[GeoNode-devel] Problems Running GeoNode's Test Suite
Travis Brundage
travislbrundage at gmail.com
Fri Nov 8 19:02:44 PST 2019
Hey all,
Just posting one more time to say that doing a local installation fixed
this. Here is what I did along the way.
Following the instructions in the documentation for a docker install did
not work at all for bringing up GeoNode, giving me some timeout errors.
Following the instructions in the documentation here:
http://docs.geonode.org/en/2.10.x/install/core/index.html#deploy-a-vanilla-geonode-2-10-with-docker
During core docker installation, neither
`docker-compose -f docker-compose.yml -f
docker-compose.override.localhost.yml pull`
or
docker-compose.override.localhost.yml up -d`
works. It seems like the images are not available, as it's getting timeout
errors.
Error on `pull`:
https://gist.github.com/travislbrundage/c7c1a0e6b5d17ddd8659c64547418aff
Error on `up -d`:
https://gist.github.com/travislbrundage/34e56e56285654e913234a7759139205
Maybe I did something wrong that way, or my network was too slow (shouldn't
be, but who knows), but wanted to document it just in case.
Using the regular docker setup in GitHub brings up GeoNode successfully,
but tests hit this celery error (before, I was running into this issue:
https://github.com/GeoNode/geonode/issues/5196).
Using the SPC GeoNode docker setup has the same results as above.
Finally, using the local installation and paver setup did get GeoNode up
successfully and the tests are working much better.
Thanks to everyone who helped me on Gitter, I appreciate it a lot. Now I
can successfully test the changes I make to improve test speed and coverage
which is great. Expect some commits and PRs from me next week. :)
Cheers all,
Travis
On Wed, Nov 6, 2019 at 11:00 PM Travis Brundage <travislbrundage at gmail.com>
wrote:
> Just following up on this, I realized the tests were stopping because I
> was passing the --failfast option when running them.
> Still, this error affects the overwhelming majority of GeoNode's unit
> tests for me, so it's a blocker for me for running them. Changing the
> celery and django-celery-beat versions did not have any affect.
> Has anyone else seen this error or am I doing something wrong? Perhaps
> there is a config option for celery I need to set?
> On Thu, Oct 31, 2019 at 12:13 PM Travis Brundage <
> travislbrundage at gmail.com> wrote:
>> Hey all,
>> So I have been struggling a bit with figuring out how to run GeoNode's
>> test suite properly, and I've also run into multiple problems. I am still
>> not entirely clear on what I am supposed to be doing to run GeoNode's
>> tests, but here is what I have done:
>> In .env: SET_DOCKER_ENV=development
>> Starting GeoNode docker: docker-compose -f docker-compose.async.yml -f
>> docker-compose.development.yml up -d
>> Configuring the system for running tests:
>> 1. Install python 2.7 on the system. Checking python version is 2.7.x:
>> python --version
>> 2. Create a python virtual environment for GeoNode dev
>> 2a. Install virtualenv: sudo apt-get install python-virtualenv
>> 2b. Create Python2.7 virutalenv: virtualenv -p `which python2.7`
>> geonode-env
>> 2c. Activate the environment: source geonode-env/bin/activate
>> 3. In geonode/ install the requirements: pip install -r requirements.txt
>> 4. Configure GDAL bindings (reference
>> https://mothergeo-py.readthedocs.io/en/latest/development/how-to/gdal-ubuntu-pkg.html
>> sudo add-apt-repository ppa:ubuntugis/ppa && sudo apt-get update
>> sudo apt-get update
>> sudo apt-get install gdal-bin
>> sudo apt-get install libgdal-dev
>> export CPLUS_INCLUDE_PATH=/usr/include/gdal
>> export C_INCLUDE_PATH=/usr/include/gdal
>> pip install GDAL==2.4.2
>> Finally, running tests: coverage run --branch --source=geonode manage.py
>> test <geonode.app.tests> --noinput
>> (replacing with app I want to test)
>> Btw, I added this to our running document of notes for GeoNode, but
>> please point out if I am doing something incorrectly:
>> https://docs.google.com/document/d/1h4xhXTejSkfqmEQmzl6CkcySc9_COZldm_5qvFI3fB8/
>> For a while this was mostly working (just slow, some problems in the
>> setUp causing that). However, now I have run into a blocking issue. I don't
>> know what I have done or changed other than pulling recent commits. Celery
>> is complaining about an improperly configured file-system backend.
>> ImproperlyConfigured: The configured path for the file-system backend
>> does not work correctly, please make sure that it exists and has the
>> correct permissions.
>> Full stack trace:
>> https://gist.github.com/travislbrundage/81fe15cf06c5179e9b8cf16060f98d5c
>> Every test I run has the same result. Anyone have pointers for what this
>> might mean is wrong with my GeoNode?
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191108/c21a6315/attachment.html>
More information about the geonode-devel
