[GeoNode-devel] GeoNode versions confusion
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue May 28 08:13:51 PDT 2019
Hello Paolo,
"master" branch (aka 2.10rc5) is almost ready for the next stable 2.10
release, which will happen in June.
2.8.1 is stable but also has a lot of bugs and issues
2.8.x (aka 2.8.2) is an update of 2.8.1 backporting most of the critical
2.10.x bugfixes, but it is still based on a very old version of Django, 1.8
actually.
I kindly suggest you to re-base your development on master branch.
We will tag and branch 2.10.x right after the 2.10.0 release in June.
Cheers,
Alessio.
Il giorno mar 28 mag 2019 alle ore 15:56 <amagislist at oicom.com> ha scritto:
> Hi all,
> I'm trying to understand which is the "right" version of GeoNode to use,
> since the README in GitHub says: "The latest official release is 2.8.2!",
> but the demo site says: "Fornito da: GeoNode versione 2.10rc5".
> The document site (http://docs.geonode.org/en/latest/index.html)
> only report versions: "latest, stable, 2.0, 1.2, master, 2.4.x".
> In GitHub there are branches: "master, 2.8.x, 2.20.x" (and a few stale
> branches), but no 2.10.x branch.
> Inn GitHub Releases there is a "2.8.1" and a "2.10rc4",
> but no "2.10rc5", as used for the demo site and no "2.8.2", as the
> README says.
> I developed a customization upon version "2.6.1" (customization from a
> Django point of view),
> but it's quite old and now I need to upgrade the base GeoNode version
> it's based on,
> but since I'm expecting upgrading not to be easy, I would like to avoid
> having to do it more than once
> in a short time.
> I also read a few discussions about branches and versions naming for
> Python 3/Django 2,
> but I don't know which GeoNode version, if any, is actually based upon
> Python 3/Django 2
> and if it is already good to use for production, or not.
> Is the choice only between 2.8.x and 2.10.x?
> What are the diferences between them, is 2.10.x more "advanced" than
> "2.8.x"?
> Is "2.10.x" already ready for production (or will it be soon enough)?
> Thank you very much in advance for any info.
> Bye
> Paolo Rizzi
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190528/f9ef8fc0/attachment.html>
More information about the geonode-devel
