[GeoNode-devel] GNIP-64 Status and Plan
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Nov 14 01:21:58 PST 2019
By the way, let's work on master branch
Il giorno gio 14 nov 2019 alle ore 10:21 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Cool,
> I'll start to keep some tasks soon.
> Il giorno mer 13 nov 2019 alle ore 22:50 Travis Brundage <
> travislbrundage at gmail.com> ha scritto:
>> Hello all,
>> I have updated the GNIP with appropriate links as suggested. I've also
>> created a new document per Alessio's suggestion. Feel free to update it or
>> let me know how I could make it better. I will be filling it out more as I
>> go and probably things will get changed over time.
>> By the way, please tell me if the link does not work or you cannot edit
>> it.
>> GNIP-64 tasks spreadsheet:
>> https://docs.google.com/spreadsheets/d/1gr4ISkFBarY-7i_DPi0Vt_FnA5_uF30dGUgYpcIZ-xw/edit#gid=0
>> Cheers,
>> Travis
>> On Tue, Nov 5, 2019 at 11:18 AM Travis Brundage <
>> travislbrundage at gmail.com> wrote:
>>> Thank you all for your feedback!
>>> Toni: No actually, I am still having that issue. :/ That is a good hint
>>> though - I will debug some more, but if anyone knows why that is happening,
>>> it would be much appreciated...
>>> Alessio: Thanks so much for your feedback. I think your suggestions make
>>> sense. I'll work on that today and update the GNIP main post with the
>>> relevant links and post a shorter notice as a comment about the update.
>>> Cheers,
>>> Travis
>>> On Tue, Nov 5, 2019 at 1:55 AM Toni Schönbuchner <
>>> toni.schoenbuchner at csgis.de> wrote:
>>>> A W E S O M E ~ T R A V I S !
>>>> Many many thanks!
>>>> Have you already found a solution for the celery path problem? If I
>>>> remember
>>>> corectly there have been some updates on celery-beat (maybe celery as
>>>> well) which might
>>>> cause issues with docker ...
>>>> – toni
>>>> *Von: *Travis Brundage <travislbrundage at gmail.com>
>>>> *Betreff: **[GeoNode-devel] GNIP-64 Status and Plan*
>>>> *Datum: *5. November 2019 um 05:22:59 MEZ
>>>> *An: *geonode-devel at lists.osgeo.org
>>>> Hi all,
>>>> Just wanted to write a status report with regards to GNIP-64. I am
>>>> excited to hear that help is on the way too :)
>>>> Most of what Coop wrote in the GNIP is still accurate. Broadly
>>>> speaking, I see this broken down into the following steps:
>>>> 1. Python library analysis
>>>> 2. Test suite improvements
>>>> 3a. Python library updates
>>>> 3b. GeoNode codebase update
>>>> 3c. django-osgeo-importer update
>>>> 4. Testing and release
>>>> 5. Repeat for Django 2
>>>> Coop had already started a spreadsheet detailing the libraries GeoNode
>>>> uses and their Python 3 compatibility. I have updated this recently. You
>>>> can find it here:
>>>> https://docs.google.com/spreadsheets/d/1buUuIeGPL8zfv5xFotfGMpxHt2i8njoCEh4Y4kna3rY/edit#gid=0
>>>> From this you can see a few categories.
>>>> 1. Some libraries are completely outdated and inactive and require
>>>> removal and if needed, replacement.
>>>> 2. Some libraries do not yet have Python 3 compatibility, but we could
>>>> update them for the community. Otherwise, we’ll need to remove and possibly
>>>> replace them.
>>>> 3. Some libraries do not yet have Python 3 compatibility, but the
>>>> community is working on it or their github still has activity. We could
>>>> save these for last or offer to help their community upgrade.
>>>> 4. Some libraries do not officially support Python 3 or 3.7
>>>> specifically, but seem to build fine as is in a Python 3.7 environment.
>>>> 5. Some libraries are GeoNode community’s. :)
>>>> 6. Some libraries have newer versions that are Python 3+ compatible,
>>>> but not backwards compatible with Python 2.7. These need to be delayed
>>>> until GeoNode core is updated.
>>>> 7. The majority thankfully - some libraries are fully Python 2.7 and
>>>> 3.7+ compatible.
>>>> Next is improving GeoNode’s test suite. I don’t have a precise goal
>>>> here, but want to improve the speed and coverage of GeoNode’s tests to
>>>> prepare for the Python 3 upgrade, so we can more easily identify any
>>>> functionality that gets broken. I have already run into a few issues and
>>>> made another thread about this.
>>>> For upgrading the codebase, I planned to branch off the next release,
>>>> 2.10.1.
>>>> From what I have researched, I don’t know if there’s a “correct” way to
>>>> update a codebase to Python 3, but seems like there are a few strategies.
>>>> My plan was to create a new branch and brute force the 2to3.py script, and
>>>> hopefully with good test coverage, get a useful coverage report to see what
>>>> has broken.
>>>> Possibly that is too much and won’t prove fruitful, in which case I
>>>> would start a new branch and do it app by app instead. I have not tested
>>>> 2to3.py in the wild before, so I don’t know how helpful it is, but from
>>>> what I’ve read it is a good starting point usually.
>>>> As a side note, it will be helpful to configure your IDE of choice with
>>>> a Python 3 interpreter. I use PyCharm, so some instructions for that here:
>>>> https://www.jetbrains.com/help/pycharm/configuring-python-interpreter.html
>>>> In general my plan of attack is:
>>>> 1. Run Python 2to3 script
>>>> 2. Clean up anything breaking GeoNode build entirely
>>>> 3. Run tests for coverage report to see what breaks
>>>> 4. Clean up until tests pass
>>>> 5. Check visually in GeoNode that the app seems to function
>>>> 6. Clean up until interactions work as expected
>>>> Simultaneously we’ll need to update the remaining Python libraries.
>>>> This will be a bit tricky as some provide Python 3 compatibility on later
>>>> versions, but not with Python 2 compatibility. Also, some still do not have
>>>> Python 3 compatibility at all, so the work is on us or drop those libraries.
>>>> We'll also need to make sure GeoNode's libraries are updated, and it
>>>> was planned to do django-osgeo-importer as part of the work too.
>>>> If all goes well, we should have a functioning GeoNode running on
>>>> Python 3. :)
>>>> I think Alessio’s testing document will be very helpful again here:
>>>> https://docs.google.com/spreadsheets/d/13aaZ1l_2_SHzdmz9DwExEO_jxwgNuXfMa6oF5eWIv_s/edit#gid=376642658
>>>> I don’t know exactly how this work should be merged in (or if it would
>>>> be), as I assume development will continue on GeoNode master, so we will
>>>> need to resolve changes along the way. This won’t be a problem for a little
>>>> while though.
>>>> Finally, repeat for Django 2. My hope is this part is easier, as I
>>>> think there are less compatibility conflicts there, but we’ll see.
>>>> I think that about wraps it up. Let me know your thoughts or if you
>>>> have any advice for me, and feel free to message me here or on Gitter to
>>>> coordinate on this effort. Thank you all for helping out on this!
>>>> Cheers,
>>>> Travis
>>>> *Von: *Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>>>> *Betreff: **Aw: [GeoNode-devel] GNIP-64 Status and Plan*
>>>> *Datum: *5. November 2019 um 10:04:57 MEZ
>>>> *An: *Travis Brundage <travislbrundage at gmail.com>, Travis Brundage <
>>>> tbrundage at boundlessgeo.com>
>>>> *Kopie: *geonode-devel <geonode-devel at lists.osgeo.org>
>>>> @Travis Brundage <tbrundage at boundlessgeo.com> awesome plan, thanks.
>>>> Just a couple of comments, for now:
>>>> 1. After the release, the "master" branch will become GeoNode 3.0 and
>>>> officially it will start the Python 3 upgrade.
>>>> 2. I would keep the issue (
>>>> https://github.com/GeoNode/geonode/issues/4276) updated with the
>>>> references to discussions and decisions.
>>>> We should edit the GNIP description and add to the bottom all the links
>>>> to ml discussion also, that can be retrieved from here
>>>> http://osgeo-org.1560.x6.nabble.com/GeoNode-devel-f5185388.html
>>>> Also, at a certain point, we would need (at least this is my
>>>> suggestion) to translate the plan into a Google spreadheest and a list of
>>>> tasks so that other people can easily keep them a start working in
>>>> parallel. What do you think?
>>>> Thanks again,
>>>> Alessio.
>>>> Il giorno mar 5 nov 2019 alle ore 05:26 Travis Brundage <
>>>>> Hi all,
>>>>> can find it here:
>>>>> replace them.
>>>>> 3.7+ compatible.
>>>>> 2.10.1.
>>>>> to update a codebase to Python 3, but seems like there are a few
>>>>> strategies. My plan was to create a new branch and brute force the 2to3.py
>>>>> script, and hopefully with good test coverage, get a useful coverage report
>>>>> to see what has broken.
>>>>> with a Python 3 interpreter. I use PyCharm, so some instructions for that
>>>>> here:
>>>>> Python 3. :)
>>>>> while though.
>>>>> Cheers,
>>>>> Travis
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191114/1168d17e/attachment-0001.html>
More information about the geonode-devel mailing list
