[GeoNode-devel] GNIP-64 Status and Plan
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Nov 14 01:21:12 PST 2019
Cool,
I'll start to keep some tasks soon.
Il giorno mer 13 nov 2019 alle ore 22:50 Travis Brundage <
travislbrundage at gmail.com> ha scritto:
> Hello all,
> I have updated the GNIP with appropriate links as suggested. I've also
> created a new document per Alessio's suggestion. Feel free to update it or
> let me know how I could make it better. I will be filling it out more as I
> go and probably things will get changed over time.
> By the way, please tell me if the link does not work or you cannot edit it.
> GNIP-64 tasks spreadsheet:
> https://docs.google.com/spreadsheets/d/1gr4ISkFBarY-7i_DPi0Vt_FnA5_uF30dGUgYpcIZ-xw/edit#gid=0
> Cheers,
> Travis
> On Tue, Nov 5, 2019 at 11:18 AM Travis Brundage <travislbrundage at gmail.com>
> wrote:
>> Thank you all for your feedback!
>> Toni: No actually, I am still having that issue. :/ That is a good hint
>> though - I will debug some more, but if anyone knows why that is happening,
>> it would be much appreciated...
>> Alessio: Thanks so much for your feedback. I think your suggestions make
>> sense. I'll work on that today and update the GNIP main post with the
>> relevant links and post a shorter notice as a comment about the update.
>> Cheers,
>> Travis
>> On Tue, Nov 5, 2019 at 1:55 AM Toni Schönbuchner <
>> toni.schoenbuchner at csgis.de> wrote:
>>> A W E S O M E ~ T R A V I S !
>>> Many many thanks!
>>> Have you already found a solution for the celery path problem? If I
>>> remember
>>> corectly there have been some updates on celery-beat (maybe celery as
>>> well) which might
>>> cause issues with docker ...
>>> – toni
>>> *Von: *Travis Brundage <travislbrundage at gmail.com>
>>> *Betreff: **[GeoNode-devel] GNIP-64 Status and Plan*
>>> *Datum: *5. November 2019 um 05:22:59 MEZ
>>> *An: *geonode-devel at lists.osgeo.org
>>> Hi all,
>>> Just wanted to write a status report with regards to GNIP-64. I am
>>> excited to hear that help is on the way too :)
>>> Most of what Coop wrote in the GNIP is still accurate. Broadly speaking,
>>> I see this broken down into the following steps:
>>> 1. Python library analysis
>>> 2. Test suite improvements
>>> 3a. Python library updates
>>> 3b. GeoNode codebase update
>>> 3c. django-osgeo-importer update
>>> 4. Testing and release
>>> 5. Repeat for Django 2
>>> Coop had already started a spreadsheet detailing the libraries GeoNode
>>> uses and their Python 3 compatibility. I have updated this recently. You
>>> can find it here:
>>> https://docs.google.com/spreadsheets/d/1buUuIeGPL8zfv5xFotfGMpxHt2i8njoCEh4Y4kna3rY/edit#gid=0
>>> From this you can see a few categories.
>>> 1. Some libraries are completely outdated and inactive and require
>>> removal and if needed, replacement.
>>> 2. Some libraries do not yet have Python 3 compatibility, but we could
>>> update them for the community. Otherwise, we’ll need to remove and possibly
>>> replace them.
>>> 3. Some libraries do not yet have Python 3 compatibility, but the
>>> community is working on it or their github still has activity. We could
>>> save these for last or offer to help their community upgrade.
>>> 4. Some libraries do not officially support Python 3 or 3.7
>>> specifically, but seem to build fine as is in a Python 3.7 environment.
>>> 5. Some libraries are GeoNode community’s. :)
>>> 6. Some libraries have newer versions that are Python 3+ compatible, but
>>> not backwards compatible with Python 2.7. These need to be delayed until
>>> GeoNode core is updated.
>>> 7. The majority thankfully - some libraries are fully Python 2.7 and
>>> 3.7+ compatible.
>>> Next is improving GeoNode’s test suite. I don’t have a precise goal
>>> here, but want to improve the speed and coverage of GeoNode’s tests to
>>> prepare for the Python 3 upgrade, so we can more easily identify any
>>> functionality that gets broken. I have already run into a few issues and
>>> made another thread about this.
>>> For upgrading the codebase, I planned to branch off the next release,
>>> 2.10.1.
>>> From what I have researched, I don’t know if there’s a “correct” way to
>>> update a codebase to Python 3, but seems like there are a few strategies.
>>> My plan was to create a new branch and brute force the 2to3.py script, and
>>> hopefully with good test coverage, get a useful coverage report to see what
>>> has broken.
>>> Possibly that is too much and won’t prove fruitful, in which case I
>>> would start a new branch and do it app by app instead. I have not tested
>>> 2to3.py in the wild before, so I don’t know how helpful it is, but from
>>> what I’ve read it is a good starting point usually.
>>> As a side note, it will be helpful to configure your IDE of choice with
>>> a Python 3 interpreter. I use PyCharm, so some instructions for that here:
>>> https://www.jetbrains.com/help/pycharm/configuring-python-interpreter.html
>>> In general my plan of attack is:
>>> 1. Run Python 2to3 script
>>> 2. Clean up anything breaking GeoNode build entirely
>>> 3. Run tests for coverage report to see what breaks
>>> 4. Clean up until tests pass
>>> 5. Check visually in GeoNode that the app seems to function
>>> 6. Clean up until interactions work as expected
>>> Simultaneously we’ll need to update the remaining Python libraries. This
>>> will be a bit tricky as some provide Python 3 compatibility on later
>>> versions, but not with Python 2 compatibility. Also, some still do not have
>>> Python 3 compatibility at all, so the work is on us or drop those libraries.
>>> We'll also need to make sure GeoNode's libraries are updated, and it was
>>> planned to do django-osgeo-importer as part of the work too.
>>> If all goes well, we should have a functioning GeoNode running on Python
>>> 3. :)
>>> I think Alessio’s testing document will be very helpful again here:
>>> https://docs.google.com/spreadsheets/d/13aaZ1l_2_SHzdmz9DwExEO_jxwgNuXfMa6oF5eWIv_s/edit#gid=376642658
>>> I don’t know exactly how this work should be merged in (or if it would
>>> be), as I assume development will continue on GeoNode master, so we will
>>> need to resolve changes along the way. This won’t be a problem for a little
>>> while though.
>>> Finally, repeat for Django 2. My hope is this part is easier, as I think
>>> there are less compatibility conflicts there, but we’ll see.
>>> I think that about wraps it up. Let me know your thoughts or if you have
>>> any advice for me, and feel free to message me here or on Gitter to
>>> coordinate on this effort. Thank you all for helping out on this!
>>> Cheers,
>>> Travis
>>> *Von: *Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>>> *Betreff: **Aw: [GeoNode-devel] GNIP-64 Status and Plan*
>>> *Datum: *5. November 2019 um 10:04:57 MEZ
>>> *An: *Travis Brundage <travislbrundage at gmail.com>, Travis Brundage <
>>> tbrundage at boundlessgeo.com>
>>> *Kopie: *geonode-devel <geonode-devel at lists.osgeo.org>
>>> @Travis Brundage <tbrundage at boundlessgeo.com> awesome plan, thanks.
>>> Just a couple of comments, for now:
>>> 1. After the release, the "master" branch will become GeoNode 3.0 and
>>> officially it will start the Python 3 upgrade.
>>> 2. I would keep the issue (
>>> https://github.com/GeoNode/geonode/issues/4276) updated with the
>>> references to discussions and decisions.
>>> We should edit the GNIP description and add to the bottom all the links
>>> to ml discussion also, that can be retrieved from here
>>> http://osgeo-org.1560.x6.nabble.com/GeoNode-devel-f5185388.html
>>> Also, at a certain point, we would need (at least this is my suggestion)
>>> to translate the plan into a Google spreadheest and a list of tasks so that
>>> other people can easily keep them a start working in parallel. What do you
>>> think?
>>> Thanks again,
>>> Alessio.
>>> Il giorno mar 5 nov 2019 alle ore 05:26 Travis Brundage <
>>>> Hi all,
>>>> speaking, I see this broken down into the following steps:
>>>> can find it here:
>>>> replace them.
>>>> but not backwards compatible with Python 2.7. These need to be delayed
>>>> until GeoNode core is updated.
>>>> 3.7+ compatible.
>>>> 2.10.1.
>>>> has broken.
>>>> This will be a bit tricky as some provide Python 3 compatibility on later
>>>> was planned to do django-osgeo-importer as part of the work too.
>>>> Python 3. :)
>>>> while though.
>>>> think there are less compatibility conflicts there, but we’ll see.
>>>> have any advice for me, and feel free to message me here or on Gitter to
>>>> Cheers,
>>>> Travis
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191114/0a903d58/attachment-0001.html>
More information about the geonode-devel
