': {'level': 'DEBUG', 'maxBytes': 15728640,
>>>> 'backupCount': 10, 'class': 'logging.handlers.RotatingFileHandler',
>>>> 'filename': '/tmp/GEONODE_APP.log'}, 'mail_admins': {'class':
>>>> 'django.utils.log.AdminEmailHandler', 'filters': ['require_debug_false'],
>>>> 'level': 'ERROR'}}, 'formatters': {'simple': {'format': '%(message)s'},
>>>> 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d
>>>> %(thread)d %(message)s'}}, 'version': 1, 'filters': {'require_debug_false':
>>>> {'()': 'django.utils.log.RequireDebugFalse'}}} INTEGRATION = False OGP_URL
>>>> = 'http://geodata.tufts.edu/solr/select' USE_L10N = 1 CELERYD_LOG_FILE
>>>> = None EMAIL_HOST = 'dummysmtp4.cgiarad.org' NLP_LOCATION_THRESHOLD =
>>>> 1.0 REST_FRAMEWORK = {'DEFAULT_PERMISSION_CLASSES':
>>>> ['rest_framework.permissions.DjangoModelPermissionsOrAnonReadOnly']}
>>>> DATABASE_NAME = 'geonode' MEDIA_URL = '/uploaded/'
>>>> RABBITMQ_SIGNALS_BROKER_URL = 'amqp://localhost:5672'
>>>> DJANGO_LIVE_TEST_SERVER_ADDRESS = 'localhost:8000' MONITORING_ENABLED =
>>>> True DOWNLOAD_FORMATS_VECTOR = ['JPEG', 'PDF', 'PNG', 'Zipped Shapefile',
>>>> 'GML 2.0', 'GML 3.1.1', 'CSV', 'Excel', 'GeoJSON', 'KML', 'View in Google
>>>> Earth', 'Tiles', 'QGIS layer file (.qlr)', 'QGIS project file (.qgs)']
>>>> SKIP_PERMS_FILTER = False GEONODE_CLIENT_HOOKSET = TWITTER_SITE =
>>>> '@GeoNode' SLACK_ENABLED = False PROJECT_NAME = 'my_geonode' TEST_RUNNER =
>>>> 'django_nose.NoseTestSuiteRunner' HAYSTACK_FACET_COUNTS = True
>>>> SECURE_SSL_REDIRECT = False TIME_ZONE = 'UTC' CORS_ORIGIN_ALLOW_ALL = True
>>>> EMAIL_BACKEND = 'django.core.mail.backends.smtp.EmailBackend'
>>>> DEFAULT_MAP_ZOOM = 0 TEMPLATE_CONTEXT_PROCESSORS = MAPBOX_ACCESS_TOKEN =
>>>> u'********************' S3_STATIC_ENABLED = False
>>>> PINAX_NOTIFICATIONS_LANGUAGE_MODEL = None LANGUAGES_BIDI =
>>>> HAYSTACK_SIGNAL_PROCESSOR = 'haystack.signals.RealtimeSignalProcessor'
>>>> CLIENT_RESULTS_LIMIT = 20 MODELTRANSLATION_DEFAULT_LANGUAGE = 'en'
>>>> GEOFENCE_SECURITY_ENABLED = True SOCIALACCOUNT_ADAPTER =
>>>> 'geonode.people.adapters.SocialAccountAdapter' DATABASE_PASSWORD =
>>>> u'********************' SECURE_HSTS_SECONDS = 3600 TEST_NON_SERIALIZED_APPS
>>>> = [] DEFAULT_CHARSET = 'utf-8' OPENGRAPH_ENABLED = 1
>>>> CELERY_MAX_CACHED_RESULTS = 32768 CELERY_RESULT_PERSISTENT = False
>>>> '172.30.1.167', 'localhost'] OGC_SERVER = {'default':
>>>> {'BACKEND_WRITE_ENABLED': True, 'PASSWORD': u'********************',
>>>> 'WPS_ENABLED': True, 'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
>>>> 'PUBLIC_LOCATION': 'http://geoportal.dummy.org/geoserver/',
>>>> 'GEONODE_SECURITY_ENABLED': True, 'PRINT_NG_ENABLED': True,
>>>> 'GEOGIG_DATASTORE_DIR': '', 'PG_GEOGIG': False,
>>>> 'GEOFENCE_SECURITY_ENABLED': True, 'LOCATION': '
>>>> http://localhost/geoserver/', 'MAPFISH_PRINT_ENABLED': True,
>>>> 'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout', 'TIMEOUT': 10,
>>>> 'WMST_ENABLED': False, 'DATASTORE': 'datastore', 'LOG_FILE':
>>>> '/usr/share/geoserver/data/logs/geoserver.log', 'BACKEND':
>>>> 'geonode.geoserver', 'GEOGIG_ENABLED': False, 'USER': 'admin'}}
>>>> DOWNLOAD_FORMATS_RASTER = ['JPEG', 'PDF', 'PNG', 'ArcGrid', 'GeoTIFF',
>>>> 'Gtopo30', 'ImageMosaic', 'KML', 'View in Google Earth', 'Tiles', 'GML',
>>>> 'GZIP', 'QGIS layer file (.qlr)', 'QGIS project file (.qgs)', 'Zipped All
>>>> Files'] AUTH_EXEMPT_URLS = EMAIL_SUBJECT_PREFIX = '[Django] '
>>>> THOUSAND_SEPARATOR = ',' STATICFILES_FINDERS = S3_MEDIA_ENABLED = False
>>>> CELERY_WORKER_DISABLE_RATE_LIMITS = False STATIC_URL = '/static/'
>>>> TIME_INPUT_FORMATS = SECURE_REDIRECT_EXEMPT = [] DATABASES = {'default':
>>>> {'ENGINE': 'django.db.backends.postgresql_psycopg2', 'AUTOCOMMIT': True,
>>>> 'ATOMIC_REQUESTS': False, 'NAME': 'geonode', 'CONN_MAX_AGE': 0,
>>>> 'CONN_TOUT': 900, 'TIME_ZONE': 'UTC', 'PORT': '5432', 'HOST': 'localhost',
>>>> 'USER': 'geonode', 'TEST': {'COLLATION': None, 'CHARSET': None, 'NAME':
>>>> None, 'MIRROR': None}, 'PASSWORD': u'********************', 'OPTIONS': {}},
>>>> 'datastore': {'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>>> 'AUTOCOMMIT': True, 'ATOMIC_REQUESTS': False, 'NAME': 'geonode_data',
>>>> 'CONN_MAX_AGE': 0, 'CONN_TOUT': 900, 'TIME_ZONE': 'UTC', 'PORT': '5432',
>>>> 'HOST': 'localhost', 'USER': 'geonode', 'TEST': {'COLLATION': None,
>>>> 'CHARSET': None, 'NAME': None, 'MIRROR': None}, 'PASSWORD':
>>>> u'********************', 'OPTIONS': {}}} LEAFLET_CONFIG = {'SRID': 3857,
>>>> 'RESET_VIEW': False, 'TILES': [('Watercolor', 'http://{s}.
>>>> tile.stamen.com/watercolor/{z}/{x}/{y}.png
>>>> <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>', 'Map
>>>> tiles by Stamen Design, CC BY 3.0 — Map data © OpenStreetMap contributors,
>>>> CC-BY-SA'), ('Toner Lite', 'http://{s}.
>>>> tile.stamen.com/toner-lite/{z}/{x}/{y}.png
>>>> <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>', 'Map
>>>> CC-BY-SA')], 'PLUGINS': {u'forms': {u'css': , u'auto-include': False,
>>>> u'js': }, u'__default__': {u'css': , u'js': }, u'ALL': {u'css': , u'js': },
>>>> 'leaflet-plugins': {'css': , 'auto-include': True, 'js': },
>>>> u'__is_normalized__': True}} ACCOUNT_APPROVAL_REQUIRED = 0 DATABASE_URL =
>>>> 'sqlite:////home/geo/Envs/geonode/src/geonode/geonode/development.db'
>>>> MODELTRANSLATION_LANGUAGES = ['en'] SLACK_WEBHOOK_URLS = ['
>>>> https://hooks.slack.com/services/T000/B000/XX'] ALT_OSM_BASEMAPS =
>>>> False ACCOUNT_OPEN_SIGNUP = True ACCOUNT_ADAPTER =
>>>> 'geonode.people.adapters.LocalAccountAdapter' SECURE_CONTENT_TYPE_NOSNIFF =
>>>> True SECRET_KEY = u'********************' FILE_UPLOAD_TEMP_DIR = None
>>>> DEFAULT_MAP_CRS = 'EPSG:900913' DATA_UPLOAD_MAX_NUMBER_FIELDS = 100000
>>>> MAP_CLIENT_USE_CROSS_ORIGIN_CREDENTIALS = 0 REDIS_SIGNALS_BROKER_URL =
>>>> 'redis://localhost:6379/0' SETTINGS_MODULE = 'my_geonode.settings'
>>>> AUTHENTICATION_BACKENDS = CELERY_ALWAYS_EAGER = True MODIFY_TOPICCATEGORY =
>>>> True SIGNING_BACKEND = 'django.core.signing.TimestampSigner'
>>>> LANGUAGE_COOKIE_DOMAIN = None DEFAULT_FILE_STORAGE =
>>>> 'django.core.files.storage.FileSystemStorage' SITEURL = '
>>>> http://geoportal.dummy.org/' LANGUAGE_COOKIE_AGE = None
>>>> SOCIALACCOUNT_PROFILE_EXTRACTORS = {'linkedin_oauth2':
>>>> 'geonode.people.profileextractors.LinkedInExtractor', 'facebook':
>>>> 'geonode.people.profileextractors.FacebookExtractor'} MANAGERS = []
>>>> SESSION_EXPIRE_AT_BROWSER_CLOSE = False TIME_FORMAT = 'P'
>>>> CACHE_MIDDLEWARE_ALIAS = 'default' SERVICE_UPDATE_INTERVAL = 0
>>>> CSRF_COOKIE_PATH = '/' NLP_LIBRARY_PATH = '/opt/MITIE/mitielib'
>>>> MONITORING_CONFIG = None CELERYD_POOL_RESTARTS = True PROJECT_ROOT =
>>>> '/home/geo/Envs/geonode/src/geonode/geonode' CACHE_MIDDLEWARE_KEY_PREFIX =
>>>> u'********************' RISKS = {'PDF_GENERATOR': {'BIN':
>>>> '/usr/bin/wkhtml2pdf', 'ARGS': [], 'NAME': 'wkhtml2pdf'},
>>>> 'DEFAULT_LOCATION': None} MAP_BASELAYERS = [{'source': {'url': '
>>>> 'ptype': 'gxp_wmscsource'}}, {'group': 'background', 'name': 'background',
>>>> 'args': ['No background'], 'visibility': False, 'source': {'ptype':
>>>> 'gxp_olsource'}, 'fixed': True, 'type': 'OpenLayers.Layer'}, {'source':
>>>> {'ptype': 'gxp_olsource'}, 'wrapDateLine': True, 'fixed': True,
>>>> 'attribution': '© UNESCO', 'name': 'background', 'title': 'UNESCO',
>>>> 'group': 'background', 'args': ['UNESCO', 'http://en.unesco.org/tiles/${z}/${x}/${y}.png'],
>>>> 'type': 'OpenLayers.Layer.XYZ', 'visibility': False}, {'source':
>>>> 'attribution': '© UNESCO', 'name': 'background', 'title': 'UNESCO GEODATA',
>>>> 'group': 'background', 'args': ['UNESCO GEODATA', '
>>>> http://en.unesco.org/tiles/geodata/${z}/${x}/${y}.png'], 'type': '
>>>> OpenLayers.Layer.XYZ', 'visibility': False}, {'source': {'ptype':
>>>> 'gxp_olsource'}, 'wrapDateLine': True, 'fixed': True, 'attribution': "©
>>>> OpenStreetMap, Tiles courtesy of Humanitarian OpenStreetMap Team", 'name':
>>>> 'background', 'title': 'Humanitarian OpenStreetMap', 'group': 'background',
>>>> 'args': ['Humanitarian OpenStreetMap', '
>>>> http://a.tile.openstreetmap.fr/hot/${z}/${x}/${y}.png'], 'type': '
>>>> Mapbox © OpenStreetMap Improve this map", 'name': 'background', 'title':
>>>> 'MapBox Satellite Streets', 'group': 'background', 'args': ['MapBox
>>>> http://api.mapbox.com/styles/v1/mapbox/satellite-streets-v9/tiles/${z}/${x}/${y}?access_token='],
>>>> 'attribution': "© Mapbox © OpenStreetMap Improve this map", 'name':
>>>> 'background', 'title': 'MapBox Streets', 'group': 'background', 'args':
>>>> ['MapBox Streets', '
>>>> http://api.mapbox.com/styles/v1/mapbox/streets-v9/tiles/${z}/${x}/${y}?access_token='],
>>>> {'ptype': 'gxp_osmsource'}, 'wrapDateLine': True, 'attribution': "©
>>>> OpenStreetMap contributors", 'name': 'mapnik', 'title': 'OpenStreetMap',
>>>> 'group': 'background', 'fixed': True, 'type': 'OpenLayers.Layer.OSM',
>>>> 'visibility': True}] LOGIN_REDIRECT_URL = '/' GROUP_PRIVATE_RESOURCES =
>>>> False DATE_FORMAT = 'N j, Y' LOCAL_SIGNALS_BROKER_URL = 'memory://'
>>>> MEDIA_ROOT = '/var/www/geonode/uploaded' PROXY_URL = '/proxy/?url='
>>>> TEMPLATE_DEBUG = False DEFAULT_FROM_EMAIL = 'Geoportal dummy '
>>>> FREETEXT_KEYWORDS_READONLY = u'********************' GEONODE_EXCHANGE =
>>>> NOTIFICATIONS_MODULE = 'pinax.notifications' SITE_ID = 1
>>>> ALLOWED_INCLUDE_ROOTS = API_LIMIT_PER_PAGE = u'********************'
>>>> SHORT_DATE_FORMAT = 'm/d/Y' ACTSTREAM_SETTINGS = {'GFK_FETCH_DEPTH': 1,
>>>> 'USE_JSONFIELD': True, 'FETCH_RELATIONS': True, 'USE_PREFETCH': False}
>>>> AWS_S3_BUCKET_DOMAIN = '.s3.amazonaws.com' FILE_UPLOAD_MAX_MEMORY_SIZE
>>>> = 2621440 DISPLAY_SOCIAL = 1 CSRF_COOKIE_AGE = 31449600 EMAIL_USE_SSL =
>>>> False INTERNAL_IPS = EMAIL_PORT = 25 GROUP_MANDATORY_RESOURCES = False
>>>> PASSWORD_HASHERS = u'********************' ANONYMOUS_USER_ID = '-1'
>>>> DATETIME_INPUT_FORMATS = You're seeing this error because you have DEBUG =
>>>> True in your Django settings file. Change that to False, and Django will
>>>> display a standard page generated by the handler for this status code.
>>>> Michael Härtel
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information. == Ing. Alessio Fabiani
>>> @alfa7691 Founder/Technical Lead
>>> GeoSolutions S.A.S. Via di Montramito 3/A - 55054 Massarosa (LU) -
>>> Italy phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 331
>>> 6233686
>>> http://www.geo-solutions.it http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>> GeoSolutions S.A.S. Via di Montramito 3/A - 55054 Massarosa (LU) - Italy phone:
>> +39 0584 962313 fax: +39 0584 1660272 mob: +39 331 6233686
>> geonode-devel mailing listgeonode-devel at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-devel
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190516/8906f821/attachment-0001.html>
More information about the geonode-devel
